MK7.5 Digital Cockpit retrofit
Cuzoe
Los Angeles
@xabhax Thank you.
My (old, before Mk8 wheel) steering wheel control module was PN 5G0 959 442 R (yours is N) and the coding was 34000 (yours is 28FFFF).
- Besides the different shape, Golf vs GTI, I had cancel where you have the mode for cruise control
@Nuje has PN 5G0 959 442 K though, and his coding is 2FFFFF
- As compared to yours his buttons only differ in shape, Golf vs GTI
- Your coding of 28FFFF might get his arrows to zoom... @Nuje hurry up and try this out!
Oddly enough VCDS says "This Control Module does NOT support Coding. The displayed Coding reflects the currently installed Hardware and cannot be changed!" I'm not sure the reason for that, but I read on a Drive2 post about MFSW retrofits that this coding can be changed in OBDEleven or ODIS but not VCDS.
I'll have to find some Mk8 scans to see what might work for my new wheel/buttons. I don't even know what the coding is on them right now, need to take a new scan/ad-map.
GolfAlltrack
I ordered the AID retrofit kit from Eurozone and got most things working. Took it to my Indy shop that has Odis and got the mileage and stuff done. But now I’m running into these small issues. Been looking at a lot of threads and figured I’d try here.
2017 Golf Alltrack SEL.
Question 1- how do I regain “media” to display? I got back “phone” and “nav” but not been able to find “media”
Question 2 - how do I get back to show driver assist systems? (Lane keep assist toggle, adaptive cruise control etc)
Question 3- how do change the yellow ambient light to blue or red or something? Seems like some of a selectable colors from the infotainment screen.
Cuzoe
Los Angeles
Not in order... but question 3
https://www.golfmk7.com/forums/inde...nfo-display-themes-coding-spreadsheed.357983/
Question 1 and 2... Long coding and adaptations. If you have VCDS (you should 😆) then post an Auto-scan and ad-map. If you have Obdeleven then post a "backup"... I think that's what they call it.
2017 Alltrack is a 7 or 7.5? Do you have selectable colors on the infotainment? If yes then the AID can probably be coded to match whatever color you choose.
HawkeAssault
Arizona Tucson/Phoenix
'15 GTI, '92 Corrado
2017 for USA should be a 7. All platforms flipped to 7.5 in 2018
GolfAlltrack
I will work on getting a Autoscan. I have VCDS and was able to get most of the items working after getting back from the Indy shop. I have a Mk7 Golf Alltrack, I don't have selectable colors in infotainment but was able to code in to select. However no colors come up yet so I'm sure its a simple switch or activation on one of the adaption list.
GolfAlltrack
Here is the autoscan- Eurozone said that I should check module 17, "
_audio: [VN]_yes
_Lane_assist: [VN]_Yes"
For getting the audio option back and to get the assist features to be able to toggle back on. Previously the button on the side of the turn signal stalk allowed me to select to turn on lane assist and adaptive cruise but since the switch it says no assist systems available.
Tuesday,27,September,2022,17:44:17:56035
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 22.9.0.0 (x64) HEX-V2 CB: 0.4623.4
Data version: 20220830 DS341.0
www.Ross-Tech.com
VIN: 3VWH17AU5HM507170 License Plate: 410 WWV
Mileage: 118144km-73411mi Repair Order:
Chassis Type: AU-VW37 (5Q0)
Scan: 01 02 03 05 08 09 10 13 15 16 17 19 22 2B 42 44 47 52 55 5F
75 A5
VIN: 3VWH17AU5HM507170 Mileage: 118144km-73411miles
02-Auto Trans -- Status: Malfunction 0010
03-ABS Brakes -- Status: Malfunction 0010
05-Acc/Start Auth. -- Status: Malfunction 0010
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: Malfunction 0010
10-Park/Steer Assist -- Status: Malfunction 0010
13-Auto Dist. Reg -- Status: Malfunction 0010
15-Airbags -- Status: Malfunction 0010
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: Malfunction 0010
19-CAN Gateway -- Status: Malfunction 0010
22-AWD -- Status: Malfunction 0010
2B-Steer. Col. Lock -- Status: Malfunction 0010
42-Door Elect, Driver -- Status: Malfunction 0010
44-Steering Assist -- Status: Malfunction 0010
47-Sound System -- Status: OK 0000
52-Door Elect, Pass. -- Status: Malfunction 0010
55-Headlight Range -- Status: Malfunction 0010
75-Telematics -- Status: Malfunction 0010
A5-Frt Sens. Drv. Assist -- Status: Malfunction 0010
Address 01: Engine (J623-CXBB) Labels:. 06K-907-425-V1.clb
Part No SW: 8V0 906 264 L HW: 06K 907 425 B
Component: 1.8l R4 TFSI H13 0002
Revision: --H13--- CVN: 6D3A6721
Coding: 311D00322466002F1000
Shop #: WSC 00066 790 00149
ASAM Dataset: EV_ECM18TFS0208V0906264L 001003
ROD: EV_ECM18TFS0208V0906264L.rod
VCID: 45D75CFC452C4813945-8010
VINID: 0E69D80474651587450070470044558D7D
6 Faults Found:
17176 - Databus
U1123 00 [032] - Received Error Message
Intermittent - Not Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 6
Fault Frequency: 2
Mileage: 0 km
Date: 2011.01.01
Time: 00:00:02
Cuzoe
Los Angeles
All those faults, haha... in the same screen as the auto-scan select clear DTC's then run another scan, that will let us see what's actually wrong.
- The majority of those will clear, just caused when doing the pairing/coding of the new dash
- Your ODIS guy should've cleared them though, that's the only way to see if something was missed/coded improperly
Anyway, also get adaptation maps for 17-Instruments and 5F-Infotatainment
Instructions here... https://www.ross-tech.com/vcds/tour/controller-channels-map.php
Put the new scan and each map in separate code tags. It will make reading them in the forum much easier.
Code:
Auto-scan goes here
I put your current scan in code tags so you can see the difference...
Code:
www.Ross-Tech.com
75 A5
6 Faults Found:
17176 - Databus
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
Mileage: 0 km
Date: 2011.01.01
Time: 00:00:02
Engine RPM: 0.00 /min
Normed load value: 0.0 %
Vehicle speed: 0 km/h
Coolant temperature: 78 °C
Intake air temperature: 56 °C
Ambient air pressure: 990 mbar
Voltage terminal 30: 12.167 V
Unlearning counter according OBD: 38
Drivetrain coordinator: ACC fault status-ACC is active despite EPB deceleration: No
Drivetrain coordinator: ACC fault status-ACC active: although TSK passive: No
Drivetrain coordinator: ACC fault status-Start off or stop request at stopping speed not set: No
Drivetrain coordinator: ACC fault status-Start off and stop request sent simultaneously: No
Drivetrain coordinator: ACC fault status-ACC active: although limiter active: No
Drivetrain coordinator: ACC fault status-ACC reactivates itself after locking: No
Drivetrain coordinator: ACC fault status-ACC sends undefined signals: No
Drivetrain coordinator: ACC fault status-ACC active although main switch off: No
Drivetrain coordinator: ACC fault status-ACC is active despite driver braking: No
Drivetrain coordinator: ACC fault status-ACC is active despite ESP/ASR passive sampling: No
Drivetrain coordinator: brake fault status-Deceleration sensor not available: No
Drivetrain coordinator: brake fault status-Deceleration sensor malfunction: No
Drivetrain coordinator: brake fault status-ESP system error: No
Drivetrain coordinator: brake fault status-ESP system malfunction due to inaccurate engine torque: No
Drivetrain coordinator: brake fault status-ESP indicates TSK message consistency error: No
Drivetrain coordinator: brake fault status-TSK/ESP handshake error: No
Drivetrain coordinator: brake fault status-ESP automatic engagement malfunction: No
Drivetrain coordinator: brake fault status-Brake light implausible: No
17178 - Databus
21630 - No Communications with HVAC Control Module (J301)
U0164 00 [040] - -
Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Mileage: 118006 km
Date: 2022.09.18
Time: 17:19:15
Coolant temperature: 27 °C
Intake air temperature: 32 °C
Ambient air pressure: 980 mbar
Engine: operating status: ES
ECU_STATE: ENG_STOP
Engine oil temperature: 27.0 °C
Time since engine start: 0.0 s
T_ES: 1825 min
Cruise control switch actuation-Main switch: Not operated
Cruise control switch actuation-Set: Not operated
Cruise control switch actuation-Resume: Not operated
Cruise control switch actuation-Status: OK
Cruise control switch actuation-Accelerate: Not operated
Cruise control switch actuation-DELAY: Not operated
Cruise control switch actuation-Cancel: Not operated
Cruise control switch actuation-Main switch hardware: Not operated
Cruise control switch actuation-Coding: plausible
Cruise control switch actuation-Limit function: not selected
Cruise control switch actuation-Limit button: operated
Cruise control switch actuation-Main switch CAN: Not operated
Cruise control switch actuation-Large increment: Not operated
Cruise control switch actuation-Control component verified: Yes
T_AST_SAE: 0 s
19868 - No Communication with Instrument Cluster
U0155 00 [032] - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 118064 km
Date: 2022.09.26
Time: 09:54:43
Voltage terminal 30: 12.187 V
ECU_STATE: ENG_STOP
Engine oil temperature: 84.0 °C
T_ES: 31 min
T_AST_SAE: 0 s
21321 - Implausible Data Received from ABS Control Module
U0415 00 [032] - -
23129 - Implausible Data Received from ABS Control Module
U0415 00 [032] - -
Readiness: 0000 0000
Address 02: Auto Trans (J743) Labels: 0D9-927-770.clb
Part No SW: 0D9 300 012 F HW: 02E 927 770 AQ
Component: DQ250-6F MQB H54 4901
Revision: 06354004 Serial number: TFK01606260141 CVN: 00003E47
Coding: 0014
ASAM Dataset: EV_TCMDQ250021 001001
ROD: EV_TCMDQ250021.rod
VCID: 196FC08C99141CF300D-804C
1 Fault Found:
10683 - No Communication with Instrument Cluster
U0155 00 [008] - -
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Mileage: 118064 km
Date: 2022.09.26
Time: 09:54:43
Address 03: ABS Brakes (J104) Labels: 5Q0-907-379-IPB-V1.clb
Part No SW: 5Q0 614 517 BK HW: 5Q0 614 517 AH
Component: ESC H62 0736
Revision: 00000000 Serial number: 61816000001255
Coding: 43FA6AA1342009738078130781C329C2562C9001C881943C16435052E02903
Shop #: WSC 01383 790 50316
ASAM Dataset: EV_Brake1UDSContiMK100IPB 035019
ROD: EV_Brake1UDSContiMK100IPB_035_VW37.rod
VCID: 7BA3FA047368CEE3B21-802E
4 Faults Found:
8232 - Databus
U1121 00 [008] - Missing Message
[FCAN: Kombi_02 message is not received]
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 223
Mileage: 118064 km
Date: 2022.09.26
Time: 09:54:43
8234 - Databus
[FCAN: Kombi_03 messag is not received]
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 223
Mileage: 118064 km
Date: 2022.09.26
Time: 09:54:43
8236 - Databus
[FCAN: Kombi_01 messagei is not received]
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 223
Mileage: 118064 km
Date: 2022.09.26
Time: 09:54:43
8356 - Databus
U1122 00 [008] - Implausible Message
[FCAN: Klima_11_alt veraltet bit is set]
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 220
Mileage: 118006 km
Date: 2022.09.18
Time: 17:19:18
Address 05: Acc/Start Auth. (J518) Labels:| 5Q0-959-435.clb
Part No SW: 5Q0 959 435 B HW: 5Q0 959 435
Component: VWKESSYMQB 021 0710
Revision: 00021000 Serial number: 0408654643
Coding: 032C0C
ASAM Dataset: EV_KessyHellaMQBAB 002019
ROD: EV_KessyHellaMQBAB_002.rod
VCID: 3B233A0433E80EE3F21-806E
1 Fault Found:
12717572 - Databus
[Ausfall VIN_01 - Botschaft - kein Signal/Kommunikation]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 223
Mileage: 118064 km
Date: 2022.09.26
Time: 09:54:43
Address 08: Auto HVAC (J255) Labels:| 5G0-907-044.clb
Part No SW: 5GM 907 044 C HW: 5GM 907 044 C
Component: Climatronic H04 1601
Revision: 00001K03
Coding: 02020024200100000105000012111402
ASAM Dataset: EV_ACClimaBHBVW37X 006142
ROD: EV_ACClimaBHBVW37X_006_VW37.rod
VCID: 44D141F84E16711B83B-8010
Fresh air blower control module (front):
A/C pressure/coolant temperature sensor:
Air quality sensor:
8 Faults Found:
327943 - Position Sensor for Left Temperature Flap Motor
B1094 15 [008] - Open or Short to Plus
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 220
Voltage terminal 30: 11.8 V
Outside temperature: 63.0 °C
Inside temperature: 0.0 °C
Left temperature flap - actual value: 0.0 %
Left temperature flap - actual value: 238
Temperature door left - Specified value: 24
328199 - Position Sensor for Right Temperature Flap Motor
B1095 15 [008] - Open or Short to Plus
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 220
Right temperature flap: actual value: 0.0 %
Right temperature flap: actual value: 238
Temperature door right - Specified value: 23
329991 - Position Sensor for Defrost Flap Motor
B1098 15 [008] - Open or Short to Plus
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 220
Defroster flap: actual value: 18
Defroster flap: actual value: 0.0 %
Defrost door - Specified value: 23
328967 - Position Sensor for Front Air Distribution Flap Motor
B1099 15 [008] - Open or Short to Plus
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 220
Front air distribution flap: actual value: 237
Front air distribution flap: actual value: 100.0 %
Air distribution door front - Specified value: 23
196866 - Temperature Sensor for Footwell Vent
B1085 15 [008] - Open or Short to Plus
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 220
459011 - Databus
[Steuergerät im Schalttafeleinsatz - kein Signal/Kommunikation]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 223
Mileage: 118064 km
Date: 2022.09.26
Time: 09:54:42
197890 - Temperature Sensor for Evaporator Vent
B108A 15 [008] - Open or Short to Plus
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 220
Refrigerant pressure: 0.0 bar
Compressor current: specified value: 0.000 A
459523 - Databus
U1123 00 [008] - Received Error Message
[Botschaft Dimmung_01 - empfangener Fehlerwert]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 223
Mileage: 118064 km
Date: 2022.09.26
Time: 09:54:43
Address 09: Cent. Elect. (J519) Labels:| 5Q0-937-08X-MV1.clb
Part No SW: 5Q0 937 087 AA HW: 5Q0 937 087 AA
Component: BCM PQ37BOSCH 028 0162
Revision: -------- Serial number: 865813071601H5
Coding: 00511B464041A2F96DE44000001407201800000000000000000000000000
Shop #: WSC 00066 790 00228
ASAM Dataset: EV_BodyContrModul1UDSBosc 015002
ROD: EV_BCMBOSCH_015.rod
VCID: 7AADFF007C52F7EBA97-802E
Wiper motor control module:
Subsystem 1 - Part No SW: 5GM 955 119 HW: 5GM 955 119 Labels: 5QX-955-119-V1.CLB
Component: WWS 160817 043 0581
Serial number: 160822221304
Coding: 0E4DDD
Rain/Light Recognition Sensor:
Subsystem 2 - Part No SW: 5Q0 955 547 B HW: 5Q0 955 547 B Labels: 5Q0-955-547.CLB
Component: RLHS 042 0105
Serial number: S5Y16M07D02H04M18S18
Coding: 00A8DD
Sunroof control module:
Subsystem 3 - Part No SW: 5G0 959 591 A HW: 8V3 959 591 A
Component: J245 PS22.409 H03 0004
Serial number: 0000FST000ZEIPK00000
Coding: 191800
Roof shade control module:
Subsystem 4 - Part No SW: 5G0 959 591 A HW: 8V3 959 591 A
Component: J394 PS22.409 H03 0004
Serial number: 0000FST000ZEKDA00000
Coding: 191800
Humidity sensor: interior:
19 Faults Found:
131586 - Function Restricted due to Insufficient Voltage
U1400 00 [008] - -
539157 - Databus
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 220
Mileage: 118006 km
Date: 2022.09.18
Time: 17:19:19
Terminal 15 status: On
Terminal 50 status: OFF
CAN-Bus_aktiv: On
Status Bremslichtschalter (HW): On
Status Bremslichtschalter (CAN): On
OFF: operated
Position lamps: Not operated
Automatic high beam assist: Not operated
Low beam: Not operated
Parking light left: Not operated
Parking light right: Not operated
last_wakeup: no cause for fault protection
Voltage: 12.2 V
Outside temperature: 31.5 °C
558869 - Databus
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 223
Mileage: 118064 km
Date: 2022.09.26
Time: 09:54:42
CAN-Bus_aktiv: On
Status Bremslichtschalter (HW): OFF
Status Bremslichtschalter (CAN): OFF
OFF: operated
Voltage: 12.2 V
Outside temperature: 20.5 °C
539925 - Databus
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 223
Mileage: 118064 km
Date: 2022.09.26
Time: 09:54:43
CAN-Bus_aktiv: On
OFF: operated
Voltage: 12.2 V
552213 - Databus
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 223
Mileage: 118064 km
Date: 2022.09.26
Time: 09:54:43
CAN-Bus_aktiv: On
OFF: operated
Voltage: 12.2 V
559637 - Databus
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 223
Mileage: 118064 km
Date: 2022.09.26
Time: 09:54:43
CAN-Bus_aktiv: On
OFF: operated
Voltage: 12.2 V
919560 - Light Switch
B126A 29 [136] - Signal Implausible
MIL ON - Intermittent - Confirmed - Tested Since Memory Clear
14858 - Bulb for Right Brake Lamp / Tail Lamp
B133C 15 [008] - Open or Short to Plus
10506 - Bulb for Left Tail Light
B12BE 15 [008] - Open or Short to Plus
Freeze Frame:
Fault Priority: 2
Fault Frequency: 3
Reset counter: 210
Mileage: 117704 km
Date: 2022.09.10
Time: 11:32:02
Terminal 15 status: OFF
CAN-Bus_aktiv: On
OFF: Not operated
Position lamps: operated
Voltage: 12.6 V
Outside temperature: 32.0 °C
5642 - Bulb for Rear Left Turn Signal
B11E9 15 [008] - Open or Short to Plus
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 209
Mileage: 117704 km
Date: 2022.09.10
Time: 11:32:23
CAN-Bus_aktiv: On
OFF: Not operated
Low beam: operated
Voltage: 12.1 V
11530 - Bulb for Right Brake Light
B12C3 15 [008] - Open or Short to Plus
Freeze Frame:
Fault Priority: 1
Fault Frequency: 1
Reset counter: 209
Mileage: 117704 km
Date: 2022.09.10
Time: 11:32:54
CAN-Bus_aktiv: On
OFF: Not operated
Low beam: operated
Voltage: 12.3 V
13834 - Bulb for Right Tail Light 2
B12C1 15 [008] - Open or Short to Plus
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 210
Mileage: 117704 km
Date: 2022.09.10
Time: 11:32:02
CAN-Bus_aktiv: On
OFF: Not operated
Voltage: 12.7 V
2055 - Courtesy Illumination for Switch (Terminal 58xs)
B133E 11 [008] - Short to Ground
13697024 - Component Protection
U1100 00 [008] - No Basic Setting
[KomponentenschutzKeine Grundeinstellung]
Freeze Frame:
Fault Priority: 1
Fault Frequency: 1
Reset counter: 223
Mileage: 118064 km
Date: 2011.01.01
Time: 00:04:03
CAN-Bus_aktiv: On
OFF: operated
Voltage: 12.1 V
15360512 - Component Protection
U1101 00 [008] - Active
Freeze Frame:
Fault Priority: 1
Fault Frequency: 1
Reset counter: 223
Mileage: 118064 km
Date: 2011.01.01
Time: 00:03:47
CAN-Bus_aktiv: On
OFF: operated
Voltage: 12.1 V
204293 - Remote key 1
B1479 54 [008] - Missing Calibration / Basic Setting
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 224
Mileage: 118108 km
Date: 2022.09.26
Time: 18:02:17
CAN-Bus_aktiv: OFF
OFF: operated
last_wakeup: Pin C14 Kessy Weckleitung
Voltage: 12.4 V
Outside temperature: 25.5 °C
204290 - Remote key 1
B1479 18 [008] - Current Too Low
204546 - Remote key 2
B147A 18 [008] - Current Too Low
206085 - Remote Control
B1311 54 [008] - Missing Calibration / Basic Setting
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 223
Mileage: 118064 km
Date: 2011.01.01
Time: 00:04:22
CAN-Bus_aktiv: On
OFF: operated
Voltage: 12.1 V
Address 10: Park/Steer Assist (J791) Labels:| 5Q0-919-298.clb
Part No SW: 5Q0 919 298 K HW: 5Q0 919 298
Component: PARKHILFE PLA H12 0054
Revision: -------- Serial number: 39431618400650
Coding: 0031163011
ASAM Dataset: EV_EPHVA2CAU3700000 003021
ROD: EV_EPHVA2CAU3700000_003.rod
VCID: 47CB56F47F205A03669-8012
5 Faults Found:
13636864 - Databus
[Dimmung - Dimmung_01.DI_KL_58xd - Fehlerspeicher auslesen]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 223
Mileage: 118064 km
Date: 2022.09.26
Time: 09:54:43
12670240 - Databus
[Steuergerät für Schalttafeleinsatz-J285 - Gateway_72.WFS_01_alt - kein Signal/keine Kommunikation]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 223
Mileage: 118064 km
Date: 2022.09.26
Time: 09:54:43
12670209 - Databus
[Steuergerät für Schalttafeleinsatz-J285 - Kombi_01 - kein Signal/keine Kommunikation]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 223
Mileage: 118064 km
Date: 2022.09.26
Time: 09:54:42
12670210 - Databus
[Steuergerät für Schalttafeleinsatz-J285 - Kombi_02 - kein Signal/keine Kommunikation]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 223
Mileage: 118064 km
Date: 2022.09.26
Time: 09:54:43
12670211 - Databus
[Steuergerät für Schalttafeleinsatz-J285 - Kombi_03 - kein Signal/keine Kommunikation]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 223
Mileage: 118064 km
Date: 2022.09.26
Time: 09:54:43
Address 13: Auto Dist. Reg (J428) Labels:| 5Q0-907-572-V2.clb
Part No SW: 5Q0 907 572 G HW: 5Q0 907 572 G
Component: ACC BOSCH MQB H10 0571
Coding: 350000C141FFC428949C8045000016
ASAM Dataset: EV_ACCBOSCHVW416 001005
ROD: EV_ACCBOSCHVW416_001_VW37.rod
10 Faults Found:
2141 - Databus
[FAULT_DIS_FAIL]
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 224
Mileage: 118064 km
Date: 2022.09.26
Time: 09:54:43
Control Module temperature: 25 °C
Voltage terminal 15: 12.0 V
Velocity_vehicle_reference: 0.00 m/s
Longitudinal_acceleration_vehicle_reference: 0.00 m/s²
Status_ACC_System: ACC_reversible_error
2176 - Databus
[FAULT_INFO_CONSTANT_DISPLAY_VARIANT]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 223
Mileage: 0 km
Date: 2011.01.01
Time: 00:00:02
0846 - Databus
[FAULT_LEARNING_PLAUS_BR_REIFENUMFANG]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 223
Mileage: 118064 km
Date: 2011.01.01
Time: 00:04:53
Control Module temperature: 30 °C
Voltage terminal 15: 14.0 V
Status_ACC_System: ACC_irreversible error
2175 - Databus
[FAULT_MISMATCH_CONSTANT_DISPLAY_VARIANT]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 223
Mileage: 118064 km
Date: 2011.01.01
Time: 00:04:52
[FAULT_THP_EC_INVALID_IKA]
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 223
Mileage: 118064 km
Date: 2011.01.01
Time: 00:03:50
Control Module temperature: 29 °C
1080 - Databus
[FAULT_TIMEOUT_KOMBI_01]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 223
Mileage: 118064 km
Date: 2022.09.26
Time: 09:54:43
Status_ACC_System: ACC_Off_MainSwitch_Off
1227 - Databus
[FAULT_TIMEOUT_KOMBI_03]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 223
Mileage: 118064 km
Date: 2022.09.26
Time: 09:54:43
1127 - Databus
[FAULT_TIMEOUT_PSD_04]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
Reset counter: 224
Mileage: 118108 km
Date: 2022.09.27
Time: 11:54:38
Control Module temperature: 34 °C
Status_ACC_System: ACC_StandBy
1218 - Databus
[FAULT_TIMEOUT_PSD_05]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
Reset counter: 224
Mileage: 118108 km
Date: 2022.09.27
Time: 11:54:38
1219 - Databus
[FAULT_TIMEOUT_PSD_06]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
Reset counter: 224
Mileage: 118108 km
Date: 2022.09.27
Time: 11:54:38
Address 15: Airbags (J234) Labels:| 5Q0-959-655.clb
Part No SW: 5Q0 959 655 J HW: 5Q0 959 655 J
Component: AirbagVW20 010 0830
Serial number: 003GCR05AT4K
Coding: 8CCCFC00000000005000001AC24800000065
ASAM Dataset: EV_AirbaVW20SMEVW37X 002144
ROD: EV_AirbaVW20SMEVW37X_VW37.rod
Seat occupied recognition passenger side:
Subsystem 1 - Part No SW: 4M0 959 339 B HW: 4M0 959 339 B
Component: BF-Gewichtss. H13 0022
Serial number: IBH000000000005MZZV2
Coding: 303137
Crash sensor for side airbag: driver side:
Subsystem 2 - Part No SW: ----------- HW: 480 003 006 16
Component: SideSensor_Df 001 0887
Serial number: 35700000000BAB887C1/
Coding: 2D2D2D
Front Passenger's Side Airbag Crash Sensor:
Subsystem 3 - Part No SW: ----------- HW: 480 003 006 16
Component: SideSensor_Pf 001 0887
Serial number: 358000000004CA887C1Z
Coding: 2D2D2D
Rear Side Airbag Crash Sensor (on driver's side):
Subsystem 4 - Part No SW: ----------- HW: 480 402 706 16
Component: SideSensor_Dr 001 6149
Serial number: 35100029B20F1951A26$
Coding: 2D2D2D
Passenger side rear thorax airbag crash sensor:
Subsystem 5 - Part No SW: ----------- HW: 480 402 706 16
Component: SideSensor_Pr 001 6149
Serial number: 3520002B920FC741E157
Coding: 2D2D2D
Crash sensor for front airbag: driver side:
Subsystem 6 - Part No SW: ----------- HW: 480 401 807 16
Component: FrontSensor_D 001 6149
Serial number: 3550002BF21160D3139.
Coding: 2D2D2D
Crash sensor for front airbag: front passenger side:
Subsystem 7 - Part No SW: ----------- HW: 480 401 807 16
Component: FrontSensor_P 001 6149
Serial number: 3560002C121160D500ES
Coding: 2D2D2D
6 Faults Found:
9483008 - Seat Occupied Recognition
B10B3 00 [008] - Function Restriction due to Implausible Message(s)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 223
Mileage: 0 km
Date: 2011.01.01
Time: 00:00:16
[ATP Wrong IKA]
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 118064 km
Date: 2011.01.01
Time: 00:03:47
1054976 - Databus
[NWD: 0x6B7 Kombi_02 Timeout]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 223
Mileage: 118064 km
Date: 2022.09.26
Time: 09:54:43
1051904 - Databus
[NWD: 0x30B Kombi_01Timeout]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 223
Mileage: 118064 km
Date: 2022.09.26
Time: 09:54:43
1051136 - Databus
[NWD: 0x6B4 VIN_01 Timeout]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 223
Mileage: 118064 km
Date: 2022.09.26
Time: 09:54:43
1048581 - Databus
[NWD: 0x5F0 Dimmung_01 error value DI_KL_58xd]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 223
Mileage: 118064 km
Date: 2022.09.26
Time: 09:54:43
Address 16: Steering wheel (J524) Labels:| 5Q0-953-549.clb
Part No SW: 5Q0 953 521 BB HW: 5Q0 953 569 A
Component: Lenks.Modul 075 0235
Revision: FF034034 Serial number: 20160714400476
Coding: 0C10
ASAM Dataset: EV_SMLSVALEOMQB 001015
ROD: EV_SMLSVALEOMQB.rod
VCID: 73B3D2245B3886A3EA1-8026
No fault code found.
Address 17: Instruments (J285) Labels:| 5G0-920-XXX-17.clb-SRI3
Part No SW: 5G1 920 791 B HW: 5G1 920 795 B
Component: KOMBI 403 4191
Coding: 0B0D6800CC1C4F040208FF000400000000000000
Shop #: WSC 12345 123 12345
ASAM Dataset: EV_DashBoardVDDMQBAB 009058
ROD: EV_DashBoardVDDMQBAB_009_VW26.rod
VCID: 2B030A44C3889E63621-807E
14 Faults Found:
13636608 - Control Module Incorrectly Coded
U1014 00 [009] - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 183
Mileage: 0 km
Date: 2011.01.01
Time: 00:00:00
16777020 - Function Restricted due to Interrupted Communications
U1110 00 [008] - -
[BAP_TEL_0x28 keine Kommunikation]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 4
Reset counter: 225
Mileage: 118108 km
Date: 2022.09.26
Time: 17:20:15
9453074 - Fuel Level Sensor 1
B103E 1B [008] - Resistance Too High
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 240
Date: 2000.00.00
Time: 00:00:00
9459739 - Fuel Level Sensor 2
B1058 1B [008] - Resistance Too High
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 240
Date: 2000.00.00
Time: 00:00:00
[Komponentenschutz keine oder falsche Grundeinstellung bzw. Adaption]
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 223
15361024 - Component Protection
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 223
Date: 2000.00.00
Time: 00:00:00
16776962 - Databus
[Airbag_01 keine Kommunikation]
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 223
Date: 2000.00.00
Time: 00:00:00
16776968 - Databus
[ESP_24 keine Kommunikation]
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 223
Date: 2000.00.00
Time: 00:00:00
16776971 - Databus
[Motor_04 keine Kommunikation]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 223
Date: 2000.00.00
Time: 00:00:00
16776982 - Databus
U1121 00 [009] - Missing Message
[SWA_01 keine Kommunikation]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 184
Mileage: 118108 km
Date: 2022.09.26
Time: 17:24:11
16776988 - Databus
[TSK_07 keine Kommunikation]
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 223
Date: 2000.00.00
Time: 00:00:00
9456433 - Key
B104B 31 [008] - No Signal
Freeze Frame:
Fault Priority: 1
Fault Frequency: 1
Reset counter: 223
Date: 2000.00.00
Time: 00:00:00
16777001 - Databus
[Personalisierung_01 keine Kommunikation]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 223
Date: 2000.00.00
Time: 00:00:00
16777034 - Function Restricted due to Interrupted Communications
U1110 00 [008] - -
[BAP_DoorLocking_0x0D keine Kommunikation]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 223
Date: 2000.00.00
Time: 00:00:00
Address 19: CAN Gateway (J533) Labels:| 5Q0-907-530-V1.clb
Part No SW: 5Q0 907 530 AM HW: 5Q0 907 530 M
Component: GW MQB High 212 2265
Revision: -------- Serial number: 20041610800715
Coding: 0901000830085900FB00221A1E0F00000001050000000000000000000000
Shop #: WSC 131071 1023 2097151
GVL: 01D43C0000000600408C90008000C80000000000000000000000000000000000
ASAM Dataset: EV_GatewConti 013020
ROD: EV_GatewConti_013.rod
VCID: 7CA1F9187666C9DBBBB-8028
Generator:
Multifunction steering wheel control module:
Subsystem 2 - Part No SW: 5G0 959 442 AE HW: 5G0 959 442 AE Labels: 3C8-959-537.CLB
Component: E221__MFL-MD9 H12 0052
Serial number: 29190001732830089305
Coding: 2DFFFF
Inverter for electrical outlet:
Subsystem 3 - Part No SW: 5Q0 907 155 A HW: 5Q0 907 155 A
Component: WECHSELRICHTE H53 0041
Serial number: 0096243
5 Faults Found:
131604 - No Communication with Instrument Cluster
U0155 00 [008] - -
[Timeout Knoten 0x14 / 17 - Steuergerät für Schalttafeleinsatz]
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 223
Mileage: 118064 km
Date: 2022.09.26
Time: 09:54:43
Terminal 30 power supply: 12.1 V
Terminal 15: On
131654 - No Communications with HVAC Control Module (J301)
U0164 00 [008] - -
[Timeout Knoten 0x46 / 08 - Steuergerät für Klima]
Freeze Frame:
Fault Priority: 2
Fault Frequency: 6
Reset counter: 220
Mileage: 118006 km
Date: 2022.09.18
Time: 17:19:03
Terminal 30 power supply: 12.3 V
Terminal 15: OFF
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 223
Mileage: 118064 km
Date: 2011.01.01
Time: 00:03:41
Terminal 30 power supply: 12.0 V
Terminal 15: On
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 223
Mileage: 118064 km
Date: 2011.01.01
Time: 00:03:47
Terminal 15: On
15360768 - Component Protection
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 223
Mileage: 118064 km
Date: 2011.01.01
Time: 00:03:42
Terminal 15: On
Address 22: AWD (J492) Labels:* 0CQ-907-554.clb
Part No SW: 0CQ 907 554 H HW: 0CQ 525 130
Component: Haldex4Motion H52 7083
Serial number: HA1-00021.05.16
Coding: 0001
ASAM Dataset: EV_AllWheelContrHA1VW37X 004013
ROD: EV_AllWheelContrHA1VW37X_004.rod
VCID: 4ACD6FC06C32A76B797-801E
2 Faults Found:
16654 - Databus
[Kombi - TO -- Kombi_01]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 223
Mileage: 118064 km
Date: 2022.09.26
Time: 09:54:42
17466 - Databus
[Kombi - TO -- Kombi_02]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 223
Mileage: 118064 km
Date: 2022.09.26
Time: 09:54:43
Address 2B: Steer. Col. Lock (J764) Labels:* 5Q0-905-861.clb
Part No SW: 5Q0 905 861 A HW: 5Q0 905 861 A
Component: ELV-MQBA H01 0120
Revision: 00000000 Serial number: 16000117722002
Coding: 5D00000000000000
Shop #: WSC 00066 790 07025
ASAM Dataset: EV_ELVMarquMQB 004111
ROD: EV_ELVMarquMQB.rod
VCID: 343111381EB6C19B33B-8060
1 Fault Found:
12670208 - Databus
[Timeout Message WFS_01]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 223
Mileage: 118064 km
Date: 2022.09.26
Time: 09:54:42
ELV State: 04
Information Clamps: 77 60
CoCo State: A0 01
WFS State: 17 06
Vehicle speed: 0.00 km/h
Voltage: 69
AD-Value H-bridge: 33
Clamp15 flip flop: SSTx: button contacts: 06
CAN signals: 00
Address 42: Door Elect, Driver (J386) Labels:| 5QX-959-X93-42.clb
Part No SW: 5Q0 959 593 E HW: 5Q0 959 593 B
Component: TSG FS 020 0041
Serial number: 28071606050B0E
Coding: 003F1320DC00020000000000
ASAM Dataset: EV_DCUDriveSideEWMAXKLO 006003
ROD: EV_DCUDriveSideEWMAXCONT.rod
VCID: 43D342E44B187623BA1-8016
Rear Driver Side Door Control Module:
Subsystem 1 - Part No SW: 5Q4 959 811 D HW: 5Q4 959 811 D Labels: 5QX-959-81X-V1.CLB
Component: Fond FHSG DRV 007 0002
Serial number: 00000000000013355841
Coding: 011000
1 Fault Found:
458794 - Databus
[Kombi_02 Datenbus fehlende Botschaft]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 223
Mileage: 118064 km
Date: 2022.09.26
Time: 09:54:43
Address 44: Steering Assist (J500) Labels:| 5Q0-909-144.clb
Part No SW: 5Q0 909 144 T HW: 5Q0 909 144 R
Component: EPS_MQB_ZFLS 129 1072
Coding: 9302
ASAM Dataset: EV_SteerAssisMQB 013144
ROD: EV_SteerAssisMQB_013.rod
2 Faults Found:
22016 - Databus
[KFC_KOMBI_01 Botschaft - CAN-Timeout]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 223
Mileage: 118064 km
Date: 2022.09.26
Time: 09:54:43
Motor status: 00
System status: Waiting for start request
Supply voltage: 12.00 V
Temperature: 33.0 °C
KFC: 56
KFA: 00 00
Freeze frame conditions: 20
uAdSensI_U1V2Filtered_gdu16: 1.20 V
uAdSensI_U5VFiltered_xdu16: 0.00000 V
uioUdNotFilt_xdu16: 12.20 V
uAdSensI_SwitchedKl30_xdu16: 12.24 V
NoInitCause_AsicSens: [0x00] ASC_CTRL_SAS_NO_ERR
NoInitCause_RackPos_Rohwert: 00 00
RP_VALCNTSAV: not activated
RP_DIAGJOB: not activated
RP_RPS: not activated
RP_KMN_RACKPOS_SET: not activated
RP_STARTUP: not activated
RP_L2PLAUSI: not activated
RP_INDEXPLAUSI: not activated
RP_WHLSPDPLAUSI: not activated
RP_RUKUCNTR: not activated
RP_UNDERVOLT: not activated
RP_CNTERR: not activated
24064 - Databus
[VIN_01 Botschaft - CAN-Timeout]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 223
Mileage: 118064 km
Date: 2022.09.26
Time: 09:54:43
Motor status: 00
KFC: 5E
KFA: 00 00
Freeze frame conditions: 21
uioUdNotFilt_xdu16: 12.23 V
Address 47: Sound System (J525) Labels:| 5Q0-035-456.clb
Part No SW: 5Q0 035 456 HW: 5Q0 035 456
Component: MIB2_lite_amp H20 0150
Revision: 00000001 Serial number: VWZ8Z1GBA02277P
Coding: 2200000000AAAAAA000000000000
ASAM Dataset: EV_AMPMst12C1Gen2ALPI 001003
ROD: EV_AMPMst12C1Gen2ALPI.rod
VCID: 6D87C45C3D1C50533C5-8038
2 Faults Found:
[Anti-theft protection - component protection active (0xEA6200)]
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 223
Mileage: 118064 km
Date: 2011.01.01
Time: 00:03:48
Voltage terminal 30: 12.1 V
6693 - Databus
[Functional restriction due to missing message]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 6
Reset counter: 220
Mileage: 118006 km
Date: 2022.09.18
Time: 17:19:19
Address 52: Door Elect, Pass. (J387) Labels:| 5QX-959-X92-52.clb
Part No SW: 5Q0 959 592 E HW: 5Q0 959 592 B
Component: TSG BFS 020 0041
Serial number: 050816060503LO
ASAM Dataset: EV_DCUPasseSideEWMAXKLO 006003
ROD: EV_DCUPasseSideEWMAXCONT.rod
VCID: 42DD47E054027F2BB17-8016
Rear Passenger Door Control Module:
Subsystem 1 - Part No SW: 5Q4 959 812 D HW: 5Q4 959 812 D Labels: 5QX-959-81X-V1.CLB
Component: Fond FHSG PSG 007 0002
Serial number: 00000000000013346971
Coding: 091000
1 Fault Found:
458794 - Databus
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 223
Mileage: 118064 km
Date: 2022.09.26
Time: 09:54:43
Address 55: Headlight Range (J745) Labels:| 7P6-907-357.clb
Part No SW: 7P6 907 357 D HW: 7P6 907 357 A
Component: AFS-ECU H07 0090
Revision: -------- Serial number: --------------
Coding: 062A00003F000400
ASAM Dataset: EV_HeadlRegulVWAFSMQB 001120
ROD: EV_HeadlRegulVWAFSMQB.rod
VCID: 40D94DE85A0E6D3BA73-8014
Left Headlamp Power Output Stage:
Subsystem 1 - Part No SW: 5N0 941 329 HW: 5N0 941 329 Labels: 3D0-941-329.CLB
Component: LeiMo links H01 0004
Coding: 2E0000
Right Headlamp Power Output Stage:
Subsystem 2 - Part No SW: 5N0 941 329 HW: 5N0 941 329 Labels: 3D0-941-329.CLB
Component: LeiMo rechts H01 0004
Coding: 2E0000
1 Fault Found:
13705477 - Databus
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 223
Mileage: 118064 km
Date: 2022.09.26
Time: 09:54:43
Address 5F: Information Electr. (J794) Labels:| 5G0-035-MIB-STD2.clb
Part No SW: 3Q0 035 876 A HW: 3Q0 035 876 A
Component: MU-S-NS-US 840 0753
Serial number:
Coding: 02730202000000005122000200180A001F0108F401200000C6
ASAM Dataset: EV_MUStd4CDELP 001001
ROD: EV_MUStd4CDELP_VW26.rod
VCID: 323D1720E4A2CFAB217-8066
Display and control head 1 for information electronics:
Subsystem 1 - Part No SW: 5G0 919 606 HW: 5G0 919 606
Component: ABT_High H62 0031
Serial number: VWZ8Z9PU300151
Data carrier:
Subsystem 2 - Part No SW: 3G0 919 866 AC HW: -----------
Component: NAR 2016/17 --- 0445
Serial number: --------------------
18 Faults Found:
1555 - Check Software Version Management
B201A 00 [009] - -
[Check software version management]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 14
Reset counter: 185
Mileage: 0 km
Date: 2011.01.01
Time: 00:00:09
Status_Software_Version_Management-module_name: C
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 223
Mileage: 118064 km
Date: 2011.01.01
Time: 00:03:48
0020 - Tuner for Satellite Radio
B11CF 53 [009] - Deactivated
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 15
Mileage: 100442 km
Date: 2021.11.24
Time: 15:12:34
Voltage terminal 30: 14.4 V
SDARS_tuner_status_2-Satellite radio antenna status: electrically OK
SDARS_tuner_status_2-Channel selection for satellite radio: 0
SDARS_tuner_status_2-Audio Signal: available.
SDARS_tuner_status_2-Antenna current: 136 mA
SDARS_tuner_status_2-Reception quality: optimum_signal
SDARS_tuner_status_2-Satellite radio tuner: pre-activation status: 07
SDARS_tuner_status_2-Satellite radio tuner: pre-activation value: 07
0007 - Connection between Antenna Amp 1 for Radio and Antenna
B1272 13 [009] - Open Circuit
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 8
Mileage: 110292 km
Date: 2022.04.24
Time: 12:37:45
Voltage terminal 30: 11.1 V
Status of antenna 1 for radio-Antenna current: 0 mA
Status of antenna 1 for radio-Connection between radio and antenna amplifier: electrically OK
Status of antenna 1 for radio-Connection between antenna amplifier and antenna: Open circuit
Status of antenna 1 for radio-Reception level antenna 1: 222 dBµV
6706 - Databus
[Instrument cluster: no communication]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 223
Mileage: 118064 km
Date: 2022.09.26
Time: 09:54:43
Network diagnosis-Status: Enabled
6714 - Databus
[VIN: no communication]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 223
Mileage: 118064 km
Date: 2022.09.26
Time: 09:54:43
6666 - Optical data bus
U1049 00 [008] - Open circuit
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 223
Mileage: 118064 km
Date: 2022.09.26
Time: 08:54:25
Voltage terminal 30: 12.7 V
System_Temperature_Sensor_6-max.value: -50 °C
System_Temperature_Sensor_6-min.value: -4 °C
System_Temperature_Sensor_6-Up-to-date: 43 °C
6698 - Optical data bus
[Optical data bus: open circuit: wakeup]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 223
Mileage: 118064 km
Date: 2022.09.26
Time: 08:54:58
6669 - Optical Data Bus for Digital Sound System
U10CC 00 [008] - Intermittent Disruption
[Optical data bus: sporadic open circuit in sound]
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 223
Mileage: 0 km
Date: 2011.01.01
Time: 00:00:23
System_Temperature_Sensor_6-Up-to-date: 39 °C
6927 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
[Trip computer setup (0x0F) - function restriction due to communication error - BapErr_timeout: heartbeat]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 223
Mileage: 118064 km
Date: 2022.09.26
Time: 09:54:43
6929 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
[Time/date (0x11) - function restriction due to communication error - BapErr_timeout: heartbeat]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 223
Mileage: 118064 km
Date: 2022.09.26
Time: 09:54:43
6930 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
[Service interval display + oil level display (0x12) - function restriction due to communication error - BapErr_timeout: heartbeat]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 223
Mileage: 118064 km
Date: 2022.09.26
Time: 09:54:43
6931 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
[Central unit master (0x13) - function restriction due to communication error - BapErr_timeout: heartbeat]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 223
Mileage: 118064 km
Date: 2022.09.26
Time: 09:54:43
7169 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
[A/C system (0x01) - function restriction due to communication error - BapErr_retry not successful]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 220
Mileage: 118006 km
Date: 2022.09.18
Time: 17:19:40
BAP-BAP_Function_ID: 02
7183 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
[Trip computer setup (0x0F) - function restriction due to communication error - BapErr_retry not successful]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 223
Mileage: 118064 km
Date: 2022.09.26
Time: 09:54:43
7185 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
[Time/date (0x11) - function restriction due to communication error - BapErr_retry not successful]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 223
Mileage: 118064 km
Date: 2022.09.26
Time: 09:54:43
7186 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
[Service interval display + oil level display (0x12) - function restriction due to communication error - BapErr_retry not successful]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 223
Mileage: 118064 km
Date: 2022.09.26
Time: 09:54:43
7187 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
[Central unit master (0x13) - function restriction due to communication error - BapErr_retry not successful]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 223
Mileage: 118064 km
Date: 2022.09.26
Time: 09:54:43
Address 75: Telematics (J949) Labels:| 5QE-035-285.clb
Part No SW: 5QE 035 285 A HW: 5QE 035 285 A
Component: OCULowMQBUS 007 0568
Coding: 02730202C2823A017F1E06020000
ASAM Dataset: EV_OCULowMQB 001006
ROD: EV_OCULowMQB.rod
3 Faults Found:
12670208 - Databus
[CAN TO instrument cluster]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 223
Mileage: 118064 km
Date: 2022.09.26
Time: 09:54:43
6912 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
[Uhrzeit (0x11) - BapErr_Timeout Heartbeat]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 223
Mileage: 118064 km
Date: 2022.09.26
Time: 09:54:43
6914 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
[Bordcomputer-Setup (0x0F) - BapErr_Timeout Heartbeat]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 223
Mileage: 118064 km
Date: 2022.09.26
Time: 09:54:43
Address A5: Frt Sens. Drv. Assist (R242) Labels:| 3Q0-980-65X-A5.clb
Part No SW: 3Q0 980 654 G HW: 3Q0 980 654
Component: MQB_B_MFK H06 0231
Serial number: 30061611P10217
Coding: 000307020002020100221344C040490094000E100020
ASAM Dataset: EV_MFKBoschMQBB 001001
ROD: EV_MFKBoschMQBB_001_VW36.rod
4 Faults Found:
1123381 - Databus
[TIMEOUT_Einheiten_01]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 223
Mileage: 118064 km
Date: 2022.09.26
Time: 09:54:43
Control Module temperature: 27 °C
System run time: 10.5 s
mid: 01 C0
Status of camera: limited
Engine_Running_Info: 0
Software_Info_4: 1
Software_Info_3: 3
Software_Info_2: 2
Software_Info_1: 0
1122612 - Databus
[TIMEOUT_Kombi_01]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 223
Mileage: 118064 km
Date: 2022.09.26
Time: 09:54:43
System run time: 6.5 s
mid: 01 D7
Status of camera: operational
Software_Info_4: 1
Software_Info_3: 3
Software_Info_2: 2
Software_Info_1: 0
1122664 - Databus
[TIMEOUT_PSD_04]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
Reset counter: 224
Mileage: 118108 km
Date: 2022.09.27
Time: 11:54:38
Outside temperature: 21.0 °C
System run time: 241.0 s
Voltage terminal 15: 11.9 V
mid: 01 F8
Software_Info_4: 1
Software_Info_3: 3
Software_Info_2: 2
Software_Info_1: 0
1275 - Front Sensors for Driver Assist
B182E F0 [024] - Function Restriction due to Environmental Influences
Intermittent - Confirmed - Not Tested Since Memory Clear
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 213
Mileage: 97582 km
Date: 2021.10.11
Time: 15:41:01
Control Module temperature: 47 °C
Outside temperature: 29.5 °C
Vehicle speed: 26.83 km/h
System run time: 384.9 s
Voltage terminal 15: 13.6 V
mid: 01 62
Engine_Running_Info: 1
Software_Info_4: 1
Software_Info_3: 3
Software_Info_2: 2
Software_Info_1: 0
End----------(Elapsed Time: 02:07, VBatt start/end: 12.5V/12.5V)-----------
I would be... hesitant... to follow any advice from Eurozone Tuning regarding coding. In my case they answered questions (some correctly, some incorrectly) but when they didn't have an answer they stopped responding to my emails. Although they did update their website to reflect the information gained from my line of questions regarding a part they were selling. Also curious their retrofit kit is with an "EU/ROW" spec AID instead of one from North America. Not that it will matter, but I expect you now have the symbol for handbrake instead of the word "PARK" showing.
GolfAlltrack
here i tried to attach the 17 module scan
Code:
;SW:5G1-920-791-B   HW:5G1-920-795-B ---  Instruments
;Component:KOMBI         403 4191     Coding:0B0D6800CC1C4F040208FF000400000000000000
;EV_DashBoardVDDMQBAB    9058    EV_DashBoardVDDMQBAB_009_VW26.rod
;Tuesday    27    September    2022    19:32:24:56035
;VCDS Version: Release 22.9.0 (x64)  Data version: 20220830 DS341.0
;VCID: 2B030A44C3889E63621-807E
IDE00295-Oil temperature display    On     1
IDE00301-Mileage    118144 km    3
IDE00342-ESI: Resetting ESI    no warning     1
IDE00343-Language variant    US English     1
IDE00345-MAS00234-MFA3-Reset-MFI button RESET / OK    Manual reset: not possible     3
IDE00345-MAS05463-MFA3-Reset-Refuel detection gasoline / diesel    MFA3-Reset     3
IDE00345-MAS05464-MFA3-Reset-Refuel detection gas    MFA3-Reset     3
IDE00345-MAS12879-MFA3-Reset-Electrical refueling detection    MFA3-Reset     3
IDE00499-Display correction of consumptions and operating range    100%    1
IDE00500-Hour    19 H    1
IDE00501-Minute    32 min    1
IDE00502-Year    2022 yr    2
IDE00503-Month    9 Months    1
IDE00504-Day    27 d    1
IDE00510-ESI: distance driven from inspection    4626 km    3
IDE00511-ESI: time from inspection    122 d    2
IDE00512-ESI: minimum value km-driving distance/inspection    15000 km    2
IDE00513-ESI: maximum value km-driving distance/inspection    30000 km    2
IDE00514-ESI: maximum value of time between inspections    730 d    2
IDE00515-ESI: oil quality    poor oil quality     1
IDE00517-ESI: soot entry    0 km    2
IDE00518-ESI: thermal load    100 km    2
IDE00819-Day counter    2218 d    2
IDE00820-Activating and deactivating all development messages    not active     1
IDE00827-ESI: minimum value of time between inspections    365 d    2
IDE01153-SIA: maximum value of distance to service    16100 km    2
IDE01154-SIA: maximum value of time to service    365 d    2
IDE02489-Display depiction    Variant 3     1
IDE02818-IDE02689-Offset for tank calibration values-Complete tank calibration    -12.8 l    5
IDE02818-MAS02376-Offset for tank calibration values-Offset sensor 1    -12.8 l    5
IDE02818-MAS02377-Offset for tank calibration values-Offset sensor 2    -12.8 l    5
IDE02818-MAS02378-Offset for tank calibration values-Offset sensor 3    12.7 l    5
IDE02818-MAS02379-Offset for tank calibration values-Offset sensor 4    12.7 l    5
IDE03329-Driving profiled for range remaining    8.5 l/100km    2
IDE03346-IDE00301-Units adjusted-Mileage    miles     3
IDE03346-MAS01230-Units adjusted-Date    dd_mm_yy     3
IDE03346-MAS01456-Units adjusted-Speed    Miles per hour     3
IDE03346-MAS02201-Units adjusted-Temperature    Degrees Fahrenheit     3
IDE03346-MAS02957-Units adjusted-Time    24h     3
IDE03346-MAS03032-Units adjusted-Volume    gallons (US)     3
IDE03346-MAS03034-Units adjusted-Pressure    psi     3
IDE03346-MAS05637-Units adjusted-Operating range consumption: CNG (compressed natural gas)    kg per 100 km     3
IDE03346-MAS05638-Units adjusted-Consumption gasoline / diesel - LPG (liquefied petroleum gas)    Miles per gallon (US)     3
IDE03346-MAS05875-Units adjusted-Average consumption: electric drive    kWh per 100 km     3
IDE03346-MAS13665-Units adjusted-Trailer/support load ground    kilogram (kg)     3
IDE03348-MAS01456-Speed warning-Speed    0    2
IDE03348-MAS01561-Speed warning-Unit    Miles per hour     2
IDE03348-Speed warning-    not active     2
IDE03349-FIX:Max. distance driven until next mileage-related inspection    30000 km    2
IDE03350-FIX: Maximum time until next time-dependent inspection    730 d    2
IDE03351-FIX: Distance covered since last mileage-dependent inspection    25100 km    2
IDE03352-FIX: Time since last time-dependent inspection    448 d    2
IDE03372-Source for synchronization of time    GPS     1
IDE03568-ENG119828-Service-key settings-p_deactivate_SK_Function    On     5
IDE03568-ENG99943-Service-key settings-p_forcewrite_qual_time    10 s    5
IDE03568-ENG119827-Service-key settings-p_main_switch_Basic    On     5
IDE03568-ENG102414-Service-key settings-p_main_switch_keyless    On     5
IDE03568-ENG102611-Service-key settings-p_write_delay_speed    20 km/h    5
IDE03568-ENG103545-Service-key settings-p_write_delay_time    40 s    5
IDE03568-ENG104099-Service-key settings-p_write_distance    20 km    5
IDE03867-Deactivate seat belt warning    No     1
IDE05930-Service notification in days    30 d    1
IDE05931-FIX: Reset value for next mileage-dependent inspection    32200 km    2
IDE05932-FIX: Reset value for next time-dependent inspections    730 d    2
IDE05971-Vehicle Positioning System Interface Control Module    not installed     1
IDE06425-Dynamometer mode: functional    not activated     1
IDE06588-Ignition active message: actuator    Driver door     1
IDE06922-No-voltage display    No display     1
IDE07221-Cylinder shut-off    Readout     1
IDE11086-Service notification    30 d    1
IDE11932-MAS01877-Display of colour adjustment-Red    0    3
IDE11932-MAS01878-Display of colour adjustment-Green    0    3
IDE11932-MAS01879-Display of colour adjustment-Blue    0    3
IDE12226-MAS03686-Display of longitudinal regulation coordinator-Automatic distance regulation    not active     1
IDE12226-MAS05203-Display of longitudinal regulation coordinator-CCS    not active     1
IDE12226-MAS10720-Display of longitudinal regulation coordinator-Speed limiter    not active     1
IDE14220-Vehicle speed warning for India-    No     1
IDE14220-Vehicle speed warning for India-    0 s    1
MAS03555-Lap counter    No display     1
ENG117917-BAP_Debug_Mode_Release    not_released     1
ENG119877-ENG98401-Configuration of Development CAN-Messages-Block 1    OFF     20
ENG119877-ENG98402-Configuration of Development CAN-Messages-Block 10    OFF     20
ENG119877-ENG98445-Configuration of Development CAN-Messages-Block 11    OFF     20
ENG119877-ENG98403-Configuration of Development CAN-Messages-Block 12    OFF     20
ENG119877-ENG98446-Configuration of Development CAN-Messages-Block 13    OFF     20
ENG119877-ENG98447-Configuration of Development CAN-Messages-Block 14    OFF     20
ENG119877-ENG98448-Configuration of Development CAN-Messages-Block 15    OFF     20
ENG119877-ENG98404-Configuration of Development CAN-Messages-Block 16    OFF     20
ENG119877-ENG98449-Configuration of Development CAN-Messages-Block 17    OFF     20
ENG119877-ENG98450-Configuration of Development CAN-Messages-Block 18    OFF     20
ENG119877-ENG98451-Configuration of Development CAN-Messages-Block 19    OFF     20
ENG119877-ENG98452-Configuration of Development CAN-Messages-Block 2    OFF     20
ENG119877-ENG98405-Configuration of Development CAN-Messages-Block 20    OFF     20
ENG119877-ENG98453-Configuration of Development CAN-Messages-Block 21    OFF     20
ENG119877-ENG98406-Configuration of Development CAN-Messages-Block 22    OFF     20
ENG119877-ENG98454-Configuration of Development CAN-Messages-Block 23    OFF     20
ENG119877-ENG98455-Configuration of Development CAN-Messages-Block 24    OFF     20
ENG119877-ENG98456-Configuration of Development CAN-Messages-Block 25    OFF     20
ENG119877-ENG98407-Configuration of Development CAN-Messages-Block 26    OFF     20
ENG119877-ENG98457-Configuration of Development CAN-Messages-Block 27    OFF     20
ENG119877-ENG98458-Configuration of Development CAN-Messages-Block 28    OFF     20
ENG119877-ENG98459-Configuration of Development CAN-Messages-Block 29    OFF     20
ENG119877-ENG98408-Configuration of Development CAN-Messages-Block 3    OFF     20
ENG119877-ENG98409-Configuration of Development CAN-Messages-Block 30    OFF     20
ENG119877-ENG125180-Configuration of Development CAN-Messages-Block 31    OFF     20
ENG119877-ENG125181-Configuration of Development CAN-Messages-Block 32    OFF     20
ENG119877-ENG125182-Configuration of Development CAN-Messages-Block 33    OFF     20
ENG119877-ENG125183-Configuration of Development CAN-Messages-Block 34    OFF     20
ENG119877-ENG125184-Configuration of Development CAN-Messages-Block 35    OFF     20
ENG119877-ENG125185-Configuration of Development CAN-Messages-Block 36    OFF     20
ENG119877-ENG125186-Configuration of Development CAN-Messages-Block 37    OFF     20
ENG119877-ENG125187-Configuration of Development CAN-Messages-Block 38    OFF     20
ENG119877-ENG125188-Configuration of Development CAN-Messages-Block 39    OFF     20
ENG119877-ENG98410-Configuration of Development CAN-Messages-Block 4    OFF     20
ENG119877-ENG98460-Configuration of Development CAN-Messages-Block 5    OFF     20
ENG119877-ENG98461-Configuration of Development CAN-Messages-Block 6    OFF     20
ENG119877-ENG98462-Configuration of Development CAN-Messages-Block 7    OFF     20
ENG119877-ENG98411-Configuration of Development CAN-Messages-Block 8    OFF     20
ENG119877-ENG98463-Configuration of Development CAN-Messages-Block 9    OFF     20
ENG119875-defuel_threshold    9 l    1
ENG128744-ENG101574-Dimming_characteristic_curve_adjustment_fpk_indicator_lights-X1    00 00     24
ENG128744-ENG99557-Dimming_characteristic_curve_adjustment_fpk_indicator_lights-X2    00 0A     24
ENG128744-ENG102140-Dimming_characteristic_curve_adjustment_fpk_indicator_lights-X3    00 32     24
ENG128744-ENG102936-Dimming_characteristic_curve_adjustment_fpk_indicator_lights-X4    00 64     24
ENG128744-ENG103548-Dimming_characteristic_curve_adjustment_fpk_indicator_lights-X5    00 96     24
ENG128744-ENG113992-Dimming_characteristic_curve_adjustment_fpk_indicator_lights-X6    00 FD     24
ENG128744-ENG99777-Dimming_characteristic_curve_adjustment_fpk_indicator_lights-Y1    00 32     24
ENG128744-ENG100480-Dimming_characteristic_curve_adjustment_fpk_indicator_lights-Y2    00 32     24
ENG128744-ENG100773-Dimming_characteristic_curve_adjustment_fpk_indicator_lights-Y3    00 78     24
ENG128744-ENG100631-Dimming_characteristic_curve_adjustment_fpk_indicator_lights-Y4    00 E6     24
ENG128744-ENG102174-Dimming_characteristic_curve_adjustment_fpk_indicator_lights-Y5    01 F4     24
ENG128744-ENG113993-Dimming_characteristic_curve_adjustment_fpk_indicator_lights-Y6    03 E8     24
ENG128743-ENG101574-Dimming_characteristic_curve_adjustment_fpk_middle_display_main_field-X1    00 00     24
ENG128743-ENG99557-Dimming_characteristic_curve_adjustment_fpk_middle_display_main_field-X2    00 0A     24
ENG128743-ENG102140-Dimming_characteristic_curve_adjustment_fpk_middle_display_main_field-X3    00 64     24
ENG128743-ENG102936-Dimming_characteristic_curve_adjustment_fpk_middle_display_main_field-X4    00 96     24
ENG128743-ENG103548-Dimming_characteristic_curve_adjustment_fpk_middle_display_main_field-X5    00 DC     24
ENG128743-ENG113992-Dimming_characteristic_curve_adjustment_fpk_middle_display_main_field-X6    00 FD     24
ENG128743-ENG99777-Dimming_characteristic_curve_adjustment_fpk_middle_display_main_field-Y1    00 09     24
ENG128743-ENG100480-Dimming_characteristic_curve_adjustment_fpk_middle_display_main_field-Y2    00 09     24
ENG128743-ENG100773-Dimming_characteristic_curve_adjustment_fpk_middle_display_main_field-Y3    00 50     24
ENG128743-ENG100631-Dimming_characteristic_curve_adjustment_fpk_middle_display_main_field-Y4    01 90     24
ENG128743-ENG102174-Dimming_characteristic_curve_adjustment_fpk_middle_display_main_field-Y5    03 52     24
ENG128743-ENG113993-Dimming_characteristic_curve_adjustment_fpk_middle_display_main_field-Y6    03 E8     24
ENG119878-ENG101574-dimming_characteristic_curve_adjustment_internal_phototransistor-X1    00 00     20
ENG119878-ENG99557-dimming_characteristic_curve_adjustment_internal_phototransistor-X2    00 01     20
ENG119878-ENG102140-dimming_characteristic_curve_adjustment_internal_phototransistor-X3    00 32     20
ENG119878-ENG102936-dimming_characteristic_curve_adjustment_internal_phototransistor-X4    01 2C     20
ENG119878-ENG103548-dimming_characteristic_curve_adjustment_internal_phototransistor-X5    01 F4     20
ENG119878-ENG99777-dimming_characteristic_curve_adjustment_internal_phototransistor-Y1    00 00     20
ENG119878-ENG100480-dimming_characteristic_curve_adjustment_internal_phototransistor-Y2    00 0A     20
ENG119878-ENG100773-dimming_characteristic_curve_adjustment_internal_phototransistor-Y3    00 32     20
ENG119878-ENG100631-dimming_characteristic_curve_adjustment_internal_phototransistor-Y4    00 96     20
ENG119878-ENG102174-dimming_characteristic_curve_adjustment_internal_phototransistor-Y5    00 FD     20
ENG119874-Gas_functionality    not active     1
ENG125906-ENG125912-Illumination_algorithm-Pointer_illumination_algorithim    terminal_58xd_log_bus_parkinglight     1
ENG125906-ENG126396-Illumination_algorithm-Scale_switching_algorithm    parking_light     1
ENG119882-init_fuel_algorithm    No     1
ENG130585-Leaving_warning_delay    1.6 s    1
ENG102605-ENG103211-outside_temperature-p_blocking_time_after_v_bigger_0    15 s    16
ENG102605-ENG100239-outside_temperature-p_ice_warning_entry_temperature    4 °C    16
ENG102605-ENG103023-outside_temperature-p_ice_warning_exit_temperature    6 °C    16
ENG102605-ENG102658-outside_temperature-p_kmt_at_delta    25 °C    16
ENG102605-ENG99866-outside_temperature-p_mileage_after_v_bigger_0    5.0 km    16
ENG102605-ENG103631-outside_temperature-P_speed_threshold    20 km/h    16
ENG102605-ENG99450-outside_temperature-p_storage_time_engine_off    180 min    16
ENG102605-ENG104179-outside_temperature-p_tendency_damping    15 s    16
ENG102605-ENG103335-outside_temperature-p_tendency_threshold    1.0 °C    16
ENG102605-ENG100500-outside_temperature-p_time_constant_pt1    40 s    16
ENG102605-ENG103256-outside_temperature-p_time_constant_slow_damping    2    16
ENG119825-Picture_Upload_Download    not active     1
ENG126396-Scale_switching_algorithm    lowbeam_foglight     1
ENG153765-Second_digital_speed    Readout     1
ENG119876-Service_Key_Clear_All_Counter    Yes     1
ENG130584-Statistic_phev_mileage    5 km    1
ENG109442-ENG119793-time_parameter_display-hmi_t_Dreiter_ms    2.0 s    18
ENG109442-ENG119794-time_parameter_display-hmi_t_dummyMenuTimeout_ms    5 s    18
ENG109442-ENG119802-time_parameter_display-hmi_t_FondGurt    35 s    18
ENG109442-ENG119804-time_parameter_display-hmi_t_FTuerAUF    300 ms    18
ENG109442-ENG119796-time_parameter_display-hmi_t_MenuTimeout_ms    255 s    18
ENG109442-ENG119799-time_parameter_display-hmi_t_NextServiceAnz_ms    5 s    18
ENG109442-ENG119798-time_parameter_display-hmi_t_NextWarning_ms    6 s    18
ENG109442-ENG119805-time_parameter_display-hmi_t_P1Pause_ms    20 s    18
ENG109442-ENG119800-time_parameter_display-hmi_t_P2Pause_ms    900 s    18
ENG109442-ENG119801-time_parameter_display-hmi_t_Quit_ms    10 s    18
ENG109442-ENG119797-time_parameter_display-hmi_t_TWSAnz_ms    3 s    18
ENG109442-ENG119795-time_parameter_display-hmi_t_UhrTimeout_ms    10 s    18
ENG109442-ENG119803-time_parameter_display-hmi_t_USZ    0.20 s    18
ENG109442-ENG119806-time_parameter_display-rollierblockgroesse    3    18
ENG109442-ENG101663-time_parameter_display-tDD15_off    0.15    18
ENG109442-ENG103975-time_parameter_display-tDD15_on    0    18
ENG109442-ENG100026-time_parameter_display-tDDWUP    0    18
ENG112418-ENG112412-total_range_gas-consumption_factor    0    4
ENG112418-ENG112411-total_range_gas-consumption_profile    consumption_profile_calculation     4
ENG112418-ENG112410-total_range_gas-selection_consumption_factor    consumption_factor_CAN     4
ENG112418-ENG99298-total_range_gas-State    not active     4
ENG153766-Tube_version    variant_1     1
Elapsed Time: 00:28
  • adpmap-17-5G1-920-791-B_3VWH17AU5HM507170-20220927-1932.txt
GolfAlltrack
here is the 5F one
Code:
;SW:3Q0-035-876-A   HW:3Q0-035-876-A ---  Information Electr.
;Component:MU-S-NS-US    840 0753     Coding:02730202000000005122000200180A001F0108F401200000C6
;EV_MUStd4CDELP    1001    EV_MUStd4CDELP_VW26.rod
;Tuesday    27    September    2022    19:33:33:56035
;VCID: 323D1720E4A2CFAB217-8066
IDE00001-Production mode    00 00 00     3
IDE00346-Summertime-automatic    manual     1
IDE00758-Base volume of telephone    50%    1
IDE00759-Base volume of speech output    50%    1
IDE00760-Microphone sensitivity    0 dB    1
IDE00769-Call number 1 for info call    FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF     23
IDE00770-Number 1 for roadside assistance    FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF     23
IDE00820-ENG117828-Activating and deactivating all development messages-Infotainment_CAN_Messages    OFF     1
IDE00820-ENG117829-Activating and deactivating all development messages-MIB_CAN_Messages    OFF     1
IDE00845-Wheel circumference    0 mm    2
IDE01996-MAS00076-Installation list: specified installations-Instrument cluster control module    No     3
IDE01996-MAS00839-Installation list: specified installations-TV Tuner    No     3
IDE01996-MAS00844-Installation list: specified installations-Radio    No     3
IDE01996-MAS00847-Installation list: specified installations-Digital Sound System Control Module    Yes     3
IDE01996-MAS00849-Installation list: specified installations-Information electronics control module 1    Yes     3
IDE01996-MAS00850-Installation list: specified installations-Information electronics control module 2    No     3
IDE01996-MAS04300-Installation list: specified installations-DVD changer    No     3
IDE01996-MAS14306-Installation list: specified installations-Windshield projection head up display control module    No     3
IDE01996-SFT271943-Installation list: specified installations-Multimedia system control head    No     3
IDE01996-ENG154341-Installation list: specified installations-Reserved_8    No     3
IDE01996-ENG152491-Installation list: specified installations-Smart Control Carrier 1    No     3
IDE01996-ENG152490-Installation list: specified installations-Smart Control Carrier 2    No     3
IDE01996-ENG152488-Installation list: specified installations-Smart Display Carrier 1    No     3
IDE01996-ENG152492-Installation list: specified installations-Smart Display Carrier 2    No     3
IDE01996-ENG152493-Installation list: specified installations-Wireless Charger 1    No     3
IDE01996-ENG152489-Installation list: specified installations-Wireless Charger 2    No     3
IDE02121-CD eject button    Enabled     1
IDE02122-Developer mode    not activated     1
IDE02330-Call number 2 for info call    FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF     23
IDE02331-Number 2 for roadside assistance    FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF     23
IDE02332-Deactivate production mode    0    3
IDE02476-MAS03001-Electrical test of speakers-Mode    automatic     49
IDE02476-ENG117360-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_1_Test_Frequency    19000 Hz    49
IDE02476-ENG117361-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_1_Test_Volume    27    49
IDE02476-ENG117378-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_10_Test_Frequency    19000 Hz    49
IDE02476-ENG117379-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_10_Test_Volume    27    49
IDE02476-ENG117380-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_11_Test_Frequency    19000 Hz    49
IDE02476-ENG117381-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_11_Test_Volume    27    49
IDE02476-ENG117382-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_12_Test_Frequency    19000 Hz    49
IDE02476-ENG117383-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_12_Test_Volume    27    49
IDE02476-ENG117384-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_13_Test_Frequency    19000 Hz    49
IDE02476-ENG117385-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_13_Test_Volume    27    49
IDE02476-ENG117386-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_14_Test_Frequency    19000 Hz    49
IDE02476-ENG117387-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_14_Test_Volume    27    49
IDE02476-ENG117388-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_15_Test_Frequency    19000 Hz    49
IDE02476-ENG117389-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_15_Test_Volume    27    49
IDE02476-ENG117390-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_16_Test_Frequency    19000 Hz    49
IDE02476-ENG117391-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_16_Test_Volume    27    49
IDE02476-ENG117362-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_2_Test_Frequency    19000 Hz    49
IDE02476-ENG117363-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_2_Test_Volume    27    49
IDE02476-ENG117364-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_3_Test_Frequency    19000 Hz    49
IDE02476-ENG117365-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_3_Test_Volume    27    49
IDE02476-ENG117366-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_4_Test_Frequency    19000 Hz    49
IDE02476-ENG117367-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_4_Test_Volume    27    49
IDE02476-ENG117368-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_5_Test_Frequency    19000 Hz    49
IDE02476-ENG117369-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_5_Test_Volume    27    49
IDE02476-ENG117370-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_6_Test_Frequency    19000 Hz    49
IDE02476-ENG117371-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_6_Test_Volume    27    49
IDE02476-ENG117372-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_7_Test_Frequency    19000 Hz    49
IDE02476-ENG117373-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_7_Test_Volume    27    49
IDE02476-ENG117374-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_8_Test_Frequency    19000 Hz    49
IDE02476-ENG117375-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_8_Test_Volume    27    49
IDE02476-ENG117376-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_9_Test_Frequency    19000 Hz    49
IDE02476-ENG117377-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_9_Test_Volume    27    49
IDE02502-Confirmation of installation change    18 55     2
IDE02607-Wheel pulse    0    2
IDE02699-Number 1 for roadside assistance    FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF     23
IDE02701-Number 1 (roaming) for roadside assistance    FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF     23
IDE03471-ENG117847-Vehicle configuration-advanced_range_display    OFF     30
IDE03471-ENG249824-Vehicle configuration-AliBox    OFF     30
IDE03471-ENG142146-Vehicle configuration-allow_message_editing    OFF     30
IDE03471-ENG130249-Vehicle configuration-Apple_DIO    On     30
IDE03471-ENG185764-Vehicle configuration-Apple_DIO_Wireless    OFF     30
IDE03471-ENG152525-Vehicle configuration-Baidu_Car_Life    OFF     30
IDE03471-ENG152559-Vehicle configuration-Baidu_Car_Life_ios    OFF     30
IDE03471-ENG185765-Vehicle configuration-Baidu_Car_Life_ios_Wireless    OFF     30
IDE03471-ENG185766-Vehicle configuration-Baidu_Car_Life_Wireless    OFF     30
IDE03471-ENG152560-Vehicle configuration-block_hmi_function_p_epb    locked     30
IDE03471-ENG142151-Vehicle configuration-conditioning_variant    0    30
IDE03471-ENG263540-Vehicle configuration-correction_e_mileage    0    30
IDE03471-ENG125043-Vehicle configuration-Dtmf_without_active_call    On     30
IDE03471-ENG142145-Vehicle configuration-esim_data_only_sms_support    OFF     30
IDE03471-ENG185778-Vehicle configuration-FoD    SWaP     30
IDE03471-ENG130248-Vehicle configuration-Google_GAL    On     30
IDE03471-ENG185779-Vehicle configuration-Google_GAL_Wireless    OFF     30
IDE03471-ENG117850-Vehicle configuration-gracenote_local_coverarts    OFF     30
IDE03471-ENG117851-Vehicle configuration-gracenote_local_other    OFF     30
IDE03471-ENG117848-Vehicle configuration-gracenote_online_coverarts    OFF     30
IDE03471-ENG117849-Vehicle configuration-gracenote_online_other    OFF     30
IDE03471-ENG152533-Vehicle configuration-Hybrid_Radio_additional_online_data    not activated     30
IDE03471-ENG152534-Vehicle configuration-Hybrid_Radio_Range_Extender    Deactivated     30
IDE03471-ENG261211-Vehicle configuration-internet_over_WLAN_default_setting    OFF     30
IDE03471-ENG125049-Vehicle configuration-Joker_button_1    not installed     30
IDE03471-ENG125050-Vehicle configuration-Joker_button_2    not installed     30
IDE03471-ENG127492-Vehicle configuration-LGI    OFF     30
IDE03471-ENG130246-Vehicle configuration-LTE_modul    activated     30
IDE03471-ENG142142-Vehicle configuration-map_email_support    OFF     30
IDE03471-ENG142143-Vehicle configuration-map_instant_messaging_support    OFF     30
IDE03471-ENG142141-Vehicle configuration-map_sms_support    OFF     30
IDE03471-ENG142152-Vehicle configuration-Map_Style    0    30
IDE03471-ENG152537-Vehicle configuration-media_control    not activated     30
IDE03471-ENG138662-Vehicle configuration-Mirror_link    On     30
IDE03471-ENG142148-Vehicle configuration-MirrorLink_Country_Code    MIB_EU     30
IDE03471-ENG142150-Vehicle configuration-MirrorLink_RGB_Preference    RGB565     30
IDE03471-ENG117843-Vehicle configuration-my_audi    OFF     30
IDE03471-ENG117845-Vehicle configuration-online_dictation    OFF     30
IDE03471-ENG127495-Vehicle configuration-online_media    OFF     30
IDE03471-ENG117840-Vehicle configuration-online_navigation    OFF     30
IDE03471-ENG117837-Vehicle configuration-online_POI    OFF     30
IDE03471-ENG117838-Vehicle configuration-online_POI_voice    OFF     30
IDE03471-ENG117839-Vehicle configuration-online_portal_browser_services    OFF     30
IDE03471-ENG152553-Vehicle configuration-online_radio    Deactivated     30
IDE03471-ENG117841-Vehicle configuration-online_street_view    OFF     30
IDE03471-ENG125048-Vehicle configuration-OPS_display_in_dash_board_display_unit    OFF     30
IDE03471-ENG167521-Vehicle configuration-perso_v_threshold    0    30
IDE03471-ENG167522-Vehicle configuration-perso_v_threshold_hysteresis    0    30
IDE03471-ENG152554-Vehicle configuration-Phone_HMI_Privacy    0    30
IDE03471-ENG125046-Vehicle configuration-Phone_module_operation_mode    Data & language service active     30
IDE03471-ENG117844-Vehicle configuration-picture_navi    On     30
IDE03471-ENG167523-Vehicle configuration-Pilot_Parking    not activated     30
IDE03471-ENG167525-Vehicle configuration-Popup_if_GPS_services_in_use    not activated     30
IDE03471-ENG152555-Vehicle configuration-Privacy_WithPINRequest    0    30
IDE03471-ENG127496-Vehicle configuration-ProbeCar_lgi    OFF     30
IDE03471-ENG137646-Vehicle configuration-ProbeCar_vzo    OFF     30
IDE03471-ENG125047-Vehicle configuration-PSD_Protocol_Version    PSD_1.5     30
IDE03471-ENG117846-Vehicle configuration-remote_HMI    OFF     30
IDE03471-ENG138661-Vehicle configuration-RSE_software_component    activated     30
IDE03471-ENG245031-Vehicle configuration-rvc_low_black_screen_trunk_open    not activated     30
IDE03471-ENG244966-Vehicle configuration-rvc_low_black_screen_velocity_threshold    not activated     30
IDE03471-ENG245015-Vehicle configuration-rvc_low_failsafe    not activated     30
IDE03471-ENG126143-Vehicle configuration-RVC_video_input    FBAS     30
IDE03471-ENG152556-Vehicle configuration-scon_telephony    not activated     30
IDE03471-ENG142081-Vehicle configuration-sd_slot_deactivation    no restriction     30
IDE03471-ENG138660-Vehicle configuration-SDS_Region_Flag    no_region     30
IDE03471-ENG152557-Vehicle configuration-show_volte_hmi_switch    not activated     30
IDE03471-ENG125045-Vehicle configuration-Sim_card_mode_switch    not installed     30
IDE03471-ENG142144-Vehicle configuration-sim_data_only_sms_support    OFF     30
IDE03471-ENG138663-Vehicle configuration-Smartphone_interface_for_rhmi    activated     30
IDE03471-ENG126993-Vehicle configuration-Station_Logo_DB_Mode    0    30
IDE03471-ENG125044-Vehicle configuration-Support_for_response_and_hold    OFF     30
IDE03471-ENG125042-Vehicle configuration-Support_of_threeway_calling    On     30
IDE03471-ENG130247-Vehicle configuration-Support_second_phone    On     30
IDE03471-ENG167531-Vehicle configuration-Tencent_myCar_canceling_share_location    OFF     30
IDE03471-ENG126994-Vehicle configuration-TPEG_availability    OFF     30
IDE03471-ENG152571-Vehicle configuration-unblock_functions_while_piloted_driving    locked     30
IDE03471-ENG137647-Vehicle configuration-UOTA    OFF     30
IDE03471-ENG167532-Vehicle configuration-UOTA_2    OFF     30
IDE03471-ENG117852-Vehicle configuration-UPnP    OFF     30
IDE03471-ENG142149-Vehicle configuration-vehicle_leaving_sound    not activated     30
IDE03471-ENG142147-Vehicle configuration-vehicle_readiness_sound    not activated     30
IDE03471-ENG152558-Vehicle configuration-voice_over_lte    not activated     30
IDE03471-ENG117836-Vehicle configuration-VZAPro    OFF     30
IDE03471-ENG127494-Vehicle configuration-VZO    OFF     30
IDE03471-ENG137648-Vehicle configuration-WiFi_Client_HMI    OFF     30
IDE03471-ENG117842-Vehicle configuration-WIFI_Hotspot    OFF     30
IDE03471-ENG152572-Vehicle configuration-wlan_5ghz_switch    not activated     30
IDE03902-Automatic ring break diagnostic    No automatic start     1
IDE04295-Bluetooth: Preferred connection profile for phone book data    PBAP     1
IDE04331-Selection of release codes for a SWaP function    FF FF FF FF     4
IDE04521-Sporadic ring break detection    optical     1
IDE04522-Awakening ability on optical databus    OFF     1
IDE04550-Bluetooth: Sniff mode    OFF     1
IDE05111-Fee-based traffic information (TMC)    1537    2
IDE05113-Infotainment Recorder    activated     1
IDE08814-IDE04033-Navigation receiver GNSS configuration-Compass    OFF     1
IDE08814-MAS01570-Navigation receiver GNSS configuration-Default    On     1
IDE08814-MAS02614-Navigation receiver GNSS configuration-GPS    OFF     1
IDE08814-MAS07828-Navigation receiver GNSS configuration-Galileo    OFF     1
IDE08814-MAS07829-Navigation receiver GNSS configuration-Glonass    OFF     1
IDE08814-ENG142047-Navigation receiver GNSS configuration-external_gps_1    OFF     1
IDE08814-ENG142048-Navigation receiver GNSS configuration-external_gps_2    OFF     1
IDE10221-MAS00839-Audio Management Input Gain Generation 2-TV Tuner    -128    40
IDE10221-MAS00846-Audio Management Input Gain Generation 2-Satellite radio    5    40
IDE10221-MAS01984-Audio Management Input Gain Generation 2-Radio (FM)    -128    40
IDE10221-MAS01985-Audio Management Input Gain Generation 2-Radio (AM)    -128    40
IDE10221-MAS01986-Audio Management Input Gain Generation 2-Digital radio (DAB)    -128    40
IDE10221-ENG125854-Audio Management Input Gain Generation 2-Exbox_DMB    -128    40
IDE10221-ENG117430-Audio Management Input Gain Generation 2-HFP    -128    40
IDE10221-ENG125846-Audio Management Input Gain Generation 2-Media_Airplay    -128    40
IDE10221-ENG125837-Audio Management Input Gain Generation 2-Media_AUX_Adapter    -128    40
IDE10221-ENG125836-Audio Management Input Gain Generation 2-Media_AUXIN    -128    40
IDE10221-ENG125843-Audio Management Input Gain Generation 2-Media_Bluray    -128    40
IDE10221-ENG125841-Audio Management Input Gain Generation 2-Media_BTDevice    -128    40
IDE10221-ENG125838-Audio Management Input Gain Generation 2-Media_CDA    -128    40
IDE10221-ENG125848-Audio Management Input Gain Generation 2-Media_Cloud    -128    40
IDE10221-ENG125839-Audio Management Input Gain Generation 2-Media_DVD    -128    40
IDE10221-ENG125844-Audio Management Input Gain Generation 2-Media_HDMI    -128    40
IDE10221-ENG125840-Audio Management Input Gain Generation 2-Media_MFP    -128    40
IDE10221-ENG125847-Audio Management Input Gain Generation 2-Media_UPNP    -128    40
IDE10221-ENG125855-Audio Management Input Gain Generation 2-Mirrorlink    -128    40
IDE10221-ENG125859-Audio Management Input Gain Generation 2-Phone_Ringer_MFP    -128    40
IDE10221-ENG125860-Audio Management Input Gain Generation 2-Phone_Ringer_OB    -3    40
IDE10221-ENG125858-Audio Management Input Gain Generation 2-Phone_Voice    -128    40
IDE10221-ENG125842-Audio Management Input Gain Generation 2-TA_Tuner_FM    -128    40
IDE10221-ENG125850-Audio Management Input Gain Generation 2-Tone_Beep    -128    40
IDE10221-ENG125853-Audio Management Input Gain Generation 2-Tone_Messaging    -128    40
IDE10221-ENG125852-Audio Management Input Gain Generation 2-Tone_Touchscreen    6    40
IDE10221-ENG125851-Audio Management Input Gain Generation 2-Tone_Warning    -128    40
IDE10221-ENG125856-Audio Management Input Gain Generation 2-TTS_Nav    -128    40
IDE10221-ENG125857-Audio Management Input Gain Generation 2-TTS_SDS    -128    40
IDE10221-ENG125845-Audio Management Input Gain Generation 2-Tuner_Online    -128    40
IDE10221-ENG125849-Audio Management Input Gain Generation 2-Tuner_Personal    -128    40
IDE10221-ENG125835-Audio Management Input Gain Generation 2-Tuner_TI    -128    40
IDE10221-ENG125861-Audio Management Input Gain Generation 2-TV_AV_IN    -128    40
IDE10480-MAS10741-Interface for external media: activation-Connection 1    activated     4
IDE10480-MAS10742-Interface for external media: activation-Connection 2    not activated     4
IDE10480-MAS10743-Interface for external media: activation-Connection 3    not activated     4
IDE10480-MAS10744-Interface for external media: activation-Connection 4    not activated     4
IDE10604-Menu entries for mobile online services    not activated     1
IDE11122-Country identification: country of sale HMI    US     2
IDE11502-ENG127601-Locked menu contents-FB_CAR_0    non_blocked     21
IDE11502-ENG127602-Locked menu contents-FB_CAR_1    non_blocked     21
IDE11502-ENG127611-Locked menu contents-FB_CAR_10    non_blocked     21
IDE11502-ENG127612-Locked menu contents-FB_CAR_11    non_blocked     21
IDE11502-ENG127613-Locked menu contents-FB_CAR_12    non_blocked     21
IDE11502-ENG127614-Locked menu contents-FB_CAR_13    non_blocked     21
IDE11502-ENG127615-Locked menu contents-FB_CAR_14    non_blocked     21
IDE11502-ENG127616-Locked menu contents-FB_CAR_15    non_blocked     21
IDE11502-ENG127617-Locked menu contents-FB_CAR_16    non_blocked     21
IDE11502-ENG127618-Locked menu contents-FB_CAR_17    non_blocked     21
IDE11502-ENG127619-Locked menu contents-FB_CAR_18    non_blocked     21
IDE11502-ENG127620-Locked menu contents-FB_CAR_19    non_blocked     21
IDE11502-ENG127603-Locked menu contents-FB_CAR_2    non_blocked     21
IDE11502-ENG127621-Locked menu contents-FB_CAR_20    non_blocked     21
IDE11502-ENG127622-Locked menu contents-FB_CAR_21    non_blocked     21
IDE11502-ENG127623-Locked menu contents-FB_CAR_22    non_blocked     21
IDE11502-ENG127624-Locked menu contents-FB_CAR_23    non_blocked     21
IDE11502-ENG127604-Locked menu contents-FB_CAR_3    non_blocked     21
IDE11502-ENG127605-Locked menu contents-FB_CAR_4    non_blocked     21
IDE11502-ENG127606-Locked menu contents-FB_CAR_5    non_blocked     21
IDE11502-ENG127607-Locked menu contents-FB_CAR_6    non_blocked     21
IDE11502-ENG127608-Locked menu contents-FB_CAR_7    non_blocked     21
IDE11502-ENG127609-Locked menu contents-FB_CAR_8    non_blocked     21
IDE11502-ENG127610-Locked menu contents-FB_CAR_9    non_blocked     21
IDE11502-ENG127521-Locked menu contents-FB_MEDIA_0    non_blocked     21
IDE11502-ENG127522-Locked menu contents-FB_MEDIA_1    non_blocked     21
IDE11502-ENG127531-Locked menu contents-FB_MEDIA_10    non_blocked     21
IDE11502-ENG127532-Locked menu contents-FB_MEDIA_11    non_blocked     21
IDE11502-ENG127533-Locked menu contents-FB_MEDIA_12    non_blocked     21
IDE11502-ENG127534-Locked menu contents-FB_MEDIA_13    non_blocked     21
IDE11502-ENG127535-Locked menu contents-FB_MEDIA_14    non_blocked     21
IDE11502-ENG127536-Locked menu contents-FB_MEDIA_15    non_blocked     21
IDE11502-ENG127537-Locked menu contents-FB_MEDIA_16    non_blocked     21
IDE11502-ENG127538-Locked menu contents-FB_MEDIA_17    non_blocked     21
IDE11502-ENG127539-Locked menu contents-FB_MEDIA_18    non_blocked     21
IDE11502-ENG127540-Locked menu contents-FB_MEDIA_19    non_blocked     21
IDE11502-ENG127523-Locked menu contents-FB_MEDIA_2    non_blocked     21
IDE11502-ENG127541-Locked menu contents-FB_MEDIA_20    non_blocked     21
IDE11502-ENG127542-Locked menu contents-FB_MEDIA_21    non_blocked     21
IDE11502-ENG127543-Locked menu contents-FB_MEDIA_22    non_blocked     21
IDE11502-ENG127544-Locked menu contents-FB_MEDIA_23    non_blocked     21
IDE11502-ENG127524-Locked menu contents-FB_MEDIA_3    non_blocked     21
IDE11502-ENG127525-Locked menu contents-FB_MEDIA_4    non_blocked     21
IDE11502-ENG127526-Locked menu contents-FB_MEDIA_5    non_blocked     21
IDE11502-ENG127527-Locked menu contents-FB_MEDIA_6    non_blocked     21
IDE11502-ENG127528-Locked menu contents-FB_MEDIA_7    non_blocked     21
IDE11502-ENG127529-Locked menu contents-FB_MEDIA_8    non_blocked     21
IDE11502-ENG127530-Locked menu contents-FB_MEDIA_9    non_blocked     21
IDE11502-ENG127625-Locked menu contents-FB_MISC_0    non_blocked     21
IDE11502-ENG127626-Locked menu contents-FB_MISC_1    non_blocked     21
IDE11502-ENG127635-Locked menu contents-FB_MISC_10    non_blocked     21
IDE11502-ENG127636-Locked menu contents-FB_MISC_11    non_blocked     21
IDE11502-ENG127637-Locked menu contents-FB_MISC_12    non_blocked     21
IDE11502-ENG127638-Locked menu contents-FB_MISC_13    non_blocked     21
IDE11502-ENG127639-Locked menu contents-FB_MISC_14    non_blocked     21
IDE11502-ENG127640-Locked menu contents-FB_MISC_15    non_blocked     21
IDE11502-ENG127641-Locked menu contents-FB_MISC_16    non_blocked     21
IDE11502-ENG127642-Locked menu contents-FB_MISC_17    non_blocked     21
IDE11502-ENG127643-Locked menu contents-FB_MISC_18    non_blocked     21
IDE11502-ENG127644-Locked menu contents-FB_MISC_19    non_blocked     21
IDE11502-ENG127627-Locked menu contents-FB_MISC_2    non_blocked     21
IDE11502-ENG127645-Locked menu contents-FB_MISC_20    non_blocked     21
IDE11502-ENG127646-Locked menu contents-FB_MISC_21    non_blocked     21
IDE11502-ENG127647-Locked menu contents-FB_MISC_22    non_blocked     21
IDE11502-ENG127648-Locked menu contents-FB_MISC_23    non_blocked     21
IDE11502-ENG127649-Locked menu contents-FB_MISC_24    non_blocked     21
IDE11502-ENG127650-Locked menu contents-FB_MISC_25    non_blocked     21
IDE11502-ENG127651-Locked menu contents-FB_MISC_26    non_blocked     21
IDE11502-ENG127652-Locked menu contents-FB_MISC_27    non_blocked     21
IDE11502-ENG127653-Locked menu contents-FB_MISC_28    non_blocked     21
IDE11502-ENG127654-Locked menu contents-FB_MISC_29    non_blocked     21
IDE11502-ENG127628-Locked menu contents-FB_MISC_3    non_blocked     21
IDE11502-ENG127655-Locked menu contents-FB_MISC_30    non_blocked     21
IDE11502-ENG127656-Locked menu contents-FB_MISC_31    non_blocked     21
IDE11502-ENG127657-Locked menu contents-FB_MISC_32    non_blocked     21
IDE11502-ENG127658-Locked menu contents-FB_MISC_33    non_blocked     21
IDE11502-ENG127659-Locked menu contents-FB_MISC_34    non_blocked     21
IDE11502-ENG127660-Locked menu contents-FB_MISC_35    non_blocked     21
IDE11502-ENG127661-Locked menu contents-FB_MISC_36    non_blocked     21
IDE11502-ENG127662-Locked menu contents-FB_MISC_37    non_blocked     21
IDE11502-ENG127663-Locked menu contents-FB_MISC_38    non_blocked     21
IDE11502-ENG127664-Locked menu contents-FB_MISC_39    non_blocked     21
IDE11502-ENG127629-Locked menu contents-FB_MISC_4    non_blocked     21
IDE11502-ENG127665-Locked menu contents-FB_MISC_40    non_blocked     21
IDE11502-ENG127666-Locked menu contents-FB_MISC_41    non_blocked     21
IDE11502-ENG127667-Locked menu contents-FB_MISC_42    non_blocked     21
IDE11502-ENG127668-Locked menu contents-FB_MISC_43    non_blocked     21
IDE11502-ENG127669-Locked menu contents-FB_MISC_44    non_blocked     21
IDE11502-ENG127670-Locked menu contents-FB_MISC_45    non_blocked     21
IDE11502-ENG127671-Locked menu contents-FB_MISC_46    non_blocked     21
IDE11502-ENG127672-Locked menu contents-FB_MISC_47    non_blocked     21
IDE11502-ENG127630-Locked menu contents-FB_MISC_5    non_blocked     21
IDE11502-ENG127631-Locked menu contents-FB_MISC_6    non_blocked     21
IDE11502-ENG127632-Locked menu contents-FB_MISC_7    non_blocked     21
IDE11502-ENG127633-Locked menu contents-FB_MISC_8    non_blocked     21
IDE11502-ENG127634-Locked menu contents-FB_MISC_9    non_blocked     21
IDE11502-ENG127561-Locked menu contents-FB_NAV_0    non_blocked     21
IDE11502-ENG127562-Locked menu contents-FB_NAV_1    non_blocked     21
IDE11502-ENG127571-Locked menu contents-FB_NAV_10    non_blocked     21
IDE11502-ENG127572-Locked menu contents-FB_NAV_11    non_blocked     21
IDE11502-ENG127573-Locked menu contents-FB_NAV_12    non_blocked     21
IDE11502-ENG127574-Locked menu contents-FB_NAV_13    non_blocked     21
IDE11502-ENG127575-Locked menu contents-FB_NAV_14    non_blocked     21
IDE11502-ENG127576-Locked menu contents-FB_NAV_15    non_blocked     21
IDE11502-ENG127577-Locked menu contents-FB_NAV_16    non_blocked     21
IDE11502-ENG127578-Locked menu contents-FB_NAV_17    non_blocked     21
IDE11502-ENG127579-Locked menu contents-FB_NAV_18    non_blocked     21
IDE11502-ENG127580-Locked menu contents-FB_NAV_19    non_blocked     21
IDE11502-ENG127563-Locked menu contents-FB_NAV_2    non_blocked     21
IDE11502-ENG127581-Locked menu contents-FB_NAV_20    non_blocked     21
IDE11502-ENG127582-Locked menu contents-FB_NAV_21    non_blocked     21
IDE11502-ENG127583-Locked menu contents-FB_NAV_22    non_blocked     21
IDE11502-ENG127584-Locked menu contents-FB_NAV_23    non_blocked     21
IDE11502-ENG127585-Locked menu contents-FB_NAV_24    non_blocked     21
IDE11502-ENG127586-Locked menu contents-FB_NAV_25    non_blocked     21
IDE11502-ENG127587-Locked menu contents-FB_NAV_26    non_blocked     21
IDE11502-ENG127588-Locked menu contents-FB_NAV_27    non_blocked     21
IDE11502-ENG127589-Locked menu contents-FB_NAV_28    non_blocked     21
IDE11502-ENG127590-Locked menu contents-FB_NAV_29    non_blocked     21
IDE11502-ENG127564-Locked menu contents-FB_NAV_3    non_blocked     21
IDE11502-ENG127591-Locked menu contents-FB_NAV_30    non_blocked     21
IDE11502-ENG127592-Locked menu contents-FB_NAV_31    non_blocked     21
IDE11502-ENG127593-Locked menu contents-FB_NAV_32    non_blocked     21
IDE11502-ENG127594-Locked menu contents-FB_NAV_33    non_blocked     21
IDE11502-ENG127595-Locked menu contents-FB_NAV_34    non_blocked     21
IDE11502-ENG127596-Locked menu contents-FB_NAV_35    non_blocked     21
IDE11502-ENG127597-Locked menu contents-FB_NAV_36    non_blocked     21
IDE11502-ENG127598-Locked menu contents-FB_NAV_37    non_blocked     21
IDE11502-ENG127599-Locked menu contents-FB_NAV_38    non_blocked     21
IDE11502-ENG127600-Locked menu contents-FB_NAV_39    non_blocked     21
IDE11502-ENG127565-Locked menu contents-FB_NAV_4    non_blocked     21
IDE11502-ENG127566-Locked menu contents-FB_NAV_5    non_blocked     21
IDE11502-ENG127567-Locked menu contents-FB_NAV_6    non_blocked     21
IDE11502-ENG127568-Locked menu contents-FB_NAV_7    non_blocked     21
IDE11502-ENG127569-Locked menu contents-FB_NAV_8    non_blocked     21
IDE11502-ENG127570-Locked menu contents-FB_NAV_9    non_blocked     21
IDE11502-ENG127545-Locked menu contents-FB_PHONE_0    non_blocked     21
IDE11502-ENG127546-Locked menu contents-FB_PHONE_1    non_blocked     21
IDE11502-ENG127555-Locked menu contents-FB_PHONE_10    non_blocked     21
IDE11502-ENG127556-Locked menu contents-FB_PHONE_11    non_blocked     21
IDE11502-ENG127557-Locked menu contents-FB_PHONE_12    non_blocked     21
IDE11502-ENG127558-Locked menu contents-FB_PHONE_13    non_blocked     21
IDE11502-ENG127559-Locked menu contents-FB_PHONE_14    non_blocked     21
IDE11502-ENG127560-Locked menu contents-FB_PHONE_15    non_blocked     21
IDE11502-ENG127547-Locked menu contents-FB_PHONE_2    non_blocked     21
IDE11502-ENG127548-Locked menu contents-FB_PHONE_3    non_blocked     21
IDE11502-ENG127549-Locked menu contents-FB_PHONE_4    non_blocked     21
IDE11502-ENG127550-Locked menu contents-FB_PHONE_5    non_blocked     21
IDE11502-ENG127551-Locked menu contents-FB_PHONE_6    non_blocked     21
IDE11502-ENG127552-Locked menu contents-FB_PHONE_7    non_blocked     21
IDE11502-ENG127553-Locked menu contents-FB_PHONE_8    non_blocked     21
IDE11502-ENG127554-Locked menu contents-FB_PHONE_9    non_blocked     21
IDE11502-ENG127505-Locked menu contents-FB_TUNER_0    non_blocked     21
IDE11502-ENG127506-Locked menu contents-FB_TUNER_1    non_blocked     21
IDE11502-ENG127515-Locked menu contents-FB_TUNER_10    non_blocked     21
IDE11502-ENG127516-Locked menu contents-FB_TUNER_11    non_blocked     21
IDE11502-ENG127517-Locked menu contents-FB_TUNER_12    non_blocked     21
IDE11502-ENG127518-Locked menu contents-FB_TUNER_13    non_blocked     21
IDE11502-ENG127519-Locked menu contents-FB_TUNER_14    non_blocked     21
IDE11502-ENG127520-Locked menu contents-FB_TUNER_15    non_blocked     21
IDE11502-ENG127507-Locked menu contents-FB_TUNER_2    non_blocked     21
IDE11502-ENG127508-Locked menu contents-FB_TUNER_3    non_blocked     21
IDE11502-ENG127509-Locked menu contents-FB_TUNER_4    non_blocked     21
IDE11502-ENG127510-Locked menu contents-FB_TUNER_5    non_blocked     21
IDE11502-ENG127511-Locked menu contents-FB_TUNER_6    non_blocked     21
IDE11502-ENG127512-Locked menu contents-FB_TUNER_7    non_blocked     21
IDE11502-ENG127513-Locked menu contents-FB_TUNER_8    non_blocked     21
IDE11502-ENG127514-Locked menu contents-FB_TUNER_9    non_blocked     21
IDE11503-Satellite radio tuner: pre-activated subscription    7    1
MAS00951-Bluetooth    On     1
MAS01968-Fan    normal     1
MAS02809-MAS02870-Check tone frequency-High note frequency range    4000 Hz    6
MAS02809-MAS02871-Check tone frequency-Medium note frequency range    1000 Hz    6
MAS02809-MAS02872-Check tone frequency-Low note frequency range    100 Hz    6
MAS03782-WLAN    On     1
ENG122227-ENG125811-Car_Function_Adaptations_Gen2-menu_auxiliary_climatization    not activated     60
ENG122227-ENG125814-Car_Function_Adaptations_Gen2-menu_auxiliary_climatization_after_disclaimer    not activated     60
ENG122227-ENG126995-Car_Function_Adaptations_Gen2-menu_auxiliary_climatization_clamp_15_off    not activated     60
ENG122227-ENG125812-Car_Function_Adaptations_Gen2-menu_auxiliary_climatization_over_threshold_high    not activated     60
ENG122227-ENG125813-Car_Function_Adaptations_Gen2-menu_auxiliary_climatization_standstill    not activated     60
ENG122227-ENG152538-Car_Function_Adaptations_Gen2-menu_auxiliary_ventilation    not activated     60
ENG122227-ENG152539-Car_Function_Adaptations_Gen2-menu_auxiliary_ventilation_after_disclaimer    not activated     60
ENG122227-ENG152540-Car_Function_Adaptations_Gen2-menu_auxiliary_ventilation_clamp_15_off    not activated     60
ENG122227-ENG152541-Car_Function_Adaptations_Gen2-menu_auxiliary_ventilation_over_threshold_high    not activated     60
ENG122227-ENG152542-Car_Function_Adaptations_Gen2-menu_auxiliary_ventilation_standstill    not activated     60
ENG122227-ENG152543-Car_Function_Adaptations_Gen2-menu_crossroad_assistent    not activated     60
ENG122227-ENG152544-Car_Function_Adaptations_Gen2-menu_crossroad_assistent_after_disclaimer    not activated     60
ENG122227-ENG152545-Car_Function_Adaptations_Gen2-menu_crossroad_assistent_clamp_15_off    not activated     60
ENG122227-ENG152546-Car_Function_Adaptations_Gen2-menu_crossroad_assistent_over_threshold_high    not activated     60
ENG122227-ENG152547-Car_Function_Adaptations_Gen2-menu_crossroad_assistent_standstill    not activated     60
ENG122227-ENG117486-Car_Function_Adaptations_Gen2-menu_display_ACC    activated     60
ENG122227-ENG117490-Car_Function_Adaptations_Gen2-menu_display_ACC_after_disclaimer    not activated     60
ENG122227-ENG117487-Car_Function_Adaptations_Gen2-menu_display_ACC_operation_clamp_15_off    not activated     60
ENG122227-ENG117488-Car_Function_Adaptations_Gen2-menu_display_ACC_over_threshold_high    activated     60
ENG122227-ENG117489-Car_Function_Adaptations_Gen2-menu_display_ACC_standstill    not activated     60
ENG122227-ENG117646-Car_Function_Adaptations_Gen2-menu_display_adaptive_key    not activated     60
ENG122227-ENG117650-Car_Function_Adaptations_Gen2-menu_display_adaptive_key_after_disclaimer    not activated     60
ENG122227-ENG117647-Car_Function_Adaptations_Gen2-menu_display_adaptive_key_clamp_15_off    not activated     60
ENG122227-ENG117648-Car_Function_Adaptations_Gen2-menu_display_adaptive_key_over_threshold_high    not activated     60
ENG122227-ENG117649-Car_Function_Adaptations_Gen2-menu_display_adaptive_key_standstill    not activated     60
ENG122227-ENG126152-Car_Function_Adaptations_Gen2-menu_display_Adblue    not activated     60
ENG122227-ENG126155-Car_Function_Adaptations_Gen2-menu_display_Adblue_after_disclaimer    not activated     60
ENG122227-ENG127002-Car_Function_Adaptations_Gen2-menu_display_Adblue_clamp_15_off    not activated     60
ENG122227-ENG126153-Car_Function_Adaptations_Gen2-menu_display_Adblue_over_threshold_high    not activated     60
ENG122227-ENG126154-Car_Function_Adaptations_Gen2-menu_display_Adblue_standstill    not activated     60
ENG122227-ENG117591-Car_Function_Adaptations_Gen2-menu_display_air_damper    not activated     60
ENG122227-ENG117595-Car_Function_Adaptations_Gen2-menu_display_air_damper_after_disclaimer    not activated     60
ENG122227-ENG117592-Car_Function_Adaptations_Gen2-menu_display_air_damper_clamp_15_off    not activated     60
ENG122227-ENG117593-Car_Function_Adaptations_Gen2-menu_display_air_damper_over_threshold_high    not activated     60
ENG122227-ENG117594-Car_Function_Adaptations_Gen2-menu_display_air_damper_standstill    not activated     60
ENG122227-ENG117491-Car_Function_Adaptations_Gen2-menu_display_ambient_illumination    activated     60
ENG122227-ENG117495-Car_Function_Adaptations_Gen2-menu_display_ambient_illumination_after_disclaimer    not activated     60
ENG122227-ENG117492-Car_Function_Adaptations_Gen2-menu_display_ambient_illumination_clamp_15_off    not activated     60
ENG122227-ENG117493-Car_Function_Adaptations_Gen2-menu_display_ambient_illumination_over_threshold_high    activated     60
ENG122227-ENG117494-Car_Function_Adaptations_Gen2-menu_display_ambient_illumination_standstill    not activated     60
ENG122227-ENG122296-Car_Function_Adaptations_Gen2-menu_display_angle_of_slope    not activated     60
ENG122227-ENG122300-Car_Function_Adaptations_Gen2-menu_display_angle_of_slope_after_disclaimer    not activated     60
ENG122227-ENG122297-Car_Function_Adaptations_Gen2-menu_display_angle_of_slope_clamp_15_off    not activated     60
ENG122227-ENG122298-Car_Function_Adaptations_Gen2-menu_display_angle_of_slope_over_threshold_high    not activated     60
ENG122227-ENG122299-Car_Function_Adaptations_Gen2-menu_display_angle_of_slope_standstill    not activated     60
ENG122227-ENG117641-Car_Function_Adaptations_Gen2-menu_display_attention_identification    not activated     60
ENG122227-ENG117645-Car_Function_Adaptations_Gen2-menu_display_attention_identification_after_disclaimer    not activated     60
ENG122227-ENG117642-Car_Function_Adaptations_Gen2-menu_display_attention_identification_clamp_15_off    not activated     60
ENG122227-ENG117643-Car_Function_Adaptations_Gen2-menu_display_attention_identification_over_threshold_high    not activated     60
ENG122227-ENG117644-Car_Function_Adaptations_Gen2-menu_display_attention_identification_standstill    not activated     60
ENG122227-ENG117531-Car_Function_Adaptations_Gen2-menu_display_auxiliary_heating    not activated     60
ENG122227-ENG117535-Car_Function_Adaptations_Gen2-menu_display_auxiliary_heating_after_disclaimer    not activated     60
ENG122227-ENG117532-Car_Function_Adaptations_Gen2-menu_display_auxiliary_heating_clamp_15_off    not activated     60
ENG122227-ENG117533-Car_Function_Adaptations_Gen2-menu_display_auxiliary_heating_over_threshold_high    not activated     60
ENG122227-ENG117534-Car_Function_Adaptations_Gen2-menu_display_auxiliary_heating_standstill    not activated     60
ENG122227-ENG117501-Car_Function_Adaptations_Gen2-menu_display_awv    activated     60
ENG122227-ENG117505-Car_Function_Adaptations_Gen2-menu_display_awv_after_disclaimer    not activated     60
ENG122227-ENG117502-Car_Function_Adaptations_Gen2-menu_display_awv_clamp_15_off    not activated     60
ENG122227-ENG117503-Car_Function_Adaptations_Gen2-menu_display_awv_over_threshold_high    activated     60
ENG122227-ENG117504-Car_Function_Adaptations_Gen2-menu_display_awv_standstill    not activated     60
ENG122227-ENG122301-Car_Function_Adaptations_Gen2-menu_display_battery_management    not activated     60
ENG122227-ENG122305-Car_Function_Adaptations_Gen2-menu_display_battery_management_after_disclaimer    not activated     60
ENG122227-ENG122302-Car_Function_Adaptations_Gen2-menu_display_battery_management_clamp_15_off    not activated     60
ENG122227-ENG122303-Car_Function_Adaptations_Gen2-menu_display_battery_management_over_threshold_high    not activated     60
ENG122227-ENG122304-Car_Function_Adaptations_Gen2-menu_display_battery_management_standstill    not activated     60
ENG122227-ENG117666-Car_Function_Adaptations_Gen2-menu_display_BCmE    activated     60
ENG122227-ENG117670-Car_Function_Adaptations_Gen2-menu_display_BCmE_after_disclaimer    not activated     60
ENG122227-ENG117667-Car_Function_Adaptations_Gen2-menu_display_BCmE_clamp_15_off    not activated     60
ENG122227-ENG117668-Car_Function_Adaptations_Gen2-menu_display_BCmE_over_threshold_high    activated     60
ENG122227-ENG117669-Car_Function_Adaptations_Gen2-menu_display_BCmE_standstill    not activated     60
ENG122227-ENG117536-Car_Function_Adaptations_Gen2-menu_display_board_computer    activated     60
ENG122227-ENG117540-Car_Function_Adaptations_Gen2-menu_display_board_computer_after_disclaimer    not activated     60
ENG122227-ENG117537-Car_Function_Adaptations_Gen2-menu_display_board_computer_clamp_15_off    not activated     60
ENG122227-ENG117538-Car_Function_Adaptations_Gen2-menu_display_board_computer_over_threshold_high    activated     60
ENG122227-ENG117539-Car_Function_Adaptations_Gen2-menu_display_board_computer_standstill    not activated     60
ENG122227-ENG117671-Car_Function_Adaptations_Gen2-menu_display_Brake_Function    activated     60
ENG122227-ENG117675-Car_Function_Adaptations_Gen2-menu_display_Brake_Function_after_disclaimer    not activated     60
ENG122227-ENG117672-Car_Function_Adaptations_Gen2-menu_display_Brake_Function_clamp_15_off    not activated     60
ENG122227-ENG117673-Car_Function_Adaptations_Gen2-menu_display_Brake_Function_over_threshold_high    activated     60
ENG122227-ENG117674-Car_Function_Adaptations_Gen2-menu_display_Brake_Function_standstill    not activated     60
ENG122227-ENG117651-Car_Function_Adaptations_Gen2-menu_display_car_mirror    activated     60
ENG122227-ENG117655-Car_Function_Adaptations_Gen2-menu_display_car_mirror_after_disclaimer    not activated     60
ENG122227-ENG117652-Car_Function_Adaptations_Gen2-menu_display_car_mirror_clamp_15_off    not activated     60
ENG122227-ENG117653-Car_Function_Adaptations_Gen2-menu_display_car_mirror_over_threshold_high    activated     60
ENG122227-ENG117654-Car_Function_Adaptations_Gen2-menu_display_car_mirror_standstill    not activated     60
ENG122227-ENG117561-Car_Function_Adaptations_Gen2-menu_display_central_locking    activated     60
ENG122227-ENG117565-Car_Function_Adaptations_Gen2-menu_display_central_locking_after_disclaimer    not activated     60
ENG122227-ENG117562-Car_Function_Adaptations_Gen2-menu_display_central_locking_clamp_15_off    not activated     60
ENG122227-ENG117563-Car_Function_Adaptations_Gen2-menu_display_central_locking_over_threshold_high    activated     60
ENG122227-ENG117564-Car_Function_Adaptations_Gen2-menu_display_central_locking_standstill    not activated     60
ENG122227-ENG117601-Car_Function_Adaptations_Gen2-menu_display_central_unit_master    activated     60
ENG122227-ENG117605-Car_Function_Adaptations_Gen2-menu_display_central_unit_master_after_disclaimer    not activated     60
ENG122227-ENG117602-Car_Function_Adaptations_Gen2-menu_display_central_unit_master_clamp_15_off    not activated     60
ENG122227-ENG117603-Car_Function_Adaptations_Gen2-menu_display_central_unit_master_over_threshold_high    activated     60
ENG122227-ENG117604-Car_Function_Adaptations_Gen2-menu_display_central_unit_master_standstill    not activated     60
ENG122227-ENG117571-Car_Function_Adaptations_Gen2-menu_display_charisma    activated     60
ENG122227-ENG117575-Car_Function_Adaptations_Gen2-menu_display_charisma_after_disclaimer    not activated     60
ENG122227-ENG117572-Car_Function_Adaptations_Gen2-menu_display_charisma_clamp_15_off    not activated     60
ENG122227-ENG117573-Car_Function_Adaptations_Gen2-menu_display_charisma_over_threshold_high    activated     60
ENG122227-ENG117574-Car_Function_Adaptations_Gen2-menu_display_charisma_standstill    not activated     60
ENG122227-ENG117526-Car_Function_Adaptations_Gen2-menu_display_clima_configuration    activated     60
ENG122227-ENG117530-Car_Function_Adaptations_Gen2-menu_display_clima_configuration_after_disclaimer    not activated     60
ENG122227-ENG117527-Car_Function_Adaptations_Gen2-menu_display_clima_configuration_clamp_15_off    not activated     60
ENG122227-ENG117528-Car_Function_Adaptations_Gen2-menu_display_clima_configuration_over_threshold_high    activated     60
ENG122227-ENG117529-Car_Function_Adaptations_Gen2-menu_display_clima_configuration_standstill    not activated     60
ENG122227-ENG117586-Car_Function_Adaptations_Gen2-menu_display_clock    activated     60
ENG122227-ENG117590-Car_Function_Adaptations_Gen2-menu_display_clock_after_disclaimer    not activated     60
ENG122227-ENG117587-Car_Function_Adaptations_Gen2-menu_display_clock_clamp_15_off    not activated     60
ENG122227-ENG117588-Car_Function_Adaptations_Gen2-menu_display_clock_over_threshold_high    activated     60
ENG122227-ENG117589-Car_Function_Adaptations_Gen2-menu_display_clock_standstill    not activated     60
ENG122227-ENG117566-Car_Function_Adaptations_Gen2-menu_display_compass    activated     60
ENG122227-ENG117570-Car_Function_Adaptations_Gen2-menu_display_compass_after_disclaimer    not activated     60
ENG122227-ENG117567-Car_Function_Adaptations_Gen2-menu_display_compass_clamp_15_off    not activated     60
ENG122227-ENG117568-Car_Function_Adaptations_Gen2-menu_display_compass_over_threshold_high    activated     60
ENG122227-ENG117569-Car_Function_Adaptations_Gen2-menu_display_compass_standstill    not activated     60
ENG122227-ENG125823-Car_Function_Adaptations_Gen2-menu_display_Curve_Assist    not activated     60
ENG122227-ENG125826-Car_Function_Adaptations_Gen2-menu_display_Curve_Assist_after_disclaimer    not activated     60
ENG122227-ENG126998-Car_Function_Adaptations_Gen2-menu_display_Curve_Assist_clamp_15_off    not activated     60
ENG122227-ENG125824-Car_Function_Adaptations_Gen2-menu_display_Curve_Assist_over_threshold_high    not activated     60
ENG122227-ENG125825-Car_Function_Adaptations_Gen2-menu_display_Curve_Assist_standstill    not activated     60
ENG122227-ENG142087-Car_Function_Adaptations_Gen2-menu_display_Display_Configuration    not activated     60
ENG122227-ENG142091-Car_Function_Adaptations_Gen2-menu_display_Display_Configuration_after_disclaimer    not activated     60
ENG122227-ENG142088-Car_Function_Adaptations_Gen2-menu_display_Display_Configuration_clamp_15_off    not activated     60
ENG122227-ENG142089-Car_Function_Adaptations_Gen2-menu_display_Display_Configuration_over_threshold_high    not activated     60
ENG122227-ENG142090-Car_Function_Adaptations_Gen2-menu_display_Display_Configuration_standstill    not activated     60
ENG122227-ENG117656-Car_Function_Adaptations_Gen2-menu_display_driving_school    activated     60
ENG122227-ENG117660-Car_Function_Adaptations_Gen2-menu_display_driving_school_after_disclaimer    not activated     60
ENG122227-ENG117657-Car_Function_Adaptations_Gen2-menu_display_driving_school_clamp_15_off    not activated     60
ENG122227-ENG117658-Car_Function_Adaptations_Gen2-menu_display_driving_school_over_threshold_high    activated     60
ENG122227-ENG117659-Car_Function_Adaptations_Gen2-menu_display_driving_school_standstill    not activated     60
ENG122227-ENG125034-Car_Function_Adaptations_Gen2-menu_display_Ecall    activated     60
ENG122227-ENG125038-Car_Function_Adaptations_Gen2-menu_display_Ecall_after_disclaimer    not activated     60
ENG122227-ENG126999-Car_Function_Adaptations_Gen2-menu_display_eCall_clamp_15_off    not activated     60
ENG122227-ENG125036-Car_Function_Adaptations_Gen2-menu_display_Ecall_over_threshold_high    activated     60
ENG122227-ENG125037-Car_Function_Adaptations_Gen2-menu_display_Ecall_standstill    not activated     60
ENG122227-ENG126160-Car_Function_Adaptations_Gen2-menu_display_Efficiency_Assist    not activated     60
ENG122227-ENG126163-Car_Function_Adaptations_Gen2-menu_display_Efficiency_Assist_after_disclaimer    not activated     60
ENG122227-ENG127004-Car_Function_Adaptations_Gen2-menu_display_Efficiency_Assist_clamp_15_off    not activated     60
ENG122227-ENG126161-Car_Function_Adaptations_Gen2-menu_display_Efficiency_Assist_over_threshold_high    not activated     60
ENG122227-ENG126162-Car_Function_Adaptations_Gen2-menu_display_Efficiency_Assist_standstill    not activated     60
ENG122227-ENG126144-Car_Function_Adaptations_Gen2-menu_display_ENI    activated     60
ENG122227-ENG126147-Car_Function_Adaptations_Gen2-menu_display_ENI_after_disclaimer    not activated     60
ENG122227-ENG127000-Car_Function_Adaptations_Gen2-menu_display_ENI_clamp_15_off    not activated     60
ENG122227-ENG126145-Car_Function_Adaptations_Gen2-menu_display_ENI_over_threshold_high    activated     60
ENG122227-ENG126146-Car_Function_Adaptations_Gen2-menu_display_ENI_standstill    not activated     60
ENG122227-ENG117516-Car_Function_Adaptations_Gen2-menu_display_exterior_illumination    activated     60
ENG122227-ENG117520-Car_Function_Adaptations_Gen2-menu_display_exterior_illumination_after_disclaimer    not activated     60
ENG122227-ENG117517-Car_Function_Adaptations_Gen2-menu_display_exterior_illumination_clamp_15_off    not activated     60
ENG122227-ENG117518-Car_Function_Adaptations_Gen2-menu_display_exterior_illumination_over_threshold_high    activated     60
ENG122227-ENG117519-Car_Function_Adaptations_Gen2-menu_display_exterior_illumination_standstill    not activated     60
ENG122227-ENG117596-Car_Function_Adaptations_Gen2-menu_display_headup_display    not activated     60
ENG122227-ENG117600-Car_Function_Adaptations_Gen2-menu_display_headup_display_after_disclaimer    not activated     60
ENG122227-ENG117597-Car_Function_Adaptations_Gen2-menu_display_headup_display_clamp_15_off    not activated     60
ENG122227-ENG117598-Car_Function_Adaptations_Gen2-menu_display_headup_display_over_threshold_high    not activated     60
ENG122227-ENG117599-Car_Function_Adaptations_Gen2-menu_display_headup_display_standstill    not activated     60
ENG122227-ENG117606-Car_Function_Adaptations_Gen2-menu_display_hybrid    not activated     60
ENG122227-ENG117610-Car_Function_Adaptations_Gen2-menu_display_hybrid_after_disclaimer    not activated     60
ENG122227-ENG117607-Car_Function_Adaptations_Gen2-menu_display_hybrid_clamp_15_off    not activated     60
ENG122227-ENG117608-Car_Function_Adaptations_Gen2-menu_display_hybrid_over_threshold_high    not activated     60
ENG122227-ENG117609-Car_Function_Adaptations_Gen2-menu_display_hybrid_standstill    not activated     60
ENG122227-ENG125805-Car_Function_Adaptations_Gen2-menu_display_lane_assistant    activated     60
ENG122227-ENG125809-Car_Function_Adaptations_Gen2-menu_display_lane_assistant_after_disclaimer    not activated     60
ENG122227-ENG125806-Car_Function_Adaptations_Gen2-menu_display_lane_assistant_clamp_15_off    not activated     60
ENG122227-ENG125807-Car_Function_Adaptations_Gen2-menu_display_lane_assistant_over_threshold_high    not activated     60
ENG122227-ENG125808-Car_Function_Adaptations_Gen2-menu_display_lane_assistant_standstill    not activated     60
ENG122227-ENG117506-Car_Function_Adaptations_Gen2-menu_display_Lane_Departure_Warning    activated     60
ENG122227-ENG117510-Car_Function_Adaptations_Gen2-menu_display_Lane_Departure_Warning_after_disclaimer    not activated     60
ENG122227-ENG117507-Car_Function_Adaptations_Gen2-menu_display_Lane_Departure_Warning_clamp_15_off    not activated     60
ENG122227-ENG117508-Car_Function_Adaptations_Gen2-menu_display_Lane_Departure_Warning_over_threshold_high    activated     60
ENG122227-ENG117509-Car_Function_Adaptations_Gen2-menu_display_Lane_Departure_Warning_standstill    not activated     60
ENG122227-ENG117631-Car_Function_Adaptations_Gen2-menu_display_MFL_jocker    not activated     60
ENG122227-ENG117635-Car_Function_Adaptations_Gen2-menu_display_MFL_jocker_after_disclaimer    not activated     60
ENG122227-ENG117632-Car_Function_Adaptations_Gen2-menu_display_MFL_jocker_clamp_15_off    not activated     60
ENG122227-ENG117633-Car_Function_Adaptations_Gen2-menu_display_MFL_jocker_over_threshold_high    not activated     60
ENG122227-ENG117634-Car_Function_Adaptations_Gen2-menu_display_MFL_jocker_standstill    not activated     60
ENG122227-ENG117616-Car_Function_Adaptations_Gen2-menu_display_night_vision    not activated     60
ENG122227-ENG117620-Car_Function_Adaptations_Gen2-menu_display_night_vision_after_disclaimer    not activated     60
ENG122227-ENG117617-Car_Function_Adaptations_Gen2-menu_display_night_vision_clamp_15_off    not activated     60
ENG122227-ENG117618-Car_Function_Adaptations_Gen2-menu_display_night_vision_over_threshold_high    not activated     60
ENG122227-ENG117619-Car_Function_Adaptations_Gen2-menu_display_night_vision_standstill    not activated     60
ENG122227-ENG117576-Car_Function_Adaptations_Gen2-menu_display_oil_level    not activated     60
ENG122227-ENG117580-Car_Function_Adaptations_Gen2-menu_display_oil_level_after_disclaimer    not activated     60
ENG122227-ENG117577-Car_Function_Adaptations_Gen2-menu_display_oil_level_clamp_15_off    not activated     60
ENG122227-ENG117578-Car_Function_Adaptations_Gen2-menu_display_oil_level_over_threshold_high    not activated     60
ENG122227-ENG117579-Car_Function_Adaptations_Gen2-menu_display_oil_level_standstill    not activated     60
ENG122227-ENG117496-Car_Function_Adaptations_Gen2-menu_display_pdc    activated     60
ENG122227-ENG117500-Car_Function_Adaptations_Gen2-menu_display_pdc_after_disclaimer    not activated     60
ENG122227-ENG117497-Car_Function_Adaptations_Gen2-menu_display_pdc_clamp_15_off    not activated     60
ENG122227-ENG117498-Car_Function_Adaptations_Gen2-menu_display_pdc_over_threshold_high    activated     60
ENG122227-ENG117499-Car_Function_Adaptations_Gen2-menu_display_pdc_standstill    not activated     60
ENG122227-ENG125815-Car_Function_Adaptations_Gen2-menu_display_Pedestrian_Assist    not activated     60
ENG122227-ENG125818-Car_Function_Adaptations_Gen2-menu_display_Pedestrian_Assist_after_disclaimer    not activated     60
ENG122227-ENG126996-Car_Function_Adaptations_Gen2-menu_display_Pedestrian_Assist_clamp_15_off    not activated     60
ENG122227-ENG125816-Car_Function_Adaptations_Gen2-menu_display_Pedestrian_Assist_over_threshold_high    not activated     60
ENG122227-ENG125817-Car_Function_Adaptations_Gen2-menu_display_Pedestrian_Assist_standstill    not activated     60
ENG122227-ENG117541-Car_Function_Adaptations_Gen2-menu_display_rdk    activated     60
ENG122227-ENG117545-Car_Function_Adaptations_Gen2-menu_display_rdk_after_disclaimer    not activated     60
ENG122227-ENG117542-Car_Function_Adaptations_Gen2-menu_display_rdk_clamp_15_off    not activated     60
ENG122227-ENG117543-Car_Function_Adaptations_Gen2-menu_display_rdk_over_threshold_high    activated     60
ENG122227-ENG117544-Car_Function_Adaptations_Gen2-menu_display_rdk_standstill    not activated     60
ENG122227-ENG122306-Car_Function_Adaptations_Gen2-menu_display_RearSeatEntertainment    not activated     60
ENG122227-ENG122310-Car_Function_Adaptations_Gen2-menu_display_RearSeatEntertainment_after_disclaimer    not activated     60
ENG122227-ENG122307-Car_Function_Adaptations_Gen2-menu_display_RearSeatEntertainment_clamp_15_off    not activated     60
ENG122227-ENG122308-Car_Function_Adaptations_Gen2-menu_display_RearSeatEntertainment_over_threshold_high    not activated     60
ENG122227-ENG122309-Car_Function_Adaptations_Gen2-menu_display_RearSeatEntertainment_standstill    not activated     60
ENG122227-ENG117626-Car_Function_Adaptations_Gen2-menu_display_reversible_belt_pre_load    not activated     60
ENG122227-ENG117630-Car_Function_Adaptations_Gen2-menu_display_reversible_belt_pre_load_after_disclaimer    not activated     60
ENG122227-ENG117627-Car_Function_Adaptations_Gen2-menu_display_reversible_belt_pre_load_clamp_15_off    not activated     60
ENG122227-ENG117628-Car_Function_Adaptations_Gen2-menu_display_reversible_belt_pre_load_over_threshold_high    not activated     60
ENG122227-ENG117629-Car_Function_Adaptations_Gen2-menu_display_reversible_belt_pre_load_standstill    not activated     60
ENG122227-ENG117636-Car_Function_Adaptations_Gen2-menu_display_road_sign_identification    activated     60
ENG122227-ENG117640-Car_Function_Adaptations_Gen2-menu_display_road_sign_identification_after_disclaimer    not activated     60
ENG122227-ENG117637-Car_Function_Adaptations_Gen2-menu_display_road_sign_identification_clamp_15_off    not activated     60
ENG122227-ENG117638-Car_Function_Adaptations_Gen2-menu_display_road_sign_identification_over_threshold_high    activated     60
ENG122227-ENG117639-Car_Function_Adaptations_Gen2-menu_display_road_sign_identification_standstill    not activated     60
ENG122227-ENG117556-Car_Function_Adaptations_Gen2-menu_display_seat_configuration    not activated     60
ENG122227-ENG117560-Car_Function_Adaptations_Gen2-menu_display_seat_configuration_after_disclaimer    not activated     60
ENG122227-ENG117557-Car_Function_Adaptations_Gen2-menu_display_seat_configuration_clamp_15_off    not activated     60
ENG122227-ENG117558-Car_Function_Adaptations_Gen2-menu_display_seat_configuration_over_threshold_high    not activated     60
ENG122227-ENG117559-Car_Function_Adaptations_Gen2-menu_display_seat_configuration_standstill    not activated     60
ENG122227-ENG125819-Car_Function_Adaptations_Gen2-menu_display_Seat_Pneumatic    not activated     60
ENG122227-ENG125822-Car_Function_Adaptations_Gen2-menu_display_Seat_Pneumatic_after_disclaimer    not activated     60
ENG122227-ENG126997-Car_Function_Adaptations_Gen2-menu_display_Seat_Pneumatic_clamp_15_off    not activated     60
ENG122227-ENG125820-Car_Function_Adaptations_Gen2-menu_display_Seat_Pneumatic_over_threshold_high    not activated     60
ENG122227-ENG125821-Car_Function_Adaptations_Gen2-menu_display_Seat_Pneumatic_standstill    not activated     60
ENG122227-ENG117551-Car_Function_Adaptations_Gen2-menu_display_sia    activated     60
ENG122227-ENG117555-Car_Function_Adaptations_Gen2-menu_display_sia_after_disclaimer    not activated     60
ENG122227-ENG117552-Car_Function_Adaptations_Gen2-menu_display_sia_clamp_15_off    not activated     60
ENG122227-ENG117553-Car_Function_Adaptations_Gen2-menu_display_sia_over_threshold_high    activated     60
ENG122227-ENG117554-Car_Function_Adaptations_Gen2-menu_display_sia_standstill    not activated     60
ENG122227-ENG117621-Car_Function_Adaptations_Gen2-menu_display_side_view    not activated     60
ENG122227-ENG117625-Car_Function_Adaptations_Gen2-menu_display_side_view_after_disclaimer    not activated     60
ENG122227-ENG117622-Car_Function_Adaptations_Gen2-menu_display_side_view_clamp_15_off    not activated     60
ENG122227-ENG117623-Car_Function_Adaptations_Gen2-menu_display_side_view_over_threshold_high    not activated     60
ENG122227-ENG117624-Car_Function_Adaptations_Gen2-menu_display_side_view_standstill    not activated     60
ENG122227-ENG122311-Car_Function_Adaptations_Gen2-menu_display_special_functions    not activated     60
ENG122227-ENG122314-Car_Function_Adaptations_Gen2-menu_display_special_functions_after_disclaimer    not activated     60
ENG122227-ENG125810-Car_Function_Adaptations_Gen2-menu_display_special_functions_clamp_15_off    not activated     60
ENG122227-ENG122312-Car_Function_Adaptations_Gen2-menu_display_special_functions_over_threshold_high    not activated     60
ENG122227-ENG122313-Car_Function_Adaptations_Gen2-menu_display_special_functions_standstill    not activated     60
ENG122227-ENG142082-Car_Function_Adaptations_Gen2-menu_display_Spoiler    not activated     60
ENG122227-ENG142086-Car_Function_Adaptations_Gen2-menu_display_Spoiler_after_disclaimer    not activated     60
ENG122227-ENG142083-Car_Function_Adaptations_Gen2-menu_display_Spoiler_clamp_15_off    not activated     60
ENG122227-ENG142084-Car_Function_Adaptations_Gen2-menu_display_Spoiler_over_threshold_high    not activated     60
ENG122227-ENG142085-Car_Function_Adaptations_Gen2-menu_display_Spoiler_standstill    not activated     60
ENG122227-ENG126148-Car_Function_Adaptations_Gen2-menu_display_SportHMI    not activated     60
ENG122227-ENG126151-Car_Function_Adaptations_Gen2-menu_display_SportHMI_after_disclaimer    not activated     60
ENG122227-ENG127001-Car_Function_Adaptations_Gen2-menu_display_SportHMI_clamp_15_off    not activated     60
ENG122227-ENG126149-Car_Function_Adaptations_Gen2-menu_display_SportHMI_over_threshold_high    not activated     60
ENG122227-ENG126150-Car_Function_Adaptations_Gen2-menu_display_SportHMI_standstill    not activated     60
ENG122227-ENG117676-Car_Function_Adaptations_Gen2-menu_display_Start_Stop_reasons    not activated     60
ENG122227-ENG117680-Car_Function_Adaptations_Gen2-menu_display_Start_Stop_reasons_after_disclaimer    not activated     60
ENG122227-ENG117677-Car_Function_Adaptations_Gen2-menu_display_Start_Stop_reasons_clamp_15_off    not activated     60
ENG122227-ENG117678-Car_Function_Adaptations_Gen2-menu_display_Start_Stop_reasons_over_threshold_high    not activated     60
ENG122227-ENG117679-Car_Function_Adaptations_Gen2-menu_display_Start_Stop_reasons_standstill    not activated     60
ENG122227-ENG122315-Car_Function_Adaptations_Gen2-menu_display_trailer_assistant    not activated     60
ENG122227-ENG122319-Car_Function_Adaptations_Gen2-menu_display_trailer_assistant_after_disclaimer    not activated     60
ENG122227-ENG122316-Car_Function_Adaptations_Gen2-menu_display_trailer_assistant_clamp_15_off    not activated     60
ENG122227-ENG122317-Car_Function_Adaptations_Gen2-menu_display_trailer_assistant_over_threshold_high    not activated     60
ENG122227-ENG122318-Car_Function_Adaptations_Gen2-menu_display_trailer_assistant_standstill    not activated     60
ENG122227-ENG122320-Car_Function_Adaptations_Gen2-menu_display_TV_tuner    not activated     60
ENG122227-ENG122324-Car_Function_Adaptations_Gen2-menu_display_TV_tuner_after_disclaimer    not activated     60
ENG122227-ENG122321-Car_Function_Adaptations_Gen2-menu_display_TV_tuner_clamp_15_off    not activated     60
ENG122227-ENG122322-Car_Function_Adaptations_Gen2-menu_display_TV_tuner_over_threshold_high    not activated     60
ENG122227-ENG122323-Car_Function_Adaptations_Gen2-menu_display_TV_tuner_standstill    not activated     60
ENG122227-ENG117611-Car_Function_Adaptations_Gen2-menu_display_ugdo    not activated     60
ENG122227-ENG117615-Car_Function_Adaptations_Gen2-menu_display_ugdo_after_disclaimer    not activated     60
ENG122227-ENG117612-Car_Function_Adaptations_Gen2-menu_display_ugdo_clamp_15_off    not activated     60
ENG122227-ENG117613-Car_Function_Adaptations_Gen2-menu_display_ugdo_over_threshold_high    not activated     60
ENG122227-ENG117614-Car_Function_Adaptations_Gen2-menu_display_ugdo_standstill    not activated     60
ENG122227-ENG122291-Car_Function_Adaptations_Gen2-menu_display_user_eco_rating    activated     60
ENG122227-ENG122295-Car_Function_Adaptations_Gen2-menu_display_user_eco_rating_after_disclaimer    not activated     60
ENG122227-ENG122292-Car_Function_Adaptations_Gen2-menu_display_user_eco_rating_clamp_15_off    not activated     60
ENG122227-ENG122293-Car_Function_Adaptations_Gen2-menu_display_user_eco_rating_over_threshold_high    activated     60
ENG122227-ENG122294-Car_Function_Adaptations_Gen2-menu_display_user_eco_rating_standstill    not activated     60
ENG122227-ENG117581-Car_Function_Adaptations_Gen2-menu_display_vin    activated     60
ENG122227-ENG117585-Car_Function_Adaptations_Gen2-menu_display_vin_after_disclaimer    not activated     60
ENG122227-ENG117582-Car_Function_Adaptations_Gen2-menu_display_vin_clamp_15_off    not activated     60
ENG122227-ENG117583-Car_Function_Adaptations_Gen2-menu_display_vin_over_threshold_high    activated     60
ENG122227-ENG117584-Car_Function_Adaptations_Gen2-menu_display_vin_standstill    not activated     60
ENG122227-ENG117661-Car_Function_Adaptations_Gen2-menu_display_weariness_recognition    activated     60
ENG122227-ENG117665-Car_Function_Adaptations_Gen2-menu_display_weariness_recognition_after_disclaimer    not activated     60
ENG122227-ENG117662-Car_Function_Adaptations_Gen2-menu_display_weariness_recognition_clamp_15_off    not activated     60
ENG122227-ENG117663-Car_Function_Adaptations_Gen2-menu_display_weariness_recognition_over_threshold_high    activated     60
ENG122227-ENG117664-Car_Function_Adaptations_Gen2-menu_display_weariness_recognition_standstill    not activated     60
ENG122227-ENG117521-Car_Function_Adaptations_Gen2-menu_display_windows    activated     60
ENG122227-ENG117525-Car_Function_Adaptations_Gen2-menu_display_windows_after_disclaimer    not activated     60
ENG122227-ENG117522-Car_Function_Adaptations_Gen2-menu_display_windows_clamp_15_off    not activated     60
ENG122227-ENG117523-Car_Function_Adaptations_Gen2-menu_display_windows_over_threshold_high    activated     60
ENG122227-ENG117524-Car_Function_Adaptations_Gen2-menu_display_windows_standstill    not activated     60
ENG122227-ENG117546-Car_Function_Adaptations_Gen2-menu_display_wiper    activated     60
ENG122227-ENG117550-Car_Function_Adaptations_Gen2-menu_display_wiper_after_disclaimer    not activated     60
ENG122227-ENG117547-Car_Function_Adaptations_Gen2-menu_display_wiper_clamp_15_off    not activated     60
ENG122227-ENG117548-Car_Function_Adaptations_Gen2-menu_display_wiper_over_threshold_high    activated     60
ENG122227-ENG117549-Car_Function_Adaptations_Gen2-menu_display_wiper_standstill    not activated     60
ENG122227-ENG142092-Car_Function_Adaptations_Gen2-menu_soundcontrol    not activated     60
ENG122227-ENG142096-Car_Function_Adaptations_Gen2-menu_soundcontrol_after_disclaimer    not activated     60
ENG122227-ENG142093-Car_Function_Adaptations_Gen2-menu_soundcontrol_clamp_15_off    not activated     60
ENG122227-ENG142094-Car_Function_Adaptations_Gen2-menu_soundcontrol_over_threshold_high    not activated     60
ENG122227-ENG142095-Car_Function_Adaptations_Gen2-menu_soundcontrol_standstill    not activated     60
ENG122229-ENG117700-Car_Function_List_BAP_Gen2-ACC_0x05    activated     64
ENG122229-ENG117701-Car_Function_List_BAP_Gen2-ACC_0x05_msg_bus    Extended data bus     64
ENG122229-ENG117702-Car_Function_List_BAP_Gen2-air_suspension_0x06    not activated     64
ENG122229-ENG117703-Car_Function_List_BAP_Gen2-air_suspension_0x06_msg_bus    Suspension data bus     64
ENG122229-ENG117764-Car_Function_List_BAP_Gen2-Amplifier_0x2D    not activated     64
ENG122229-ENG117765-Car_Function_List_BAP_Gen2-Amplifier_0x2D_msg_bus    Infotainment data bus     64
ENG122229-ENG122334-Car_Function_List_BAP_Gen2-Angle_Of_Slope_0x24    not activated     64
ENG122229-ENG122335-Car_Function_List_BAP_Gen2-Angle_Of_Slope_0x24_msg_bus    not activated     64
ENG122229-ENG117696-Car_Function_List_BAP_Gen2-auxilary_heating_0x03    not activated     64
ENG122229-ENG117697-Car_Function_List_BAP_Gen2-auxilary_heating_0x03_msg_bus    Comfort data bus     64
ENG122229-ENG117744-Car_Function_List_BAP_Gen2-AWV_0x1B    activated     64
ENG122229-ENG117745-Car_Function_List_BAP_Gen2-AWV_0x1B_msg_bus    Terminal 15     64
ENG122229-ENG122336-Car_Function_List_BAP_Gen2-Battery_Management_0x25    not activated     64
ENG122229-ENG122337-Car_Function_List_BAP_Gen2-Battery_Management_0x25_msg_bus    Powertrain data bus     64
ENG122229-ENG117758-Car_Function_List_BAP_Gen2-BCmE_0x23    activated     64
ENG122229-ENG117759-Car_Function_List_BAP_Gen2-BCmE_0x23_msg_bus    Infotainment data bus     64
ENG122229-ENG117760-Car_Function_List_BAP_Gen2-Brake_0x26    activated     64
ENG122229-ENG117761-Car_Function_List_BAP_Gen2-Brake_0x26_msg_bus    Suspension data bus     64
ENG122229-ENG117717-Car_Function_List_BAP_Gen2-central_locking_0x0D    activated     64
ENG122229-ENG117716-Car_Function_List_BAP_Gen2-central_locking_0x0D_msg_bus    Comfort data bus     64
ENG122229-ENG117736-Car_Function_List_BAP_Gen2-charisma_0x17    activated     64
ENG122229-ENG117737-Car_Function_List_BAP_Gen2-charisma_0x17_msg_bus    Infotainment data bus     64
ENG122229-ENG117734-Car_Function_List_BAP_Gen2-clima_slave_2_0x16    not activated     64
ENG122229-ENG117735-Car_Function_List_BAP_Gen2-clima_slave_2_0x16_msg_bus    Comfort data bus     64
ENG122229-ENG117692-Car_Function_List_BAP_Gen2-climatic_master_0x01    activated     64
ENG122229-ENG117693-Car_Function_List_BAP_Gen2-climatic_master_0x01_msg_bus    Comfort data bus     64
ENG122229-ENG117694-Car_Function_List_BAP_Gen2-climatic_slave_0x02    not activated     64
ENG122229-ENG117695-Car_Function_List_BAP_Gen2-climatic_slave_0x02_msg_bus    Comfort data bus     64
ENG122229-ENG117724-Car_Function_List_BAP_Gen2-clock_0x11    activated     64
ENG122229-ENG117725-Car_Function_List_BAP_Gen2-clock_0x11_msg_bus    Comfort data bus     64
ENG122229-ENG117732-Car_Function_List_BAP_Gen2-compass_0x15    not activated     64
ENG122229-ENG117733-Car_Function_List_BAP_Gen2-compass_0x15_msg_bus    not activated     64
ENG122229-ENG117722-Car_Function_List_BAP_Gen2-driver_seat_0x10    not activated     64
ENG122229-ENG117723-Car_Function_List_BAP_Gen2-driver_seat_0x10_msg_bus    Comfort data bus     64
ENG122229-ENG125039-Car_Function_List_BAP_Gen2-Ecall_0x33    activated     64
ENG122229-ENG125828-Car_Function_List_BAP_Gen2-eCall_0x33_msg_bus    Comfort data bus     64
ENG122229-ENG127500-Car_Function_List_BAP_Gen2-efficiency_assis_msg_bus_0x3C    Comfort data bus     64
ENG122229-ENG127499-Car_Function_List_BAP_Gen2-efficiency_assist_0x3C    not activated     64
ENG122229-ENG125829-Car_Function_List_BAP_Gen2-ENI_0x37    activated     64
ENG122229-ENG125830-Car_Function_List_BAP_Gen2-ENI_0x37_msg_bus    Comfort data bus     64
ENG122229-ENG152531-Car_Function_List_BAP_Gen2-ExBoxM2_0x38    not activated     64
ENG122229-ENG152532-Car_Function_List_BAP_Gen2-ExBoxM2_0x38_msg_bus    Comfort data bus     64
ENG122229-ENG117708-Car_Function_List_BAP_Gen2-exterieur_light_0x09    activated     64
ENG122229-ENG117709-Car_Function_List_BAP_Gen2-exterieur_light_0x09_msg_bus    Comfort data bus     64
ENG122229-ENG117698-Car_Function_List_BAP_Gen2-headup_displ_0x04    not activated     64
ENG122229-ENG117699-Car_Function_List_BAP_Gen2-headup_displ_0x04_msg_bus    Comfort data bus     64
ENG122229-ENG117746-Car_Function_List_BAP_Gen2-Hybrid_0x1D    not activated     64
ENG122229-ENG117747-Car_Function_List_BAP_Gen2-Hybrid_0x1D_msg_bus    Powertrain data bus     64
ENG122229-ENG117706-Car_Function_List_BAP_Gen2-interieur_light_0x08    activated     64
ENG122229-ENG117707-Car_Function_List_BAP_Gen2-interieur_light_0x08_msg_bus    Comfort data bus     64
ENG122229-ENG117740-Car_Function_List_BAP_Gen2-LDW_HCA_0x19    activated     64
ENG122229-ENG117741-Car_Function_List_BAP_Gen2-LDW_HCA_0x19_msg_bus    Extended data bus     64
ENG122229-ENG117720-Car_Function_List_BAP_Gen2-MFA_0x0F    activated     64
ENG122229-ENG117721-Car_Function_List_BAP_Gen2-MFA_0x0F_msg_bus    Comfort data bus     64
ENG122229-ENG117767-Car_Function_List_BAP_Gen2-MFL_Jocker_0x34    not activated     64
ENG122229-ENG117766-Car_Function_List_BAP_Gen2-MFL_Jocker_msg_bus_0x34    Infotainment data bus     64
ENG122229-ENG117719-Car_Function_List_BAP_Gen2-mirror_0x0E    activated     64
ENG122229-ENG117718-Car_Function_List_BAP_Gen2-mirror_0x0E_msg_bus    Comfort data bus     64
ENG122229-ENG117738-Car_Function_List_BAP_Gen2-Night_Vision_0x18    not activated     64
ENG122229-ENG117739-Car_Function_List_BAP_Gen2-Night_Vision_0x18_msg_bus    not activated     64
ENG122229-ENG117710-Car_Function_List_BAP_Gen2-parking_assist_0x0A    activated     64
ENG122229-ENG117711-Car_Function_List_BAP_Gen2-parking_assist_0x0A_msg_bus    Terminal 15     64
ENG122229-ENG117752-Car_Function_List_BAP_Gen2-Passenger_Seat_0x20    not activated     64
ENG122229-ENG117753-Car_Function_List_BAP_Gen2-Passenger_Seat_0x20_msg_bus    Comfort data bus     64
ENG122229-ENG125831-Car_Function_List_BAP_Gen2-Pedestrian_Assist_0x3A    not activated     64
ENG122229-ENG125832-Car_Function_List_BAP_Gen2-Pedestrian_Assist_msg_bus_0x3A    Extended data bus     64
ENG122229-ENG122333-Car_Function_List_BAP_Gen2-Range_Data_0x39    not activated     64
ENG122229-ENG125827-Car_Function_List_BAP_Gen2-Range_Data_msg_bus_0x39    Infotainment data bus     64
ENG122229-ENG122327-Car_Function_List_BAP_Gen2-RearSeatEntertainment_0x2E    not activated     64
ENG122229-ENG122328-Car_Function_List_BAP_Gen2-RearSeatEntertainment_0x2E_msg_bus    Comfort data bus     64
ENG122229-ENG117750-Car_Function_List_BAP_Gen2-Reversible_Seat_Belt_Tightener_0x1F    not activated     64
ENG122229-ENG117751-Car_Function_List_BAP_Gen2-Reversible_Seat_Belt_Tightener_0x1F_msg_bus    Powertrain data bus     64
ENG122229-ENG125833-Car_Function_List_BAP_Gen2-Seat_Pneumatic_0x3B    not activated     64
ENG122229-ENG125834-Car_Function_List_BAP_Gen2-Seat_Pneumatic_msg_bus_0x3B    Comfort data bus     64
ENG122229-ENG139200-Car_Function_List_BAP_Gen2-Seatmemory_codriver_rear_0x3F    not activated     64
ENG122229-ENG139201-Car_Function_List_BAP_Gen2-Seatmemory_codriver_rear_msg_bus_0x3F    Comfort data bus     64
ENG122229-ENG139198-Car_Function_List_BAP_Gen2-Seatmemory_driver_rear_0x3E    not activated     64
ENG122229-ENG139199-Car_Function_List_BAP_Gen2-Seatmemory_driver_rear_msg_bus_0x3E    Comfort data bus     64
ENG122229-ENG117726-Car_Function_List_BAP_Gen2-service_interval_display_0x12    activated     64
ENG122229-ENG117727-Car_Function_List_BAP_Gen2-service_interval_display_0x12_msg_bus    Comfort data bus     64
ENG122229-ENG117748-Car_Function_List_BAP_Gen2-SideView_0x1E    not activated     64
ENG122229-ENG117749-Car_Function_List_BAP_Gen2-SideView_0x1E_msg_bus    not activated     64
ENG122229-ENG122329-Car_Function_List_BAP_Gen2-Special_Functions_0x35    not activated     64
ENG122229-ENG122330-Car_Function_List_BAP_Gen2-Special_Functions_msg_bus_0x35    Comfort data bus     64
ENG122229-ENG117762-Car_Function_List_BAP_Gen2-Start_Stop_reasons_0x27    not activated     64
ENG122229-ENG117763-Car_Function_List_BAP_Gen2-Start_Stop_reasons_0x27_msg_bus    Infotainment data bus     64
ENG122229-ENG117742-Car_Function_List_BAP_Gen2-SWA_0x1A    not activated     64
ENG122229-ENG117743-Car_Function_List_BAP_Gen2-SWA_0x1A_msg_bus    Extended data bus     64
ENG122229-ENG117704-Car_Function_List_BAP_Gen2-tire_pressure_system_0x07    activated     64
ENG122229-ENG117705-Car_Function_List_BAP_Gen2-tire_pressure_system_0x07_msg_bus    Suspension data bus     64
ENG122229-ENG117754-Car_Function_List_BAP_Gen2-traffic_sign_recognition_0x21    activated     64
ENG122229-ENG117755-Car_Function_List_BAP_Gen2-traffic_sign_recognition_0x21_msg_bus    Comfort data bus     64
ENG122229-ENG122331-Car_Function_List_BAP_Gen2-Trailer_Assistant_0x36    not activated     64
ENG122229-ENG122332-Car_Function_List_BAP_Gen2-Trailer_Assistant_msg_bus_0x36    Comfort data bus     64
ENG122229-ENG122325-Car_Function_List_BAP_Gen2-TV_tuner_0x2C    not activated     64
ENG122229-ENG122326-Car_Function_List_BAP_Gen2-TV_tuner_0x2C_msg_bus    Comfort data bus     64
ENG122229-ENG117730-Car_Function_List_BAP_Gen2-UGDO_0x14    not activated     64
ENG122229-ENG117731-Car_Function_List_BAP_Gen2-UGDO_0x14_msg_bus    Terminal 15     64
ENG122229-ENG117728-Car_Function_List_BAP_Gen2-unit_master_0x13    activated     64
ENG122229-ENG117729-Car_Function_List_BAP_Gen2-unit_master_0x13_msg_bus    Comfort data bus     64
ENG122229-ENG117712-Car_Function_List_BAP_Gen2-VPS_0x0B    not activated     64
ENG122229-ENG117713-Car_Function_List_BAP_Gen2-VPS_0x0B_msg_bus    Infotainment data bus     64
ENG122229-ENG117756-Car_Function_List_BAP_Gen2-weariness_rcognition_0x22    not activated     64
ENG122229-ENG117757-Car_Function_List_BAP_Gen2-weariness_rcognition_0x22_msg_bus    Infotainment data bus     64
ENG122229-ENG117714-Car_Function_List_BAP_Gen2-wiper_comfort_0x0C    activated     64
ENG122229-ENG117715-Car_Function_List_BAP_Gen2-wiper_comfort_0x0C_msg_bus    Comfort data bus     64
ENG122228-ENG127498-Car_Function_List_CAN_Gen2-Adaptive_key    Not available     8
ENG122228-ENG117690-Car_Function_List_CAN_Gen2-Adaptive_key_msg_bus    Comfort data bus     8
ENG122228-ENG117688-Car_Function_List_CAN_Gen2-Driving_school    Not available     8
ENG122228-ENG117689-Car_Function_List_CAN_Gen2-Driving_school_msg_bus    Infotainment data bus     8
ENG122228-ENG107608-Car_Function_List_CAN_Gen2-MFL    available.     8
ENG122228-ENG117681-Car_Function_List_CAN_Gen2-MFL_msg_bus    Infotainment data bus     8
ENG122228-ENG117683-Car_Function_List_CAN_Gen2-Oil_level    Not available     8
ENG122228-ENG117684-Car_Function_List_CAN_Gen2-Oil_level_msg_bus    Powertrain data bus     8
ENG122228-ENG117685-Car_Function_List_CAN_Gen2-PDC_audio_lowering    available.     8
ENG122228-ENG117686-Car_Function_List_CAN_Gen2-PDC_audio_lowering_msg_bus    Suspension data bus     8
ENG122228-ENG98891-Car_Function_List_CAN_Gen2-Reserved    Not available     8
ENG122228-ENG101416-Car_Function_List_CAN_Gen2-Reserved_1    Comfort data bus     8
ENG122228-ENG99458-Car_Function_List_CAN_Gen2-Reserved_2    Comfort data bus     8
ENG122228-ENG99668-Car_Function_List_CAN_Gen2-Reserved_3    Not available     8
ENG122228-ENG99892-Car_Function_List_CAN_Gen2-VIN    available.     8
ENG122228-ENG117687-Car_Function_List_CAN_Gen2-VIN_msg_bus    Comfort data bus     8
ENG122230-ENG142097-Dashboard_Display_Configuration-ability_switch_nav_maps    On     10
ENG122230-ENG122343-Dashboard_Display_Configuration-call_picture    On     10
ENG122230-ENG122341-Dashboard_Display_Configuration-coverart    On     10
ENG122230-ENG122340-Dashboard_Display_Configuration-crossroad_detail_map_compression_mode    RLE     10
ENG122230-ENG122344-Dashboard_Display_Configuration-crossroad_detail_map_resolution    resolution_1     10
ENG122230-ENG127006-Dashboard_Display_Configuration-crossroad_detail_map_transmission_mode    MOST_streaming     10
ENG122230-ENG142153-Dashboard_Display_Configuration-dynamic_icon    0    10
ENG122230-ENG127501-Dashboard_Display_Configuration-fastlist_most    OFF     10
ENG122230-ENG122338-Dashboard_Display_Configuration-navigation_map_compression_mode    H264     10
ENG122230-ENG122339-Dashboard_Display_Configuration-navigation_map_resolution    resolution_1     10
ENG122230-ENG127005-Dashboard_Display_Configuration-navigation_map_transmission_mode    MOST_streaming     10
ENG122230-ENG122342-Dashboard_Display_Configuration-stationart    On     10
ENG117913-ENG101574-Dimming_Ambient_Illumination_Information_Control_Unit-X1    0    6
ENG117913-ENG99557-Dimming_Ambient_Illumination_Information_Control_Unit-X2    50    6
ENG117913-ENG102140-Dimming_Ambient_Illumination_Information_Control_Unit-X3    100    6
ENG117913-ENG99777-Dimming_Ambient_Illumination_Information_Control_Unit-Y1    0    6
ENG117913-ENG100480-Dimming_Ambient_Illumination_Information_Control_Unit-Y2    50    6
ENG117913-ENG100773-Dimming_Ambient_Illumination_Information_Control_Unit-Y3    100    6
ENG117914-ENG101574-Dimming_Ambient_Illumination_Operating_and_Display_Unit-X1    0    6
ENG117914-ENG99557-Dimming_Ambient_Illumination_Operating_and_Display_Unit-X2    50    6
ENG117914-ENG102140-Dimming_Ambient_Illumination_Operating_and_Display_Unit-X3    100    6
ENG117914-ENG99777-Dimming_Ambient_Illumination_Operating_and_Display_Unit-Y1    0    6
ENG117914-ENG100480-Dimming_Ambient_Illumination_Operating_and_Display_Unit-Y2    50    6
ENG117914-ENG100773-Dimming_Ambient_Illumination_Operating_and_Display_Unit-Y3    100    6
ENG117916-ENG101574-Dimming_Illumination_for_Display_Unit-X1    0    12
ENG117916-ENG99557-Dimming_Illumination_for_Display_Unit-X2    10    12
ENG117916-ENG102140-Dimming_Illumination_for_Display_Unit-X3    100    12
ENG117916-ENG102936-Dimming_Illumination_for_Display_Unit-X4    150    12
ENG117916-ENG103548-Dimming_Illumination_for_Display_Unit-X5    220    12
ENG117916-ENG113992-Dimming_Illumination_for_Display_Unit-X6    253    12
ENG117916-ENG99777-Dimming_Illumination_for_Display_Unit-Y1    1%    12
ENG117916-ENG100480-Dimming_Illumination_for_Display_Unit-Y2    1%    12
ENG117916-ENG100773-Dimming_Illumination_for_Display_Unit-Y3    8%    12
ENG117916-ENG100631-Dimming_Illumination_for_Display_Unit-Y4    20%    12
ENG117916-ENG102174-Dimming_Illumination_for_Display_Unit-Y5    60%    12
ENG117916-ENG113993-Dimming_Illumination_for_Display_Unit-Y6    100%    12
ENG141636-ENG142049-Key_code_monitoring-monitoring_keycode_0x00_0x07    0    32
ENG141636-ENG142050-Key_code_monitoring-monitoring_keycode_0x08_0x0F    0    32
ENG141636-ENG142051-Key_code_monitoring-monitoring_keycode_0x10_0x17    0    32
ENG141636-ENG142052-Key_code_monitoring-monitoring_keycode_0x18_0x1F    0    32
ENG141636-ENG142053-Key_code_monitoring-monitoring_keycode_0x20_0x27    0    32
ENG141636-ENG142054-Key_code_monitoring-monitoring_keycode_0x28_0x2F    0    32
ENG141636-ENG142055-Key_code_monitoring-monitoring_keycode_0x30_0x37    0    32
ENG141636-ENG142056-Key_code_monitoring-monitoring_keycode_0x38_0x3F    0    32
ENG141636-ENG142057-Key_code_monitoring-monitoring_keycode_0x40_0x47    0    32
ENG141636-ENG142058-Key_code_monitoring-monitoring_keycode_0x48_0x4F    0    32
ENG141636-ENG142059-Key_code_monitoring-monitoring_keycode_0x50_0x57    0    32
ENG141636-ENG142060-Key_code_monitoring-monitoring_keycode_0x58_0x5F    0    32
ENG141636-ENG142061-Key_code_monitoring-monitoring_keycode_0x60_0x67    0    32
ENG141636-ENG142062-Key_code_monitoring-monitoring_keycode_0x68_0x6F    0    32
ENG141636-ENG142063-Key_code_monitoring-monitoring_keycode_0x70_0x77    0    32
ENG141636-ENG142064-Key_code_monitoring-monitoring_keycode_0x78_0x7F    0    32
ENG141636-ENG142065-Key_code_monitoring-monitoring_keycode_0x80_0x87    0    32
ENG141636-ENG142066-Key_code_monitoring-monitoring_keycode_0x88_0x8F    0    32
ENG141636-ENG142067-Key_code_monitoring-monitoring_keycode_0x90_0x97    0    32
ENG141636-ENG142068-Key_code_monitoring-monitoring_keycode_0x98_0x9F    0    32
ENG141636-ENG142069-Key_code_monitoring-monitoring_keycode_0xA0_0xA7    0    32
ENG141636-ENG142070-Key_code_monitoring-monitoring_keycode_0xA8_0xAF    0    32
ENG141636-ENG142071-Key_code_monitoring-monitoring_keycode_0xB0_0xB7    0    32
ENG141636-ENG142072-Key_code_monitoring-monitoring_keycode_0xB8_0xBF    0    32
ENG141636-ENG142073-Key_code_monitoring-monitoring_keycode_0xC0_0xC7    0    32
ENG141636-ENG142074-Key_code_monitoring-monitoring_keycode_0xC8_0xCF    0    32
ENG141636-ENG142075-Key_code_monitoring-monitoring_keycode_0xD0_0xD7    0    32
ENG141636-ENG142076-Key_code_monitoring-monitoring_keycode_0xD8_0xDF    0    32
ENG141636-ENG142077-Key_code_monitoring-monitoring_keycode_0xE0_0xE7    0    32
ENG141636-ENG142078-Key_code_monitoring-monitoring_keycode_0xE8_0xEF    0    32
ENG141636-ENG142079-Key_code_monitoring-monitoring_keycode_0xF0_0xF7    0    32
ENG141636-ENG142080-Key_code_monitoring-monitoring_keycode_0xF8_0xFF    0    32
ENG117921-Operating_and_Display_Unit_1_Proximity_Sensor_Basic_Adaptation    04 01 52 04 52 10 52 40 52 32 00 64 00 5E 01 5E 01 96 00 FA 00 14 00 14 00 14 00 14 00 FF FF FF FF FF FF FF FF 01 00 CE     40
ENG117809-p_damping_Display    5 ms    1
ENG117808-p_HMI_Display    13%    1
ENG122219-ENG122287-Radio_Level_Quality_Offsets-Set_AM_Quality_Level_Offset    0    2
ENG122219-ENG122288-Radio_Level_Quality_Offsets-Set_FM_Quality_Level_Offset    0    2
ENG117919-Startup_Screen_Sticker_HMI    00 01     2
Elapsed Time: 00:36
GolfAlltrack
and yea, I do have the Euro parking light on my cluster, although i sorta prefer the euro symbol vs the "PARK" light. I'm not sure why the audio/media disappeared. When i got the car back from the shop, i was also missing nav, driver assist, and phone. I was able to code those back in but haven't been able to find where I'm missing the media/audio/radio to display.
Cuzoe
Los Angeles
Nothing stands out in the adaptations... probably long coding in the instrument cluster. I'll get some pictures of the long coding helper in my car here in about an hour.
Your BCM and Gateway will not support selecting colors in the dash via the infotainment screen.
You can set the dash to Red, Blue or Gold/Yellow using adaptations, see the link I posted previously...
https://www.golfmk7.com/forums/inde...nfo-display-themes-coding-spreadsheed.357983/
You can also set the "style" of it... Golf, GTI, Golf R, Alltrack
Cuzoe
Los Angeles
Module 17-Instruments... long coding... use the helper.
Check the boxes for what your car has
Byte 1 Bit 5 - Cruise Control System active on my car, which has ACC
Byte 4 Bit 2 - ACC (Adaptive Cruise) active on my car, which has ACC
Byte 4 Bit 6 - Lane Maintenance Assist I believe this is lane keeping, which you state you have
- If you select this then also select Byte 11 bit 1
Byte 5 Bit 3 - Lane Change Assist I believe this is blind spot monitoring, your scan doesn't show the rear radars so probably leave unchecked
- If you select this then also select Byte 11 bit 3
Byte 5 bit 7 - Audio System/Display Installed this should get you your media options
GolfAlltrack
That fixed it!! Thank you so much! Apparently I had to click yes to VCDS experimental coding to get those other bits to appear. Now we're back to how it was before. Thank you
