Cuzoe
- Los Angeles
No worries... I always choose yes to view experimental... often it will let you see neat options for things not normally featured on your car. They'll be in Germain, and they might not work, but you can always undo the change.
- Speaking of which... you should run an Auto-scan (after clearing faults) and get adaptation maps for all the modules (just select all, and let it run).
- Save those away somewhere, read-only. That way as/if you experiment/learn about the modules and options you can always get back to how it was, with everything working.
- Also, unless a set of changes are dependent on each other... make one change at a time. I've gotten excited and checked/unchecked several boxes and broken things, albeit temporarily.
- In the VCDS folder there is a log of changes made, but you'll want to avoid having to refer it to fix/restore things you broke. Looking at your saved scans is much easier.
Your car already has the front radar, and your scan shows park assist which means you have the bi-directional rear ABS sensors... you can almost certainly get ACC retrofitted without needing any hardware changes.
If you're interested in that, now or in the future, there are a few folks you might reach out to. I'll leave them unmentioned unless you're interested.
