So I'm back, responding to myself, haha. But if somebody whose AID map zooms in and out with the right side MFSW button arrows could post up and auto scan that would be awesome! Or really just the long coding of the MFSW Buttons, which is a slave module to 19-Gateway.
I just retrofitted an Mk8 wheel and for the first time noticed that module. There are no descriptions in VCDS long coding helper. I would bet good money that's where we can configure the buttons to either zoom or scroll through recent destinations.
Here the scans you wanted. The up and down buttons on the right side zoom my map in and out
Address 16: Steering wheel (J524) Labels:| 5Q0-953-549.clb
Part No SW: 5Q0 953 521 K HW: 5Q0 953 569 A
Component: Lenks.Modul 075 0175
Revision: FF032032 Serial number: 20140716500407
Coding: 0400
Shop #: WSC 00046 000 00000
ASAM Dataset: EV_SMLSVALEOMQB 001015
ROD: EV_SMLSVALEOMQB.rod
VCID: 3A2D386DCCD0170BC16-806E
No fault code found.
Address 19: CAN Gateway (J533) Labels:| 5Q0-907-530-V1.clb
Part No SW: 5Q0 907 530 AJ HW: 5Q0 907 530 M
Component: GW MQB High 212 2246
Revision: -------- Serial number: 04031910801620
Coding: 0101000830080000FB00001A1C0F00000000000000000000000000000000
Shop #: WSC 12345 123 61029
GVL: 015C3C100000000040DC90008006480000000000000000000000000000000000
ASAM Dataset: EV_GatewConti 013020
ROD: EV_GatewConti_013.rod
VCID: 79AFE7618956DC1388C-802C
Generator:
Multifunction steering wheel control module:
Subsystem 2 - Part No SW: 5G0 959 442 N HW: 5G0 959 442 N Labels: 3C8-959-537.CLB
Component: E221__MFL-DC1 H06 0038
Serial number: 27130000784820103284
Coding: 28FFFF
1 Fault Found:
131689 - Rear View Camera System Control Module
U104C 00 [009] - No communication
[Timeout Knoten 0x69 / 6C - Steuergerät für Rückfahrkamerasystem]
Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 1
Reset counter: 196
Mileage: 170001 km
Date: 2022.05.05
Time: 15:26:57
Terminal 30 power supply: 12.0 V
Terminal 15: On
