NAR Golf 1.8 TSI MK7 to 7.5 Tail Light Issue
Cssoz
Toronto, Canada
Golf 7, 2017 1.8T
My adaption (coding) for the taillights only via obd11
Adaptation
Control unit: 09 Central Electrics
Values:
Dimmwert EF 20:
Old value: 28
New value: 10
Mileage: 77665 km
Date: 2020-07-17 12:46
Adaptation
Values:
Dimmwert EF 21:
Old value: 20
New value: 10
Mileage: 77665 km
Date: 2020-07-17 12:45
Adaptation
Values:
Dimmwert EF 21:
Old value: 10
New value: 20
Mileage: 77665 km
Date: 2020-07-17 12:10
Adaptation
Values:
Lasttyp 20:
Old value: 14 - kombinierte Blink- Bremsleuchten
New value: 34 - LED Bremsleuchten
Dimmwert EF 20:
Old value: 36
New value: 28
Lichtfunktion C 20:
Old value: Blinken links Dunkelphase
New value: nicht aktiv
Lichtfunktion B 20:
Old value: Blinken links Hellphase
Mileage: 77665 km
Adaptation
Values:
Lichtfunktion B 21:
Old value: Blinken rechts Hellphase
Lasttyp 21:
Lichtfunktion C 21:
Old value: Blinken rechts Dunkelphase
Dimmwert EF 21:
Old value: 36
New value: 10
Mileage: 77665 km
Date: 2020-07-17 11:49
Adaptation
Values:
Dimmwert AB 27:
Old value: 127
New value: 100
Lasttyp 27:
Old value: not active
New value: 38 - LED Blinkleuchten
Lichtfunktion A 27:
Old value: Standlicht allgemein (Schlusslicht, Positionslicht, Begrenzungslicht)
New value: Blinken rechts Hellphase
Mileage: 77665 km
Date: 2020-07-17 11:43
Adaptation
Values:
Lasttyp 27:
Old value: 36 - LED Kleinleistung
New value: not active
Mileage: 77426 km
Date: 2020-07-14 08:31
Nissanskylinen1
Toronto
'16 R w/DCC & Nav
Thank you for the coding!
So the coding you have done here does the following:
1) Turn Channel 27 to not active. This turns off ambers on all the time.
2) Change Channel 27 so that it blinks on when you turn the signal stalk to the right. The dimming value is also now 100 when it the turn signal is on to the right. Your hazards (both sides) will now come on whenever you turn the signal stalk to the right.
3) Right outer tail light - no more blinking on turn signal when stalk is to the right. Change the type to brake LED only. Dim DRLs to 10.
4) Left outer tail light - no more blinking on turn signal when stalk is to the left. Change the type to brake LED only. Dim DRLs to 28. You now have no left turn signal programmed for your car.
5&6) Dim the DRL from 10 to 20, then changed your mind and put it back to 10 on the right outer tail light.
7) Change the DRL dim to 10 on the left outer tail light to match the right side.
The changes above mean that when you go to indicate a right turn, both ambers turn on. When you indicate a left turn, you have no turn signal on at all.
Can you confirm that when you turn your left turn signal on, the tail lights indicate a left turn signal? If it does, where in the adaptations menu do you have it so that your left turn signal works?
I tried your settings on my car. When I indicate right, the hazards turn on. When I indicate left, no signal turns on.
Cssoz
Toronto, Canada
Golf 7, 2017 1.8T
@ZERO815 could you please kindly help out with your insane knowledge?
Nissanskylinen1
Toronto
'16 R w/DCC & Nav
Here are my codings currently. My Leuchte 20 is identical as Leuchte 21 other than the fact that the turn signal is the other way.
If I turn Leuchte27 to active, my turn signal will cause my hazards to turn on.
keggo
California
TDI S 6spd
Thank you @Cssoz! I’ll go through my coding in a bit, but yes, I also have the AKD taillights with the yellow wire. Everything is connected and all other functions work right now.
Cssoz
Toronto, Canada
Golf 7, 2017 1.8T
Thank @ZERO815. I just decoded the info like a student and used it. =D
keggo
California
TDI S 6spd
Haha Thank you @ZERO815! Just need to scrub through the coding and make sure there isn’t some extraneous setting. In the meantime, I have the inner and outer lights operating out of phase with one another for turn indication. Haha Just really want the dynamic ambers working x)
Glad to see others have bought the exact models (tails and headlights) as me.
Cssoz
Toronto, Canada
Golf 7, 2017 1.8T
ya these lights are the best I have seen. not to mention it's on a VW, Audi's new gen OEM lights are amazing (Euro spec so far)
but all the regular cars out there, even JDM luxury brands are using cheap or halogen turn signals LOL
Cssoz
Toronto, Canada
Golf 7, 2017 1.8T
@Nissanskylinen1 is your
Leuchte27NSL RC6 changed TO 38 - LED Blinkleuchten ?
this is what got my dynamic signal working
Nissanskylinen1
Toronto
'16 R w/DCC & Nav
Any luck?
Cssoz
Toronto, Canada
Golf 7, 2017 1.8T
Hey, Summarized in point form or steps of what you have done and remaining issues.
So Zero815 can help us out! As Zero have done for me specific to my case
VW 4 Life <3
keggo
California
TDI S 6spd
Okay, so:
1. I installed the lights including running the yellow wire on both sides.
2. Reset coding back to stock from the previous mod so all the stock halogens brightened for braking.
3. Noticed the indicators were on, solid, during running lamp mode. Figured out the Leuchte27 thing and turn it to not active.
4. Couldn’t figure out the coding so I took to the internet and found this post linked from another post. Haha
All my lights, inner and outer, were set to 14 - kombiniert, but according to #5 on @ZERO815’s sheet, I changed 23SL and 24SL to 43 - Allgemeine LED. The tail lights looks great otherwise. The running lights and brake lights look fantastic. I have also tested modes on Leuchte27 to make sure the indicators work, and they do, just not as individual indicators.
I’ll head out there right now and see what I can try. I haven’t tried setting Leuchte27 to Blinkleuchten.
keggo
California
TDI S 6spd
Agreed!! I have basically gotten sequential indicators all around now (once I get the rears working lol)
keggo
California
TDI S 6spd
Here’s my baby, btw. :3
P.s. I know she’s dirty, but with how much I drive between the SF Bay and LA, it’s hard to keep bug guts and road grime off her :(
