Cuzoe
- Los Angeles
I'll add (bad) pictures from my phone later... but finally tore the car apart to get several retrofits done. While in progress I decided that I would retrofit DCC (while I'm in there ). This is going semi-smoothly, with my mistakes and struggle documented here. The following is officially in progress and/or done...
Heated seat wiring (and replacement of A/C controls with heated seat buttons)
Blind spot monitoring sensors installed and wired (wired to door disconnects, but have done the wiring in the doors yet)
Parking aid/assist sensors (6 front, 6 rear) installed in bumpers, wiring installed
Re-pinned connector for rear sensors, aftermarket harnesses are intended to run on the left side of car (and wired accordingly, but OEM is right side so...)
Replaced front crash bar with proper one for ACC radar (see post above this)
Installed 2" Ecohitch in rear (this took some "massaging" and was missing hardware, it's on and extremely solid but I cannot recommend)
Front fogs installed in bumper
Wiring installed for all 6 shifter surround buttons, which are also installed
Footwell lights and wiring, front and rear
Dieselgeek Superpin (car still in pieces so haven't driven but eliminated some slop, will give opinion once I drive)
Motion sense alarm wiring/disable button on B pillar
Added the dealer switch to demo Helix system to my amp rack (would like to put it somewhere accessible in car but the box is, relatively, massive so I need to find a place)
Started sound deadening of the rear arches and seat area
Updated the OP, blah blah blah.
