Cuzoe
- Los Angeles
This post is for @Drewpul, regarding soundaktor retrofit.
You need 3 parts (plus hardware), and to do some wiring...
Speaker - 4H0 907 601 D (Item 1)
I would also try to get this with pigtail... https://www.ebay.com/itm/155594876308
Module - 5G0907159 (Item 2)
You can also get xxx159B, 159C, 159D. I would just find one with the pigtail to make your life easier.
You may have better luck finding 8K0907159 in the US, these will will work as well.
Bracket - 5G0906468A (Item 3)
Picked up new, less than $20 from the dealer.
I picked up all new hardware...
2x N01508210 (Item 4)
1x N10653201 (Item 5)
2x N10335206 (Item 6)
Different view, item 2/3 here...
Power from cabin fuse panel, fuse SC34 (there will be other things wired to this, but you can tap in at TIUL T17m (brown connector), left kick panel.
Ground from wherever there's a ground... easy one is the stud just aft of the battery... your wiring is going to be routed past that location anyway.
And you need powertrain can bus, which you can also get from TIUL T17m (brown connector), left kick panel.
Then two wires from the module jump straight over to the speaker.
You will have to flash custom firmware to the module. Factory un-modified firmware has VIN/engine type lockouts. I can, at some point give some pointers on how to flash with ODIS, but that can info can be found elsewhere. Anyway... here's a thread by @Chillout on the modified firmware (big, gigantic credit to him for the work making this possible, buy him a coffee).
I have retrofitted driving modes (FPA) to my car, but for simplicity lets assume a car with no driving modes. You will want to load one of the "No-FPA" firmware versions. I am currently running the firmware from the Audi RS4/RS5... it sounds awesome. But as mentioned I have driving modes so I can set the Soundaktor to Off, Comfort/Eco, Normal or Sport. The "No-FPA" version will default to Sport mode which may be a bit much on daily basis. You'll have to try a few until you find something you like. Recently Chillout has modified some Porsche Cayenne firmware, which I will be trying soon .
