Those with the oil weepage, are any of you guys STOCK?
I believe i have weepage. I cleaned the engine way the other day because i thought it could have been from when i changed the oil. If it is in fact weepage then i am stock other then springs
Is there supposed to be an (outer brim) “secondary” o-ring already on the cap? Or are you guys adding the o-ring as an extra measure?
I like traffic lights, I LIKE TRAFFIC LIGHTS, especially when they’re green, especially when they’re green!
Thanks for this. I ordered the Viton oring tonight. Hopefully it stops the seeping on my stock 16r.This is an obvious defect. Everyone probably has this issue. Here's a few more places to buy.
I prefer getting things from in USA. High quality Viton o-ring that will probably never need replaced.
http://www.oringsandmore.com/viton-fkm-o-ring-44-x-2mm-price-for-1-pc/
Same as eBay item.
48mm x 44mm x 2mm Rubber Oil Seal O Ring Gasket Washer Black 10 Pcs https://www.amazon.com/dp/B00N3VGC0U/ref=cm_sw_r_other_apa_i_YEGyBbB551C94
Teflon tape around the threaded part of the oil filler cap. It works 50¢ fix
Sent from my SM-N960U using Tapatalk
Disagree. As you can see in the picture this was the "revised" yellow oem cap. Still leaks brand new even with viton o-ring.The cheapest option is rarely the best IMO, the reason these start to weep is that the original seal on the cap becomes compressed, the real answer is a new cap, in this case aftermarket may be the best option (not tested however) as they may use a different seal that doesn’t harden so easy, in the mean time a silicone O-ring appears best quick fix as it’s the most compliant and doesn’t harden making the cap hard to remove.
Why spend $80 for aftermarket and perhaps still have it leak. Ecs tuning oil cap $80
