Going to take the opportunity to record OEM+ updates to my 2015 MK7. I'm not that much of a car guy but I hope to learn a lot through the process. Thanks in advance for anyone who follows along
TLDR Part List;
- 02/02/2019 - After my 2009 City Golf (MKIV) was written off in an accident, I used the cheque to put a down payment on a used 2015 2-Door Autobahn GTI (DSG) with 146,000km. I decided to go with high mileage due to affordability and a 1-owner record with an extremely detailed service history through one VW dealership. It was the only 2-door in the province I could find at the time. Purchased the car for $16,000 CAD out the door.
- Replaced under VW corrosion warranty;
- New OE driver’s side door.
- New OE tailgate.
- New OE front fenders (pair).
- New OE master switch.
- New OE front bumper. No more License plate holes..
- New OE shifter/leather boot.
- New OE european rear cloth headrests.
- New OEM fuel injectors P/N 06A 906 036 Q.
- New OEM runner flap sensor P/N 06K 907 386 D.
- OE TCR steering wheel.
- OE PP brake calipers/carriers (front only, swapped up from non-PP). Black Badgeskin decal overlays.
- OE 19” Pretoria wheels (factory black). Sourced from a 2019 Golf R.
- OE 8” touchscreen upgrade from 5.8”. Sourced from a 2016 GTI performance model.
- OE MIB2 Discover Pro unit retrofit P/N 3G0 035 047. Sourced from a 2017 Golf R.
- OE HPFP P/N 06L 127 025 N (60,000 miles used).
- OEM Roof Rack P/N 5G3 071 126.
- OSRAM LEDriving headlights.
- OSRAM LEDriving dynamic LED mirror indicators (black).
- Volkswagen (Helix) Subwoofer
- NGK Laser Platinum Plugs.
- US Millworks aluminum license plate mount with tow-hook bracket.
- deAuto red accented LED upgrade for footwells. Having bad flickering with these..
- APR 27mm black wheel lugs with OEM black wheel caps.
- Continental Extreme Contact DSW06+ tires 235/35/19. (Pretoria's for Summer).
- Continental VikingContact 7 tires 235/45/18. (Austin's for Winter).
- OE front fog lights + Kufatec wiring harness, will be a 2024 summer project/retrofit.
- Supporting OE parts need to be ordered;
- 5GM.853.665 D9B9 (Left Trim)
- 5GM.853.666 D9B9 (Right Trim)
- 5GM.853.949 9B9 (Left, fog lamp end plate)
- 5GM.853.950 9B9 (Right, fog lamp end plate)
- 5GM.807.723 A (Left bumper support retainer w/fog opening)
- 5GM.807.724 A (Right bumper support retainer w/fog opening)
- N91.090.701 (Fog Lamp Bolt x4)
- 000.979.009 E (Fog light trigger wire)
- Euro light switch P/N 5G0 941 431 BD.
- Euro tails with @ZERO815 harness.
- Clubsport center wheel caps P/N 5G0 601 171 B LYC
- Camshaft position sensor P/N 04C 907 601 K
- Ignition switch P/N 5G1 959 839 A3Q7
- Upstream 02 sensor P/N 06K 906 262 CS
- Hatch emblem P/N 1K0 853 675 AJ 739
- Various Badgeskins, will update with pictures when installed.
- EQT Coil Grounding Kit
- Tiguan Engine Cover
- Exhaust options;
- Clubsport muffler with custom diffuser/Golf R tips or
- Remus Quad-tip exhaust.
- Oetteger wing P/N 5G0 071 644 BGRU
- EQT coilovers, suggestions welcome. Currently driving around with a snapped coil.
- IE Gen 3 intake.
- IE Gen 2 intercooler (Or OEM Golf R).
- Refinish Pretorias/Ceramic coat.
- EBC Brakes 272mm rear slotted rotors.
- EBC Brakes 340mm front slotted rotors.
- EBC ‘Red Stuff’ performance brake pads.
- APR Braided SS brake lines.
- Roof Box.
- Puddle lights from Rocketwire.
- Folding mirror retrofit. USP motorsports has a great kit.
- Carbon hood.
