Diggs24
- de plains! de plains!
- 2015 GTI
Works for everyone but you, same as last time. Look into it.Link doesn't work for me.
https://gensportunited.com/need-colder-spark-plugs/
After reading that I think that I'll just go back to the stock heat range.
I thout they were plutonium. But maybe they are ruthenium.
The article states that if the tuner recommends a colder plug, then listen to the tuner. I think thats important to point out since EQT recommends a colder plug for even stage 1.
The article says right after that statement you copied that even for a car with full bolt ons you won't see any benefits so don't waste your time or money. It's always best to quote the whole sentence not just part of it.
Gen coupe page.... full bolt on could be the V6 NA motor. In which case yes, NA bolt on car isn't adding much power at all and cylinder temp/EGT increase is minimal.
Full bolt on mk7 totally different.
I've always viewed it as an "if it's not broke, don't fix it" thing. If stock heat range isn't giving you issues, then there's no reason to go to a colder range.
One of the big reasons you go colder spark plugs is to minimize the chance of getting pre-ignition. Note this is different than knock. But it's a very grey area because there's really no way to detect pre-ignition and there's a lot of variables at play. You're most likely to run into pre ignition issues when running the car really hard, think road course etc. Most people never push theirs cars this hard...very different scenario than having a 5-10 second pull on the on ramp or whatever. I think tuners recommendations are naturally on the conservative side of things, and running a colder plug is safer, across all driving conditions etc.
I'm "only" running 1 step colder plugs on my 700hp corvette, almost doubled the HP, but if I were to take it to the track I'd probably get some colder plugs/race style plugs to be safe.
Bottom line yeah it's a grey area for sure. I'm running RS7/RS3 plugs and don't seem to be fouling up fast or anything. I'm OK with 15k-20k interval on the conservative side too. I can't think of any advantages to going back to stock heat range, I'm not trying to extend the service internal of my plugs.
