I had a variable weekend at VIR. The first day, I had some major instability at the rear under braking. Everyone was complaining of low grip as the track had not rubbered in as there was no event prior to our DE.
The second day this disappeared but I had also backed up my brake zones. So ???? Not sure what was happening.
I need to check my alignment. Maybe my zero toe at the rear is too aggressive for the track???? The car felt fine around the corners. Just a handful under braking. Im also curious whether I have a rear caliper that is hanging up???
I’ve got 100k on my car now. They may be due a rebuild. I’ve been checking the rotor temps with an IR gun and the RHS is running 20-25F hotter than the LHS.
Engine ran fine after the carbon cleaning and injectors. Actually ran the AC a couple of sessions
@GTIfan99. I now have the cooling capacity to do that
I did get a secondary air code. I need to pull my air filter out and check the secondary air lines and sensor plugs. Not sure if its related to the work I did on the intake or just coincidence….????
I’ve already changed out the combi valve $$$$ about 40k ago. So Im a little frustrated with my car right now.
I also picked up a screw in my tire in the paddock on the 2nd session of the third day. I thought the ticking sound was a rock that had stuck to the tire. Took a few laps for me to realize something was not right. Had a huge understeer moment at T-10 (right front tire going down). Decided to come in, but I had ruined the tire by this time. I am shopping for a new set of HPDE tires.
So a word of caution. If you suspect something is wrong come in and check it out. Missing out on track time is OK. It sucks but it is not worth wadding up your car. I should have investigated the ticking noise before heading out. Not the first time I have picked up a screw in the paddock. If you make two mistakes in a session, come in and regroup. De-hydration, fatigue, heat and lack of sleep can mess up your concentration. As a driver you need to bring your A-game ALL the time.
It was AWESOME to see so many GTi’s at the track. Got to meet
@DerHase. There were 10 GTi’s & R’s at VIR. The new Mk8 R looks really good in the flesh.
