VWR dog bone mount replaces everything.
Fuck now I want this lol
Christ. There is honestly too many freaking options for the same part. I'm generally pretty knowledgeable of the various options for a given mod for these cars, but I'm starting to feel like I don't know shit.
Just the ECS tranny mount with everything else stock? That would effectively make the tranny mount a pivot for the rest of the drivetrain to twist around. I believe you've got to go poly on the motor trans. You can do a softer insert like the powerflex diesel or 034 aluminum if you want to keep the NVH down. But rubber mounts just suck.
Sent from my LG-H910 using Tapatalk
Do I need to remove the subframe to install any of the parts you guys have mentioned in this thread?
Thanks.
What is the installation like on this? I've heard that that it is excessively involved. I'd like to try this after installing and then removing 034 due to NVH...
034 caused you NVH? It's the most NVH-friendly insert on the market. If that didn't make you happy the VWR is gonna make you even less happy, and you'll be out a couple hundred in installation, or several hours of your own time.
Sorry for digging up an old thread but has anyone replaced the lower oem puck? Will I need something to press the oem puck in? I'm pulling my hpa kit and replacing the oem to go back to stock. Would like to know what I'm in for. Thanks in advance!
putting an oem puck in is a pain in the ass. it's super tight and deforms( becomes oval ) at the portion where the outer edge of the puck is only 1/2 height, in other words the part where the dogbone arm goes in between the upper and lower pucks
good luck, let us know how i went for you
