Recently Installed 42DD 02 spacer about a week ago and I've noticed at under cruising speeds keeping the throttle position at a constant the afr's will jump around from 13 then go to 16 ended up getting P013E for rich/lean. Also read on another thread that it could be the way the spacer is angled and could be leaking and double checked to make sure it was secured. Had no problems on my tune without using one before just decided to get on for being able to pass inspection has anyone experienced this or could it possibly be liked to map sensor?
