Hello fellow Mk7 GTI enthusiasts.
TLDR:. Is upgrading both the Rear Stabilzer Bar (RSB) and Front stabilzer bar (FSB) worth doing as a pair, versus only upgrading the RSB?
My goals and introduction. I am looking to dial out the understeer on my GTI (2017 Autobahn with PP/DCC). The car is stock right now except for JB4. I am about to start on handling upgrades. The car will mainly be driven on streets (and during winter in Minnesota ;-) and occasional spirited driving and HPDE.
I want to sharpen up the handling without ruining daily driveability. My previous car was an NC Miata, and while I know I can't expect to get the level of steering feedback I loved on that car, I do want to make the GTI more neutral (get rid of the OEM understeer) and increase the steering response (to the extent that is possible).
I also value a smooth roll transition which is fundamental to my question about replacing both RSB+FSB versus the RSB alone.
Is a matched RSB+FSB from a reputable vendor going to result in a better car balance transition in a corner,? Or is the subframe procedure such a PITA for me or trusted mechanic that the FSB would not be worth it? (I.e are there good RSB only upgrades that don't create poor roll transition)
Thanks in advance for input based on real world experience.
I'm on stock springs, with Koni FSD shocks, 034 camber mounts, and Powerflex offset LCA bushings (roughly -2.8 deg camber up front, -1.8 rear for reference).
I have H&R 26mm front bar, and 26mm rear bar.
Normally they pair a 28mm front with the 26mm rear, or the 26mm front with the 24mm rear.
I chose to do 26 at both ends as I figured I didn't want to add more roll stiffness up front and make it understeer.
I've driven the car with stock front bar and 26mm rear. It felt good.
Added the front bar and ran with it on soft. Felt better.
In May of this year I got the chance to use a full day for test and tune going out on track as much as I wanted over the course of 8hrs. Front bar on full stiff was notably faster (plus was able to carry more speed in near every corner). Makes me want to try and test out the 28mm front bar... but the reality is that the gains would likely be so small (if any) that any testing would prove inconclusive.
Tire wear is pretty good as it is now, if anything it needs more camber up front.
I also have data from other cars with VERY expensive suspension setups... and this one is faster than or within a couple mph min corner speeds in every turn at VIR. It's a VERY good bang for the buck setup.
People get way too drawn to lowering when it hurts geometry on a strut car IMO. Especially when there is limited bump travel. If you hit the bumpstops mid-corner (and/or if they're progressive bump stops and you compress them too much) then the front spring rate goes closer to ∞ and the car will push like a freight train.
I have videos from all the below outings on my channel. Keep in mind from Dec to Feb (going from stock front bar to 26mm front, both with 26mm rear) was also with a power increase, and from RT660 to V730 tires (less grippy, I hate them).
I do suspect that if you don't also add camber up front, that a bigger front bar may well make the car push worse.
10/23/2022 | Track Daze (Fastivus) | Summit Jefferson Ext. | 01:26.10 | Put DS1.11 rear pads on, along with 26mm H&R rear sway bar. Car felt amazing. DO88 intercooler was also installed which helps greatly with consistency. Fastest lap was lap #4 in final (third) session of the day. Every time prior it has been one of the first couple laps out. Hot tire pressures seemed best at 31-32psi up front, and 33-34psi rear. Day started out at ~40F ambient in first session, ended around 65F. |
12/10/22 - 12/11/22 | TSCC | VIR Full | 02:17.31 | APR trans tune installed. 034 upper/lower torque mount inserts installed. Car felt great. Ran 32psi front/31psi rear hot. No problems with IATs at all, plateud at +10F over ambient under throttle. 40F-50F most of the weekend. |
2/10/23 - 2/11/23 | TSCC | VIR Full | 02:14.97 | 8BP ECU tune added. H&R 26mm front sway bar, Superpro front forward LCA bushings, RS3 solid LCA rearward bushings installed. Kumho V730(245/40R17) added. Switched to Endless RF650 brake fluid. Zero problems with brakes. Front tires seemed to get greasy very quickly. Targeted 31/31psi. Per Andy Hollis may want to try a bit less pressure. Also tires being brand new may have needed this first "scrubbing in" to get better. Tire wear seemed very good with the front sway bar added (which was run on the soft setting, did not experiment with the harder setting). |
5/26/23 - 5/28/23 | Private Test Day/TSCC 2-Day HPDE | VIR Full | 02:12.55 | Running my own "OS" tune now. Similar overall power to the prior used 8BP tune (same overall speeds on straights, etc). Swapped Superpro LCA bushings for offset Powerflex bushings for more camber. Tested back to back stiff vs soft sway bar with 30 and 35psi tire pressures over 4 sessions. H&R 26mm FSB set to STIFF with 34-35psi hot worked best. Brakes up front get grabby as session goes on. AAT ~62F when best lap was set in second session of the morning. Tire wear is excellent. Front rotors/pads brand new for this event (DS3.12/Zimmerman blanks). Potentially VCDS tweaks to blame for brake problems. "Brake booster" set to 2 at this time, to be experimented with before/at next event. |
7/20/2023 | SCCA TNiA | VIR Full | 02:18.52 | 90-95F ambient temps, ran in the afternoon only. "Brake booster" was set back to 5 and didn’t really have any notable issues with brakes, but heat was slowing the car itself down. Had excessive KR, believe due to oil from PCV being ingested. 10-15 deg avg KR at times. Consistently 5 deg of KR in every session. First time with hood vent installed, even in the heat was able to beat on the car the entire time with no coolant problems, and oil never exceeded 275F. PCV needs taken care of and then heat situation re-evaluated. Car seemed much more stable at speed with the hood vent addition. |
Keeping the front end from getting into positive camber (as badly) is why the FSB is a huge help on these cars in particular.
I'm in more of a "get it mostly right and then just drive the car" kind of mindset. Too many people in the VW community buy coilovers and every damn suspension accessory under the sun and they're still 4 seconds off of Spec Miata times. I've done stuff to my car obviously - but it's essentially all to get tire wear under control and not get stupid over curbs at 120mph... going faster is just a side benefit.
