U know. It is oil based. In a way, isn’t that bad for the rubber?Based on my recommendation Discount Tires is now using mayo to mount new tires on the wheel. They like how well it seals the bead.
He definitely meant synonym as is they’re the same.Please explain.
The oil and water in Mayo stick together.U know. It is oil based. In a way, isn’t that bad for the rubber?
Based on my recommendation Discount Tires is now using mayo to mount new tires on thewheelrim. They like how well it seals the bead.
No, I meant synonymsDid you mean synonymous?
syn·o·nymPlease explain.
I dunno man. Find me an example where someone mounted a tire to a wheel/rim using Mayo. I think it’ll be the only way to settle this
Jim’s service bays don’t use lubeI dunno man. Find me an example where someone mounted a tire to a wheel/rim using Mayo. I think it’ll be the only way to settle this
Um it was a joke like all the other ones about mayo. You didn't really think Discount Tires would do that did you?I dunno man. Find me an example where someone mounted a tire to a wheel/rim using Mayo. I think it’ll be the only way to settle this
Switched to mayo so you can lick your fingers clean.Jim’s service bays don’t use lube
Somebody call the police
There were not emojis JimUm it was a joke like all the other ones about mayo. You didn't really think Discount Tires would do that did you?
