snobrdrdan
former GTI owner
- Southeast Michigan
11:46 to 11:50
A huge sigh, then: "it's fun, isn't it?"
Recently helped install H&R springs on an S3, and due to my eternal paranoia about aligning the struts correctly at the top had an epiphany. Mark the underside of the strut mount with a Sharpie to that you can look up and visually confirm that they're positioned correctly.
Just point the indicator on the top of the strut mounts towards the center of the car. As long as that's done the three holes will align which means it's on correctly. If the holes don't align you know it's wrong.
orly? Didn't know that!
Thanks for this thread, its really helpful. One question I have is whether you think it is worthwhile replacing the bump stops and spring seats on the front shocks when changing the shocks? How long are these things generally good for?
My car currently has 5k miles. I was planning on doing the spring install when the whether gets warm at about 7k miles. I'm planning on using the 2x4 method and replacing the following bolts:
STRUT MOUNT BOLT x6 Part Number: N-101-277-07
STRUT BOLT x2 Part Number: N-909-548-02
STRUT LOCK NUT x 4 Part Number: N-101-064-02
STABILIZER LINK BOLT,x2 Part Number: N-107-765-01
STABILIZER LINK LOCK NUTx2 Part Number: N-901-838-03
LOWER CNTRL ARM MOUNT BOLT x2 Part Number: N-106-405-01
I also plan on replacing the bearings as well. Should I replace the strut mounts as well with the heavy duty ones ECS sells? Or should I be good considering the miles are relatively low. Preferably, I'd like to do it right the first time rather than having to redo the install later on.
