Retrofitting Lane assist camera without changing windshield?
Reaper1
Here is the "translation" for the 3q0 camera.
  • lane assist camera coding.txt
Reaper1
Ok, now i have every thing working.
Obd11 calibration:
1 place VAS6430 in wall 1,30m (from floor)
2 put car 1,5m away from board (from wall to the center of wheel ,measure in the floor .
3 measure 4 wheel arches .
All the next steps change search calibration target to Grundeinstellung
SEQUENCE IS IMPORTANT
OBD11:
4 - go to module A5 change type of diagnostic to vw
5 -go adaptation distance to calibration field 1500m confirm
6 -go adaptation body height wheel house edge
Type your measurments confirm
7 -go adaptation calibration target position
Just confirm
8 - go adaptation axel offset
Just confirm
9 - go basic configuration search calibration target
10 - go basic configuration initial online configuration
11 - go basic configuration Static calibration costumer service
12- change type of diagnostic to end of assembly line
13 - go basic configuration static calibration end of assembly line
Wow man that looks awesome, great work!.
Camarao69
Portugal
Did not have time to take pictures but in my case as the weather can be hot the doble side tape didn't hold on, but i think the fault was the vinyl i used that expanded so i had to paint the glass with glass primer, first did a laser cut vinyl to define better the borders ,put it on the glass and then painted it, e saw this on drive2 many times , for now it is working.
Lane assiste, trafic sign and light assist.
Nuje
Island near Vancouver
2015 Sportwagen TDI
Obd11 calibration:
OBD11:
Just confirm
Just confirm
Great stuff! It was the ADAPTATION channels I was missing (I'd tried originally in VCDS, but didn't get anywhere with that).
Thank you for posting the instructions / step-by-step; gonna try that first chance I get!
Reaper1
You should try to do a first calibration which then the camera calculates its actual height and move the board up or down accordingly for a perfect static calibration.
Reaper1
Update on my 3Q0 camera:
Bought one brand new and one used, and i cant seem to flash them or even code them, maybe my car is too old for this camera, will try on a newer car and update.
Attached below is my bracket for the 3Q0, still not perfect but its a nice idea in my opinion.
  • 3Q0 BRACKET.zip
Golfman1973
Dundee
I have completed this in my 2018 polo AW.
scott
Reaper1
Can these cameras be properly calibrated at a dealers after its installed?
or because its not in the correct position would it fail?
scott
Dealer wont do it, they cant take responsibility if something happens to you, they didnt install the camera.
hahoolam123
london
passat b8
i made some changes to the bracket.
the air vents are tilt in order to send the air exactly into the camera little window in order to defroze this part...
the factory heater is there because theres no other way to do it...
this is invisible of course , is under the tint
Excellent work. I've been looking to see if I can do this without changing the windscreen and saw this post. Excellent - is it possible to get 3d file for this to help a fellow VWer?
hahoolam123
london
passat b8
scott
This is a brilliant work. Where did you get the bit that holds hacked camera part? I have a passet - and my reverse mirror bracket only has small rain sensor hence there is no camera hold / and its angled hence can't fit the camera in.
gianry
Italy
Hi, I've ACC option and I'd like to fit a Front camera (pre lift GOLF model).
Could you help me to fit the camera with a bracket to wiindshild ? I've possibility to print 3d model .
AWD4416
Texas
Been following this since I got the ACC retrofit on my 2019 GTI S. I gave the no glass replacement a shot but it didn’t work out with the 3Q0 camera like everyone said. Actually I couldn’t update the firmware with VCP because the camera was in initialization state due to the extended flat cable. Removing the cable made that error go away.
How has everyone printed the calibration board? You guys use a printing place like the office max, UPS/FedEx store or did you print it at home and taped the smaller sheets together? Been looking at these places to print online but I’m not seeing them being able to print the file due to the size. Any input would be appreciated.
