Yes bought thid harness but, connectors are fitting only dont know how to connect the wiresNot sure what we are looking at. Did that harness come with a "kit" you purchased?
That adapter harness should be all you need. Plug the original car connector into it and the other end into your new clockspring. The two loose wires are the +12V that goes to the fuse box and the ground cable. I cannot imagine what the additional harness is for.I have a 2017 Tiguan and bought a new steering wheel with heating option.
Bought a clockspring 5Q0953569B
And bought this cable but there are 2 harnessen do I also use the Harness with the 2 wires?
https://a.aliexpress.com/_Ev7sSH3
There is no heating button on that wheel.I have a 2017 Tiguan and bought a new steering wheel with heating option.
Should only need two wires, power and a ground. Nothing to the bcm. The climate control panel with the heated steering wheel option does its work by canYeah, I'm thinking you don't need that additional harness. There are some VAG vehicles that have the heated steering wheel button on the center console... On our golf these are the buttons around the shifter but some cars have a panel of buttons somewhere else in the center console area. Of course we don't have our heated steering wheel button down there.
My guess is these two wires would go from that button to the BCM. Not applicable for our Golf and the Tiguan is very similar so likely not applicable for you either.
I know, haha. I was talking about cars with a heated steering wheel button in the center console (not our Golfs, or Tiguans to my knowledge).Should only need two wires, power and a ground. Nothing to the bcm. The climate control panel with the heated steering wheel option does its work by can
Don't you remember seeing the option for Steering Wheel heat button installed when going through the 2000+ adaptations for our facelift BCM's .Ahhhhhh.
Sorry is wrong picture ( did it on my mobile phone ) i have one with heatingThere
So i dont need to install the extra wires to the BCM?I know, haha. I was talking about cars with a heated steering wheel button in the center console (not our Golfs, or Tiguans to my knowledge).
In progress edit: found a picture for the Passat B8 console buttons, with steering wheel heat.
The aliexpress link posted by @smotz is listed for Tiguan II, Passat B8 and Touran II.
So those additional wires included, on the Passat, would go to the BCM.
You only need the BCM wiring if you have a button like my picture. I don't know what you have in the tiguan.So i dont need to install the extra wires to the BCM?
