VeloDub1
- Orange County, CA
TT pads are the rear upper spring #8j0-512-149 available at Dealer or cheaper from ECS tuning.
I did do myself and was about my 6th spring install aswell, you shouldn't have issue based on skill. The rear is easy but the front is just time consuming and can be frustrating until you figure out the technique to getting the bottom of the strut out of the knuckle. There are a few diy Instructions in the VWR spring threads. I used the 2x4 method for the front, to clear the dcc module I had to knotch a 2x4. I think im going to make a DCC strut DIY thread with more pics but here is some tips:
Tips:
For DCC:
- Use a notched 2x4 and frt pinch bolt installed at sway link hole, use a rubber tie down for support, LF:2x4 will be on rt side of strut and notched around DCC module, RF: 2x4 will be on left side of strut and not against DCC Module
- You have 3 level sensors(all but rt rear), for the front: Remove the entire sensor and arm (its close to 2x4 and you would risk breaking and need the room), Rear: just unclip arm from ball stud
All:
- Strut spreader trick: Install spreader at top of knuckle 1st, shake and push on top of brake rotor, knuckle should drop an inch, now install spreader at bottom middle of knuckle, shake and push on rotor again until it drops another 1/2 to 1". Now use 2x4 method to pull additional 1/2" out. If you dont get it to drop this 1st 1" to 1 1/2" before 2x4 method you may just raise the entire arm and get frustrated like I did until I figured out where to shake to releive tension to get the knuckle to drop.
Nice, thanks for the pics and the instructions ;-) very creative with the 2x4's
