Hey, Is it possible to buy any nav card(Fits MIB 2 Of course) that does not include my country in it and update it using Updated map That Has my country from VW Website?
It is one below the Pro, the one with the 6.5" display( cant remeber the name )Discover Pro?
And what about just getting an sd card ( not vw one, just buy one with enough capacity ) and uploading the map data to it?I think as long as it is a compatible card and you update with a compatible map update then it should work just fine.
Sent from my SM-G955F using Tapatalk
I already had a VW map card so just updated straight to that, all I can go by is the system requirements page posted above! It suggests discover media systems come with a card from factory so that should be used to update, but I can’t imagine (as long as it’s of matching specifications) why any card can’t be used, did you lose your map card??
Why is it saying this error? Ive tried 2 different Computers and both do this
Oh ok, But Dont I need to have NAV Data already on my unit before using this software?I’m trying to update as well and it’s also doing this so must be a server issue.
I wish VW had a similar method for U.S. cars.
Because what its installing is an update isnt it?
What file? And how can i fix it?It means file has been modified. If this is official file, than check sum might be for previous update, otherwise someone tempered with the file.
