greekspec2
- California
- 17 Golf R 17 BMW X1M
Thought I post some part numbers from a MK8 Golf R DSG .... the front hubs have a little more camber, stiffer sway bar and RS3 control arms. The rear uses stiffer bushings and a bigger sway bar.
FRONT
5WA407253B left wheel bearing housing
5WA407254B right wheel bearing housing
5WA407621A wheel hub with bearing
81A407151F left track control arm
81A407152F right track control arm
5Q0411303AC stabilizer 25x4
5WA411105A front coil spring
5WA423811D left tie rod end
5WA423812D right tie rod end
5WA199369A subframe
5WA413032T electronically shock absorber
1K0412303E bump stop
REAR
5WA511305L stabilizer
5WA505465A connecting link
5WA511115C coil spring
5WA505311A track control arm
5Q0505323C camber track control arm
5WA505435G left wheel bearing housing
5WA505436G right wheel bearing housing
5G0501529G tie rod
5WA513045BB electronically shock absorber
5G0513353G shock absorber mounting
5Q0511357S bump stop
BRAKES FRONT
5WA615123BSQ5 left brake caliper blue
5WA615124BSQ5 right brake caliper blue
5WA698151B brake pads
5WA615301A discs 357mm
5WA615311A left splash shield
5WA615312A right splash shield
5WA611701 brake hose
BRAKES REAR
5WA615423BSQ5 left brake caliper blue
5WA615424BSQ5 right brake caliper blue
5WA615425BSQ5 caliper carrier blue
5WA698451A brake pads
FRONT
5WA199369A subframe
REAR
5G0501529G tie rod
BRAKES FRONT
BRAKES REAR
