Cliff p.
- El Paso, TX
- '17 Golf R DSG
Having some discussion in another thread here, the rear o2 sensor "defouler" was brought up. Some mentioned that the rear o2 sensor on the MK7 is more than just an efficiency monitor/sniffer. Obviously, the rear o2 isn't a 5 wire (wideband/lambda) sensor, so this confuses me.
Is there a way the ECM interprets the rear o2 sensor working with the front o2 sensor, such that it will adjust the AFR target? I know that on older vehicles (OBDII without a 5 wire upstream sensor), the upstream and downstream sensors do work in tandem to target AFR set by ECM. I just can't see this solution for cars equipped with a wideband o2 sensor that is obviously more accurate in measuring precise AFR.
Mainly looking for those tuner guys in the audience to chime in, for my personal edification and for that of the community. I think it matters quite a bit if the rumors are true and the rear o2 performs more than a sanity check, and can actually affect AFR targets.
