JTM88
Broken Arrow, OK
2016 GTI
If they don't have a DOT certification stay away.
Anyone with a DOT certification (and label) is fine.
Even with a dot cert I had a line fail on track and result in a tiny/slow leak that caused severe fade at even low speeds. I see it as a freak accident, but it's always a risk with any part.
Thanks. The only ones I see that are certified and have a label are the Stoptech lines, so I guess I'll go with those.
victorofhavoc
Kansas City
Super secret sauce... There's only a few companies that actually go to the lengths required to get dot certified. They typically just white label their stuff to resellers.
Notably, the racing line brake lines are made by good ridge. Good ridge makes a lot of them...
Stoptech is dot certified and make their own, not sure if they white label but I'd bet they do.
Kart17
SE Michigan
'17 VW GTI Sport
Think my ac is on the way out the condenser was leaking when I did the intercooler install in the winter..
Pavel Jesenik
Czech republic
VW Golf 7
Hi everyone
I'm having trouble searching my contacts in Golf 7 Bluemotion
When I select contacts then tap Find -the keyboard is all greyed out and won’t let me select any letter number or symbol meaning I have to scroll through my whole phone book to select .
I have new infotainment firmware
Any advice would be appreciated
Thanks for help
CaptainRatty
Winston-Salem, NC
MK7 GTI
How quick do your exhaust tips turn black?
Within 200 miles, mine are jet black again with soot.
Giuseppe Busso
Greece
Seat Leon mk3 1.8 FR
The OEM DV of IS38 is the one in the bottom (2nd photo).
OEM 06H145710C
A friend gave me one with part number 06H145710D.
This supposed to be newer revision? Anyway I've already installed it, but do we know which is better to keep?
Also some inlet inspection
Nineeightyone
Pennsylvania
20 CX5 19 GTI 10 MZ3
Hi everyone
Thanks for help
I know here in the states, Android Auto by default is not allowed to utilize the keyboard under certain conditions -- and this is controlled by the vehicle, and not by the device. You may need to allow keyboard usage using VCDS. However, I don't know if that is a worldwide restriction or not, just a thought.
swcrow
7.5 GTI
did a E30 log on my AP.....it saved it as a csv.gz.....what the crap is that? I did a log on it after an update a few days ago and saved the log as a regular .csv
I changed nothing.
Can I convert to .csv?
EpicTech
Houston
MK7 GTI 6sp w/PP
I changed nothing.
.gz files are compatible with Linux based systems, at the core they are UNIX, so Mac's (Apple) and Android OS can view them and of course any standard Linux OS. SUSE, Redhat, Ubuntu etc.
-You can convert with 7zip on Windows.
krs
Las Vegas, NV
MKVIIS R
Is this from my car? Was sitting in the passenger side floor, doesn’t look familiar, and can’t see where it would have come from. ¯\_(ツ)_/¯
swcrow
7.5 GTI
Uhhhhhhh
I’m dumb
How?
Edit …. Got it
swcrow
7.5 GTI
Yeah gz is gzip and a default zip format on some Linux distros. 7zip usually works, just don't get it from sketchy sources. There have been supply chain attacks on some 7zip mirrors recently 🙄
Odd that it just started happening too
