- Bay Area Smoke Hell
- DVP Spektrm, MK4 R32
Update 3/23/17 This issue was caused by hardwiring a dash cam to fuse 37, the Left DRL/Parking Light Control Module. The last 10a fuse on the bottom row in the fuse panel. This module feeds back to the BCM and it is suspected that there was some sort of random power fluctuations causing the BCM to dip power to KESSY or something like that.
Re-wired to the 12v 20a fuse location and no more issues.
Update 2/24/17 Dealership reset all coding defaults in the Central Electrics system, and this resolved the issue. The shop foreman who was the one working on my car was a little perplexed given that none of the coding I did was anything to do with KESSY and had been in place for months before this all started to happen.
I had done the following:
- I coded out the LED license plate light error when I switched to LED plate bulbs.
- I changed the tail lights to work in unison, 4 at once when braking, then inner/outer (together) for blinkers.
- I changed the comfort blink setting from 3 to 4.
- Open/Close windows with key fob.
- Turn on DRL option in MIB.
- DRL stay on with turn signals.
I'll be adding each one of these things back one by one, with the exception of DRL option in MIB because I never used it, to test and figure out which one caused it.
Original Post
So in the last 3 weeks or so I've experienced intermittent "key not in range" messages on the dash, while I was sitting in the car, with it in park but had it running.
Sometimes the key was in my right pocket.
Sometimes the key was sitting in the cubby in front of the shifter.
One time the key was sitting in the cup holder.
Eventually the error seems to go away on its own while siting idle, or goes away when I put the car into gear and start driving.
It has been a bit colder here in the SF Bay Area for a few weeks, but I'm not sure why that would have anything to do with it.
Things I've tried:
- Replaced the battery (though I shouldn't have to, the car is 3 months old).
- Searching the forums, didn't find much on this aside from other people experiencing it and it most often being due to a low battery (I don't have a low battery)
- Scanning for error codes with OBDEleven (none found for the KESSY system)
Does anyone have any ideas/suggestions on this one? Thanks.
Original Post
Things I've tried:
