Hi all
I need some assistance please with finding off the shelf quality in line crossovers that will neatly snug behind the A pillars that house my front Dynaudio tweeters in my Mk 7 Golf.
Dynaudio tweeters that are fitted with the full Dynaudio upgrade system ordinarily are fed a direct active crossover signal from the Dynaudio DSP amp. However my car has a somewhat hybrid set up with front stock VW 20W 4 ohm Mids; and the stock tweeters-that ordinarily have caps on them-swapped out for these heavier duty Dynaudio’s. All four component door speakers are powered by the OEM upgrade 5 channel Helix DSP amp (380 watts total) which also powers the wheel well sub.
I have read that Dynaudio Esotec tweeters can handle as low as 2200 hz up till 3000 with 12db roll off ? I don’t know what my VW Dynaudio specs are or the model number to research.
however I was hoping the aficionado’s on here could kindly guide me to a supplier with good quality ready made plug and play in line caps that I can splice into tweeter feed.
The front Mids are 20 W 4ohm standard VW made in Belgium units but unsure of their frequency range; hoping to be guided as to what lowest frequency that my Dynaudio tweeters can crossover with these Mids.
I’ve attached pics of my tweeters in case anyone recognises them and can determine the specs for them. They are quite weighty and have a big magnet and most other component tweeters such as Focal Audio etc are lightweight and flimsy in comparison.
thanks in advance
thanks in advance
