Hub of Spacer broke off? What the....
swcrow
7.5 GTI
So I decided to do a quick wheel rotation and when I got to my rear wheels I found the pictures below. The hub portion of the spacer literally broke off. Has anyone ever seen this before? Their hub centric and my wheels are hubcentric as well so I don’t get it. These are BFI spacers fwiw
Now I have to bolt the wheels back on with no hub to rest on, Until I can get replacement spacers
swcrow
7.5 GTI
Mk7tsi3door
Nova Scotia
The rears break off if they are less then 15mm I think. It hits on the ... axle cap? Lol not sure but I broke some like that too
swcrow
7.5 GTI
Reeeeeeally? I’m glad you said this... was about to replace with another set....of 10mm
Only the rears?
I had it happen and I don't remember the brand of spacer. If you have a Discount Tire in your area I would buy tires from them because they use a round wire brush and clean off all that rust and corrosion every time you rotate and balance.
