DIY MIB1 to MIB2 Infotainment Conversion (Part 1)
madwazzabi
Toronto, Canada
2015 GTI Atbhn PP
And if you're a struggling artist down on their luck, you can always try this. You just need a USB to Ethernet adapter with the ASIX AX88772 chipset and the remote programmer guys can update the firmware remotely for you along with all the remote programming that you're getting them to do if you'd rather not do the firmware update yourself.
bmxdarcy
Alabama
2015 Sportwagen TDI
Hey guys, I had been trying to lurk my way through this swap but now I'm stuck. I think it may be either I purchased in-compatible part numbers for the screen and infotainment unit or because I haven't installed the USB yet and still have the MDI Cable installed, (although that seems unlikely to me). We have ODIS at work so CP was removed and for the most part everything seems to work but no sound. I have the same issue HawkAssault described a couple pages back where the turning the volume nob just shows a full red bar but no sound. Here's the info for reference, let me know if you want a scan. Can anyone guide me?
I have a 2015 Sportwagen TDI NAR which came with Fender audio.
Parts purchased: 3G0 035 043 C and 5G0 919 606
In VCDS - Module 47 Coding:
12000000AAAAAA0000
Module 5F Adaptations all confirmed exept:
IDE03471-ENG07590-Fahrzeugkonfiguration-Mirror_link,function_on_hmi_on: change to "on" - This adaptation option does not appear
Bluetooth and telephone functions are 'not available' at the moment as well.
Thanks in advance!
madwazzabi
Toronto, Canada
2015 GTI Atbhn PP
Sounds similar to what I went through and documented a few posts earlier here I had also suggested to @HawkeAssault to replace his Fender Amp here . I assume HawkeAssult went through with replacing the amp and was successful as no further posts on the matter since. I think you have the same issue but I find it interesting is that you have a European Discover Pro and it wasn't a hacked unit (or at least you haven't disclosed that you removed CP on a hacked unit). So far on the small sample size I had seen mainly the NAR Discover Pro headunits being the common link in units that cannot be made to work with the MIB1 Fender amp.
HawkeAssault
Arizona Tucson/Phoenix
'15 GTI, '92 Corrado
I haven't got the new amp in yet. I do have an amp out of a 2017 GTI buuuuuuuut I've not gotten around to scheduling an appointment with my dealer to remove CP.
George Ab
Pacific NW
12000000AAAAAA0000
Thanks in advance!
Verify that you made the coding changes to the 5F head unit is set to work with Fender Amp. Bytes 01-07, byte 11, and byte 19 (MOST on): https://www.golfmk7.com/forums/index.php?threads/recoding-the-radio-to-eliminate-fender-amp.341803/ You mentioned adaptations, but not coding; the unit pulled may not have come from a non-Fender configuration so they would have to be changed. The thread I pointed to shows how to perform with both VCDS and OBD11.
Maybe the Fender amp, but my understanding is the MIB1 Fender amp works with MIB2 head unit with the code change you made. It has been recently found that MIB2.5 head units and now the MIB2 3G0 035 047 (thanks for info madwazzabi (I will update original thread)) do not play well with the MIB1 Fender amps. The MIB2 amp does sound better than the MIB1 amp, so you may consider that.
For blue tooth, CarPlay, drive modes you will need FeC's installed. To install you will need the USB cable.
Cuzoe
I don't know that I've ever seen the part number for the cable, only for the USB port itself; 5G0035222E, somewhere around $50 from the dealer. Many just ordered the cable/port from AliExpress. I believe EZT sells the cable/port or just the cable by itself. I would assume they have US stock so might be worth the premium if you're in a hurry.
everest_4
Milwaukee, WI
7.5R 6MT
Hey all, so I have everything installed and I have the Dlink cable for coding. The company I was going through for the coding/ODIS basically took my money and after a couple issues from them poorly communicating they have stopped replying altogether. Who can point me in the direction to finish my retrofit?
Cuzoe
Really sorry to hear that... been there before.
But reach out to @simaservis1108 or @doctor.
ash9949
Poland
golf 7
which head unit you have .?
mib std2 - thenisat/preh are easy to patch
mib std2 - delphi unit you need dlink
mib harman high unit - it is also easy but a little complicated but can be done
dont pay any money to anyone because everything is for free, people whom you have paid money they didnt pay for anyone
simaservis1108
Serbia,Belgrade
Seat Leon 5F FR
I can do it for you.Without problems.
Shit like that happens all the time because people read some shitty forums online and try "copy-cat" solutions.
Nowadays I get many bricked units after "experts" tried to flash/unlock them.
everest_4
Milwaukee, WI
7.5R 6MT
I have the 8" MIB 2.
ash9949
Poland
golf 7
