BrownMK7Driver
- St Catherines, Ontario. Canada
Can someone provide me with Jack's skype? I want to find out his cost and availability before i start to source parts
Assuming you don't have nav the screen part numbers in the OP are the same except for a mute/voice button. I would just get whatever is cheaper. The 6.5" screens use your existing screen trim.if i can source a: 3Q0035844A for fairly cheap, whats the best screen that would be reasonably cheap? (~100Cad)?
Trying to get this retrofit done for less than 800CAD (including jack's service)
Is the VAS5... cable required for the upgrade to MIB2 or can this be done with a ross tech vag-com cable?
Gotta have the VAS5 cable. The Ross Tech one won't work.
If Carplay does not work when the MIB2 Discover Pro is installed:
Enter 5F Information Electronics in VCDS
Enter Adaptation-10
Under "Channel 64B", select the channels listed below and make the following changes in the "New Value" Drop down.
IDE03471-ENG130249-Fahrzeugkonfiguration-Apple_DIO: change to "on"
IDE03471-ENG130248-Fahrzeugkonfiguration-Google_GAL: change to "ein"
IDE03471-ENG07590-Fahrzeugkonfiguration-Mirror_link,function_on_hmi_on: change to "on"
IDE10480-MAS10741-Schnittstelle für externen Medien: Aktivierung-Anschluss 1: change to "activated"
Press DO IT to save changes
=robtemp;810893]Is the VAS5... cable required for the upgrade to MIB2 or can this be done with a ross tech vag-com cable?
Required if you want car play/ Android auto.
Sent from my Pixel 2 XL using Tapatalk
Thank you for confirming.
VAGCOM, OBD11, or VAS5 will work.
Great to know. Thanks so much!
