Cuzoe
- Los Angeles
Nice, so that means your dataset already had DCC settings, but since it wasn't enabled in coding no menu showed. And yea gotta let the can bus sleep before some things will show up, while other things show up instantly .
The sensors have to be within a certain range for basic settings to run. If they are not in the range the sensor could be faulty, or mounted incorrectly (although that's not too likely). The "not possible" means not in the right range.
The DCC module shows values for 4 sensors but you only need 3, Front Left/Right and Rear Left. My assumption is the DCC module could be used on a car with air suspension and then all 4 corners would need a height sensor.
