So if one gets the Tiguan door handles I assume they also need to get a Tiguan areaview harness in order to have the right angle Fakra, correct?
**** This (part of) this post is off topic ****
Just as I was going to ask about the door handles I chose the less-lazy route. My memory from the past was you could only get KESSY illuminated door handles.
But this morning I see that is no longer the case...
https://www.aliexpress.us/item/3256804250181796.html
As I'm sure you can guess... I've got them coming
Also,
@CarloP, I see you have the same weirdness with the front illumination "sun" icon being on the steering wheel instead of the dash.
At some point I'm going to
modify the GCA file to fix that...
https://golfmk7.com/forums/index.php?threads/mib2-high-discover-pro-toolbox.367798/post-7873345
Also noticed your door handle lights (in car) are white but your infotainment shows them as purple (RGB)... you can fix that in the BCM adaptations...
interior_light_2nd_generation_p_ambienteumfang_mehrfarbig_HMI... change bit 3 from 1 > 0... so from xxxx1xxx > xxxx0xxx
- this will change the door handle light from RGB to white on the infotainment screen (unless you're planning to replace with an RGB
