Areaview Retrofit Progress
Reaper1
Finally got It to work, the main connector seems to not fully Insert into the module, took the connector shell off and it worked.( Was having some hard time getting It to work but the problem was there were no cameras connected, once I connected 1 camera the display was working)
Only coding change I made as In park assist module, change camera type to Environmental camera.
Would you guys mind sharing your 6C coding?, Trying to fine tune the coding but not so sure what needs to be coded.
Cuzoe
I've seen pictures of the whole mirror assembly, mounting does not look the same. Messaged them about the "Golf Mk7" lower shell. Got an auto-response about a spring festival saying to expect up to a 72 hour delay.
It was showing 1 piece available, which I thought was interesting.
https://www.aliexpress.us/item/3256804734618749.html
Edit: I just clicked the link and it now shows not available... one of you folks just buy this? :unsure:
Reaper1
I have bought this a month a ago, He didn't ship, and then sent a message that It Is still in designing and will be done In about a year.
Panora
Dublin
Hi guys ,
did someone got that cover on test or what you used in your cars ? just drill a hole ?
mirror harness should have some part number to get them of ASO , could b of Passat or Arteon , even Skoda b ok i guess .
i got door harness to reduce diy job.
Thx,
xabhax
15 GTI
Reaper1
How you manage to connect that ?
I have same harness
Still waiting for camera facelift of Arteon but of a picture looks like same as you have.
Hey, To make It as clean as possible you will need to order an extension cable.
I contacted this seller on Aliexpress and asked him to make a custom cable. https://bevotoprfconnectorcable.ali...o.order_list.order_list_main.2.3e0d1802K57dS5
You need two male connectors that match the two females on the emblem itself, and make sure the wiring isn't like the usual Fakra method, It needs to be
pin1 - pin1
pin2 - pin2
pin3 - pin3
pin4 - pin4
Panora
Dublin
Reaper1 , thank you,
i think i can bypassing extension to replace that HSD 4 Pin Connector
to this one.
1PCS-HSD-LVDS-4-Pin-Connector-Fakra-Type-Straight-Male-Plug-Crimp-for-Dacar-535-4.jpg_640x640.jpg
I should have all parts this week ,
Don't know why all them have for sale harness kit with wrong plugs ;-)
Panora
Dublin
Hi guys ,
Got today all parts ,
i was curies about reverse camera plug and there is a little wire BLACK-BLUE plugin directly to camera
so i removed and bingo ! BLACK plug can b replaced by green one .
My harness plug can b used directly to camera whiteout DIY job.
i will try connect first on bench did all work
just curies how to pop up camera on bench , cant do reverse but i can use parktronic button i think ?
did someone try that already ?
Panora
Dublin
There is little different on front badge,
i don't want touch my grill ( MK7.5 GTI ) so i try get one damage
of scrap yard to play with modifications.
Camera wont fit inside , need cut little around radar plug .
BTW, i have 6C module 5Q0907556E , hope that will work .
Parametrization for Passat or Tiguan b better ?
Tiguan have only RHD LHD ;-)
Panora
Dublin
That wasn't easy day 4 me today,
Front badge that was a nightmare , is not to bad , but i will try to little lowered maybe 5mm
Camera plug blocking a radar plug , so i have to modify camera plug to smaller
and elbow same like in the doors and waterproof which i did but i thing i will order factory.
Was to dark to take good picture,
About mirrors ,that will take some time ,
i ordered elbow LVDS harness to the doors.
have original door plugs so want to do proper way.
