q2quest
- Santa Rosa, CA
- Car(s)
- 2012 Golf 2.5 manual
When I was looking for this information about a month ago I couldn't easily find it so I decided to post this for others who are trying to find a way to bypass the Fender amp to install aftermarket amps, DSPs, etc.
The back of the MIB2 with Fender has a blank where normally the speaker wires would be in a non Fender system. There are eight pins for four passive speakers. In the absence of the proper VW connector I used four small speaker lead connectors. They are the perfect size and I plugged them into the pins in the back. I only needed a left and a right channel for my DSP. In the photo below the connectors are plugged into the rear channel right and left. I later realized that by doing this I would not be able to receive phone calls as the bluetooth calls play only through the front speakers. So, while both front and rear are full range signals, you should tap into the front left and right channels instead.
The picture below and most of this content was provided by Don (DV52) who was extremely helpful to me. Socket "N" is where the speaker pins are. I found that in my unit the designated numbered pins are exactly upside down from this depiction. Only #4 and #8 are labelled on the unit. You want 7/3 and 6/2, unlike the pins I used originally in the above photo.
I ran these speaker wires behind the glovebox, behind the passenger kick panel, under the passenger side sill plate and into the trunk. Super easy. You're dealing with only 4 speaker wires instead of 10 or 12 if you grab the speaker wires off the Fender amp.
Now for the recoding. The pictures below are screen shots from my laptop using VCDS in order.
Take a picture of your long coding just in case you get messed up you can always put it back the way it was.
Use the tab button on your keyboard to cycle through the individual bytes and make the following selections.
The photos below are screen shots of a VW diagnostics software I am unfamiliar with, but I believe it is OBD11. They were also provided by (DV52) as a guide to recoding if using that application instead.
I hope this helps someone else. I also hope I didn't forget anything. Originally when I was using the speaker wires off the Fender amp into my DSP I got terrible pops when the radio was off. Grabbing the wires from the head unit as described cured those pops and completely simplified the wiring.
