cldlhd
- bucks county,pennsylvania
I'm sure this has been gone over before but bear with me. I just picked up my 2016 Golf SE on Saturday night and was wondering about the pinch welds and best way to raise and support the car with my own hydraulic jack and stands ( Esco 10499's ).Is the weight of the car supposed to be supported by the reinforced pinch weld ( runs perpendicular to the ground ) or the flat metal on either side of the pinch weld that runs parallel to the ground? Or maybe both? A peek at the factory jack may enlighten me but only had the car 4 days and it's rained for 3. I just got one of those side lift jack pads and the groove is so deep that the pinch welds bottom doesn't make contact with it and all the weight would be on the metal on the sides of the pinch welds. That looks ok at the back but the front pinch welds have underbody plastic trim that almost butts up against it and the trim would be crushed by the jack pad.The pinch weld looks reinforced to the point where I imagine it"s meant to hold the weight and not merely keep the jack head in place. I'm thinking about getting a hockey puck and cutting a groove to match the depth of the factory jack head.
