tigeo
- Richmond, VA area
I hate my shiny tape I can see through my grille. There. I said it. I will Amazon some.There are plenty of options on Amazon. I just searched black aluminum tape.
So, this setrab 6-series 19 row cooler is technically undersized for my application, and that certainly shows on hot days when it simply delays the oil overheating. Especially at a large track like VIR, i think you will find the smaller racing line oil cooler to be woefully inadequate for keeping temps under control.It makes me wonder how the Racingline one would work out here. It's smaller (1/2 size of his) but mounts to p. side.
Track testing will be interesting but looks like it may not need the duct when center mounted....so just hammering that IC outlet with hot air basically.
It's interesting that some have reported the RL sorting their oil temp issues. So many variables here. Does your cooler isolate oil from coolant or is that factory connection/heat exchanger still in place with the one you have? You have Iabed one right? Does that use the factory oil filter?So, this setrab 6-series 19 row cooler is technically undersized for my application, and that certainly shows on hot days when it simply delays the oil overheating. Especially at a large track like VIR, i think you will find the smaller racing line oil cooler to be woefully inadequate for keeping temps under control.
I think the oil cooler issue is a nested loop situation. Oil gets hot. Cooler removes heat. Radiant heat from the oil cooler transfers to coolant because cooler is in front of radiator. Coolant capacity to handle heat diminishes increasing oil temps. And the cycle continues. Clearly having the large oil cooler in front of the IC outlet increased IAT which makes sense; moving to center sorted that based on the data collected. The duct looks to not be necessary as the additional heat through the cooling stack is being managed by the IC now in that center-mounted position.
What I'm trying to say here is that maybe bigger isn’t better w/r to oil coolers. It's possible a smaller oil cooler may actually work better in the front-mounted position. The larger one in place of your aux radiator out of the main cooling stack should be ok. All a hypotheses of course and keep in mind I'm a geologist.
Do we have any data from someone running a RL oil cooler?
Ah because you have no factory heat exchanger now so that makes more sense needing this size. The smaller RL one is working along side the factory heat exchanger more like a booster not the sole cooler so doesn't need to be as big...at least that's how it makes sense to me.I do have the iabed setup that removes the factory heat exchanger and retains the factory filter.
To be frank, ive seen a lot of comments from people in the community claiming certain things are sufficient to solve their problems which in my opinion are unacceptable. "DS2500s are a great track pad!" for example. However, everyone's use case is different. what might be sufficient on a stock GTI cant keep up with the added thermal input of a is38 on a tuned R. When i was running 2:24s at VIR i had a lot less themal issues than now when im running 2:12s. A track like VIR with large WOT sections will be different than a short track without long straights. People also have different standards for what is "solved", I want oil temps under 260, but some people are happy starting at 278 all day long.
Setrab has done the calculations on their coolers to determine their cooling capacity, which you can see here (mine is the 50-619-7612):
"EOC hp and btu/hr range based on specific performance parameters that if varied may result in different performance results. Low EOC hp and btu/hr range based on typical wet sump high-performance application and typical variable parameters. High EOC hp and btu/hr range based on typical dry sump high-performance application and typical variable parameters. Wet Sump Parameters include: oil flow rate, 5gpm; 20/50 engine oil or similar; 130ºF ITD; 60mph airflow. Dry Sump Parameters include: oil flow rate, 8gpm; 20/50 engine oil or similar; 140ºF ITD; 80mph airflow."
a smaller cooler simply does not have the thermal capacity to work with higher hp numbers. its physics.
