Sorry to bump such an old thread but I think my question closely related to the previous posts. I have Osram headlights, full assemblies, replaced my halogens. They are plug & play, much like most of the reps out there. I have the soft code for left/right parking lights. Doesn't throw a dash error but shows up in a scan. Looking at the picture above, I see the following:
Left Front Parking Light - Leuchte2SL VLB10 - Load Type 2 (on my car this is Lasttyp 2, just a typo in the pic I think)
Right Front Parking Light - Leuchte3SL VRB21 - Lasttyp 3
The "B10" for the left and the "B21" for the right correspond to pins on the BCM (J519), confirmed with the J519 pinout chart. Right now both these channels are set to "Type 10 - allgemeine Scheinwerfer" which translates to general headlights, according to Google translate anyway. If I'm remembering the choices for this adaptation correctly I should be able to set it to "not active." There is a "Fehlerort mittleres" adaptation channel associated with B10 and B21, which translates to "fault location medium." This channel's value is currently "45" but I'm not sure what that means. I would think the value in this channel won't matter if the type is set to "not active" though.
I'm thinking setting the type to "not active" for the two Lasttyp channels should mean the BCM no longer looks for them. And if that's the case, I should no longer get the soft codes for those lights. Thoughts anyone?
