Got the front LCA’s and rear trailing arms in. My car fought me today. Trying to get the bolts lined up to get the trailing arm bolted to the rear upright was a pain.
So I realized that my rear toe links were binding quite a bit. Going with spherical here is the way to go. The joint can now articulate through the full range of motion.
So I have a question for you folks. When installing the front LCA, i discovered the rear vertical bolt hole is slotted. What the frack???
Is this correct from the factory or has this just wallowed out in my case?
Its on both sides and the same on the upper and lower hole. Which makes me think it’s factory. Plus I have not had any clunks or erratic handling.
